The heat and ac work, but not all the time. When I first turn the heat on it blows hot, but over a two or more hour period is stops blowing hot and is cold air coming out only.
The freon level is good, no leaks. tried moving the temp lever back and forth, feel like it sticks maybe. ice builds up on the outside but was told that is normal
    Scholar:
  • 103 Answers
Ice buildup on the coils is not normal. Once iced over, the coils can no longer extract heat out of the air which is how a heat-pump like this works.
Posted on Dec 10, 2014
4 Suggested Answers
Sea Breeze
  • 4654 Answers
SOURCE: Automotive AC Prob
Automotive AC is a complex thing to resolve. I have rebuilt many and have seen what it takes to make them work correctly. Now send me make, model, year and engine type and from there I can help you solve your problem. Thanks, Sea Breeze
Posted on May 30, 2009
co7196
  • 3433 Answers
SOURCE: AC unit blows cold air in the AM and hot air in the afternoon
That is ediculous. He can charge it, leak chk and repair in one trip. I hope he isn't popping you for a service call each time.
Posted on Jun 23, 2009
  • 1249 Answers
SOURCE: Olds aurora 95 ac --
There is probably air or other non-condensible gas in the system. And/or too much refrigerant or stop leak or wet oil. Recover the refrigerant, pull a deep vacuum on the system (using a micron vacuum gauge to verify), and recharge by weight.
If it was mine, I would flush the lines and replace the filter/drier and maybe orifice or expansion valve (if dirty) before recharging. Also, everything that is taken apart or messed with should get a new seal or gasket or o-ring on it when put back together, then check system for leaks before recharging. Better to do it right once than mess with it every spring.
When it is 77 degrees F outside, the air coming from the vent should be much colder than 60 degrees. More like below 50.
Posted on Mar 31, 2014
Unit not working correctly. The unit worked for the winter, few days ago I turn on the AC and noticed that it wasn't cooling like it should.
It's could be the board or a heat relay. See if you have 24 volts on "x2" im assuming, emergency heat when in cool mode if so it's the board. Or unhook black or x2 or your emergency heat from board and run unit in cool. If heat stays on its a relay
Jun 02, 2016 | Heating & Cooling
Heat and ac stopped working in 05 kia sedona
check that the heater control (tap ) is being turned on by the controls.. Have an accredited ac mechanic check the ac system .
Jan 07, 2014 | 2005 Kia Sedona LX
No heat from vents
As per your problem mentioned. There are few solved help links to troubleshoot these problems. Go through the list and Click the link below:----
2000 Toyota Avalon: No heat on Passenger Side?
http://whatisbyme.blogspot.in/2012/05/2000-toyota-avalon-no-heat-on-passenger.html
No heat on Oldsmobile Silhouette?
http://technoanswers.blogspot.in/2012/02/no-heat-on-oldsmobile-silhouette.html
Heater blows cold?
http://schematicsdiagram.blogspot.in/2012/02/heater-blows-cold.html
Heat blows cold on drivers side and hot on passenger side?
http://schematicsdiagram.blogspot.com/2011/12/heat-blows-cold-on-drivers-side-and-hot.html
Hot air on the driver's side vents only?
http://repairhelpcenter.blogspot.com/2012/01/hot-air-on-drivers-side-vents-only.html
Temperature gauge does not move and no heat when heater is ON?
http://technoanswers.blogspot.com/2012/01/temperature-gauge-does-not-move-and-no.html
1992 Toyota Camry: A/C Control light Flashing and A/C not Blowing Cold?
http://technoanswers.blogspot.in/2012/04/1992-toyota-camry-ac-control-light.html
No heat, blower blows only cold?
http://technoanswers.blogspot.in/2012/02/no-heatblower-blows-only-cold.html
Ford F150 Ac only blows through defrost vents?
http://technoanswers.blogspot.com/2012/01/forf-f150-ac-only-blows-through-defrost.html
Dodge A/C come out of defrost vents only?
http://technoanswers.blogspot.com/2012/01/dodge-ac-come-out-of-defrost-vents-only.html
Ac vacuum line on dodge cummins?
http://technoanswers.blogspot.com/2012/01/ac-vacuum-line-on-dodge-cummins.html
Ford ranger AC blows cold through defrost vents instead on cabin vents?
http://technoanswers.blogspot.com/2012/01/ford-ranger-ac-blows-cold-through.html
2005 Chrysler PT Cruiser: A/C Blows Warm?
http://whoisbyme.blogspot.in/2012/06/2005-chrysler-p8t-cruiser-ac-blows-warm.html
2009 Mercury Grand Marquis: A/C blows Cold From Defrost Vent Only?
http://whoisbyme.blogspot.in/2012/06/2009-mercury-grand-marquis-ac-blows.html
AC not blowing through Vents on 2007 Chevy Trailblazer?
http://schematicsdiagram.blogspot.in/2012/04/ac-not-blowing-through-vents-on-2007.html
Passenger side temperature is warm air out of dash vents?
http://schematicsdiagram.blogspot.in/2012/04/passenger-side-temperature-is-warm-air.html
These will help.
Thanks.
Nov 28, 2012 | 2006 Ford Taurus
I have a 2002 Acura RSX that has AC Problem. Blows very cold air, but not all the time. As long as RPM is running at drive speeds, I have cold air. However, at stop lights the air temp goes warm. If I...
your ac compressor is freezing up try not putting it on cold all the way. put thermostat towards the red jus a lil but still on the cold side to see if that helps
Apr 03, 2010 | 2002 Acura RSX
Heater wont blow hot air in my 1998 Lincoln Navigator
the computer that controls the deflector motor are not responding and opening the door for heat, I'm sure you have climate control,check the temp setting sensor to the computer input first
Nov 01, 2009 | 1998 Lincoln Navigator
OVerheating and dumping antifreeze
sounds like you have a fan issue if it over heated while you had ac on and was stopped it would not cool the engine or the condensor try turning the vehicle on turn the ac on with hood open spray the condensor with water hose it is in the very front of the car see if ac starts blowing colder most people overlook the basics.
Jul 01, 2009 | 2004 Kia Sedona
2002 bmw 3 series intermittent ac
Sounds like a compressor problem.
Jun 05, 2009 | 2001 BMW 325
2001 Saturn L200 heat only blows high. A/c out.
Sounds like a possible broken/ripped/disconnected air line (hose) to the compartment.
Mar 18, 2009 | 2001 Saturn L-Series
Heating & Cooling Logo
67 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
