Compressor gets up to pressure but after one or two nails it will turn on again sometimes it seems to cough a few times before it will finally shut off only to come on again after one or two nails. what seems to be the problem?
There is a differential set point. General use is 10 psi difference
Look under cap for the location of this setting..
You compressor don't have an adjustment, I'm assuming it's a type 2 if so change the pressure switch part# 5140062-38 make sure there is no water on the tank also
You can adjust the "cut in" set point to a lower pressure. your pressure switch has a screw that you can turn out to lower the set point.
