Question about Ovens
Country fire star how to remove from stove - Ovens
Do I need special tools to remove back of oven, allen keys don't seem to fit
They won't be high security fixings.
Look at the head of the screws with a flashlight.
So allen keys (six sided) either metric or imperial (they are fractionally different sizes.
Robertson (square head)
Torx (star head).
Why do you want to remove the back of the oven? Access is usually from the rear of the stove, the bit next to the wall, via an inspection cover. The exception is fan assisted ovens, which is often a combination of both.
Nov 18, 2015 | Ovens
What's causing my oven to stay hot HOURS after I've turned it off?
If you have the older type stove with the oven knob that has the temperature setting around the outside of the knob, then that part could be bad. It is called a thermostat. That part usually comes with sensor attached. The sensor is the long skinny looking tube that goes through a hole and into the oven.
If you have the newer type electronic stove where you program in the temperature you want, the electronic circuit board could be bad. But the electronic stoves have a over temperature protection built into the circuit board, so that would have engaged, shutting down the stove.
Either way, it is a potential fire hazard and needs to be addressed.
Nov 07, 2014 | Hotpoint Ovens
My frigidaire stove I have to umplugg it because keeps beeping f10 can' stop I push any bottom and keeps beeping
Hi Elizabeth! From what you have posted, your appliance is experiencing a high-temperature error code (F10). A high-temperature error indicates that your oven has reached too high of a temperature for too long of a time period. If unplugging your appliance does not prove to be successful, you would require a visit from a professional to check the temperature sensor and the electronic oven control (brains of your appliance behind the touch pad). If you have any other questions please comment so I can help!
Thanks,
Chris
Dec 18, 2013 | Frigidaire 30" Self-Cleaning Freestanding...
Hi there. I have just moved in to a flat & have been asked if my stoves 050531075 gas oven is fitted with something called a FSD (Fire Suppresion Device) Would you be able to tell me please?
The are probably referring to an automatic fire extinguisher system, but from what I just read, the UK only requires a manual fire extinguisher to meet code.
The FSD would be fire extinguishers mounted on the wall instead of portable. They are only required in commercial restruarants.
Jun 08, 2011 | Stoves Ovens
I live in a rental and tired to cook a chicken,some greese hit the coil burner in botton.I was standing in front when it had a flash fire out from between the door and the drawer.Is this a flaw in this...
That is to be expected when grease hits a heating element, just be cautious and always remember to use flour on a grease fire, not water.
May 30, 2011 | Ovens
I have a Simpson electric oven with stove top elements, and one of the burners will only cook at the highest level, I cant figure out how to change it, any suggestions?
You need to change the "Simmerstat", take the model number to your local electrical parts supplier/parts counter at your local stove retail shop that sells Simpson stoves and ask for one for that model, make sure you get the right one for the position as some control a single element and some control dual elements.
*** TURN OFF THE WALL SWITCH AND ENSURE NO POWER IS APPLIED TO THE STOVE BEFORE PROCEEDING ****
Remove the upper back panel of the stove. Swap wire for wire of the old simmerstat to the new one, remove the knob from the old Simmerstat, undo the nut securing the simmerstat in the oven control panel and discard, fit new one, secure, fit knob, fit back panel, turn on wall switch and test.
Some countrys/states require registered electricians perform this task on electrical appliances so you must ensure you can do this legally before you start and take the relevant safety precautions and don't electrocute yourself.
Apr 13, 2011 | Ovens
Right side stove top igniters dont fire off of right side knobs+
clean the pilot jets out sonds as if they are clogged. if the right side is only being lit once the left side is on then you better not run the right until you do get it fixed as more than likely whats happening is the enough gas is traveling through the chamber to be ignited by the left sides flame and that can be dangerous, however your stove uses an electronic lighter all you need to do is clean the contact points so that they will spark cleanly if it still won't light you need a repairman.
Dec 07, 2009 | Ovens
The oven burner will not ignite.
Because the glowbar is glowing does not necessarily make it good.
Turn off the gas to the stove. Remove the oven racks. Remove the bottom oven pan. Remove the flame spreader. This gives you access to the glow bar and gas valve.
Put a clamp on amp meter around one wire of the glowbar. Turn the oven control on to BAKE.
If the glowbar reads 3 amps or less,replace the glowbar ignitor.
If the glowbar reads good,check the burner tube for a white ash buildup. It can be cleaned with a wire brush. Look closely near the glowbar section of the burner.
Check all the wire connections for the gas valve.
If the glowbar is good and the ash deposits are gone and the oven still will not ignite,the next step is to replace the gas safety valve.
Dec 01, 2009 | Amana Ovens
Montgomery ward gas stove. top burners work fine. oven barely gets warm
I have a whirlpool gas stove oven fire will not go off when in off position. Is the fire suppose to go off completely?
Aug 21, 2009 | GE JGRS14 Gas Single Oven
Stove smokes when i turn the oven on
on the oven's smooth surface you should use a razor blade and scrap off the plastic (when cooled).. if the plastic melted on the burner, you may need to replace that particular element from a local appliance part store. easy to do.
Apr 20, 2009 | GE JKS05 Electric Single Oven
Ovens Logo
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
