Question about HP DeskJet 3050A All-In-One Printer 2982936
Inisert ink cartigage for HP CR 232A cartidge 61
Nothing donot remember how to put in into the printer.
    Renaissance:
    An user who is expert in 3 categories / brands.
  • HP Master
  • 884 Answers
Hi there
I have found a manual for you which not only tells you step-by-step how to change the ink cartridges, but has pictures of the operation as well. You can load it by going here:
http://h10032.www1.hp.com/ctg/Manual/c02853536.pdf
The pages you want are 28 et ff, and then you can save the manual as a pdf document to your computer for future reference.
Hope this is helpful, if so would you please register that with Fixya
Cheers
Posted on Dec 10, 2014
HP Deskjet Printer 1050
Contact HP support and I am sure they will think of something.
However, for the time being, I believe HP printers had this toner/ink/cartridge stuff in settings.
Jul 25, 2013 | Office Equipment & Supplies
HOW CAN I RESET INK CARTIDGE LEVELS ON HP DESKJET 3510
When you get an HP 61 / 61XL integrated ink cartridge refilled (i.e. currently offered at Costco or Frys today) or if you buy a remanufactured/compatible HP ink cartridge, the ink levels cannot be reset (HP has a smart chip embedded within the nozzle plate at base of ink cartridge which counts the drops and then registers as empty).....so you'll just need to live with it and ignore 'ink low', 'non-genuine', 'counterfeit' messages and similar while you are using these types of aftermarket supplies. The first video below provides an overview of this 'low ink' phenomena.
Additionally, severe cartridge errors (i.e. Incompatible cartridges, Black/Color cartridge(s) problem / Cartridge not intended for this printer, etc.) typically indicate the internal micro-electronics of the HP 61 cartridge are electrically damaged. The cartridges electrical wire runs at rear and lower side of the ink cartridge are very delicate and are somewhat susceptible to ink attack over time, which can lead to premature failures. In addition, the older the cartridge the higher the chance of an internal electrical failure due to prolonged ink exposure and subsequent circuit corrosion. I suggest you run a Tap 41 diagnostic test to check cartridges electrical health (this is a forced service test so the printer will attempt to send whether cartridges are good or not); Refer to Inkjet411 youtube videos below:
HP 60, 60XL, 61, 61XL Ink Cartridge Refills - Solving Errors & Warnings:
http://www.youtube.com/watch?v=BskAfa6NJSg
HP Deskjet 1000-3056 Printer Models -- HP 61 Ink Cartridges Tap 41 Diagnostics Test
http://www.youtube.com/watch?v=tMZkqE36ifk
Feb 18, 2013 | HP PhotoSmart C4480 All-in-One Printer ...
HELP!
use a GENUINE cartridge
Mar 27, 2010 | HP Printer/Scanner/Copier 2210 Ink-jet...
THIS PRINTER COME TO ME WHIT OUT INK CARTIDGES BUT I GET NEW HP CARTIDGES , AND PUT IT IN THE PRINTER BUT IT SHOW IN THE DISPLAY USE THE INTRODUCTORY CARTIDGES THAT WERE SHIPPED WHIT YOUR PRINTER
yes right..u need the introductory cartridge in order to align the cartridges...so cal hp on 18004746836...
they will ship the cartdrige at free of cost...
Mar 24, 2010 | Office Equipment & Supplies
I have hp 4288 printer. Refilled cartridge does not work
ur cartidge nosel is jammed. get some drop of water on ur finger tip put it on nosel then put the cartidge nosel on newspaper because it is a good absorber it wiil help the ink to come out try for some times if it not work replace ur cartidge...
Nov 29, 2009 | HP DeskJet F380 All-In-One Printer
I have new ink cartrages but nothing prints Parts move but nothing prints
did you perform the ALIGN TEST procedure ??? everytime you replace cartidges you have to perform this test . AJ
Jul 14, 2009 | HP OfficeJet D135 All-In-One InkJet...
Error code E-90
When turning on the power, the Carriage
Unit collides to the Change Lever
located to the front side of the printer. CAUSE
PF Motor
Ink System
CR Scale
CR Encoder Board
Holder Shaft Unit
OR IT S SAMPLE JUST WHEN YOU OPEN THE SCANNER TRY TO MOVE THE CARRIAGE BY THE GEAR OR SOME PAPER JAME IT DO THIS PROBLEM.
Oct 22, 2008 | Epson Stylus CX7800 All-In-One InkJet...
How to refil ink in hp 2120 cartidge
actually your printer cartridge was cloted or maybe airlocked.
You must use tissue paper and rub it on the nozzle side. Ink may flow out.
sukumar.t.k.
Jul 30, 2008 | HP Office Equipment & Supplies
HP Deskjet D4160
This is Vikram Kumar Thumu from India-Hyderabad. I have seen your issue and I would like to provide my solution on the issue.
Well, this is the issue that could happen with either with Printer Software or with Printer Ink cartidges that could be out of ink or very low in ink...
To isolate and to resolve the issue I recommend you to perform below solution. I hope that this will fix the issue for you.
Solution 1: Hard Reset Printer
1. Turn OFF printer
2. Disconnect Printer from Computer.
3. Remove the Printer Power Cable from wall outlet and then try to remove the ink cartidges from Printer.
4. Wait for a minute.
5. and then reseat the Printer ink cartidges and then Connect the Printer cable to the Computer and then Power ON Printer.
This should generally fix the issue. However, if the issue still persists then I recommend you to proceed further solution on the issue.
Soltution 2:
Right click on the Printer icon of HP Deskjet D4100 Series and then select the option " online " and then press F5 key in the keyboard. to effect the changes.
Solution 3:
Try to print a Cartidges Test page from Printer Properties to check the ink cartidges ink status.
if found issue with ink cartridges then replace them else try to uninstall and reinstall the Printer software.
This should resolve the issue. If the issue still persists then I recommend you to contact HP CHAT SUPPORT or HP PHONE SUPPORT team or HP EMAIL Support on this issue. They can help you further to resolve the issue for you.
If you need any further assistance you can mail me at thumuvikram@rediffmail.com. I 'll be glad to help you ...
Bye.
Mar 27, 2008 | Apple HP DeskJet 3820 InkJet Printer
HP DeskJet 3050A All-In-One Printer 2982936 Logo
44 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
