Question about Tablets & eReaders
I have the trio stealth g4 10.1 and my wife has the same thing only it is a v2. She can't download certian apps such as menard's from the play store like i can...how can that be corrected?
MUKHTAR
  • 2017 Answers
SOURCE: can't download any thing from google store
kindly login with your valid account .
Posted on Dec 27, 2012
SOURCE: play store is not downloading apps
try checking your internet connection
try checking and fixing your google account reboot the tablet
Posted on Apr 04, 2014
SOURCE: my iview754tpc 'play store is not downloading apps
check for internet connection propely setup your google account
mushtaq_maho
  • 46 Answers
SOURCE: I have a trio Stealth-10 tablet and when i turn it
you have malware or virus best suggestion is to reset it to factory default assuming it has an android operting system
Posted on Jul 16, 2014
kitty22cat44
  • 48 Answers
SOURCE: I can't download Google play store app after I
search "google play download free" on google. before you download, make sure you enable installations from unknown sorces in settings
Posted on Dec 07, 2014
My trio stealth is new. When I power it on, goes to a screen "@9dual core" and doesn't go any further. Help!
There's a hard reset process on the G2 7" that I have used successfully on several stuck units. It may also work, I've learned, on other models of Trio tablets and other Android-based brands / models as well. It did on a Zeki 7" 8GB that I owned. But.... TRY AT YOUR OWN RISK. Here it is.
(1) PRESS AND HOLD the power button until the tablet shuts off completely.
(NOTE:
if any type of start-up screen comes on, FORGET it: the Tablet must be COMPLETELY powered off for this to have any chance of working.)
(2) PRESS AND HOLD the volume-down button, while simultaneously PRESSING AND HOLDING the power button
This will (hopefully) bring up the Android figurine, along with some kind of rotating-wheel graphic.
(3) Do nothing else but WAIT, until the screen changes to a text-based menu, with about 6 to 8, or more choices.
(4) Use the volume-up and volume-down buttons to navigate between choices, and select (highlight) the choice offering to reset the tablet (to Factory Settings).
(5) Click and release the power button to start the reset operation. Follow and additional prompts to ensure you are selecting the correct next step.
This RESET process will erase ALL your installed apps, as well as delete all your saved photos, music and other user files and preferences (including wallpaper, time-zones, Wi-Fi settings etc. But when it works it will give you back a working Trio. Use your reset Triot carefully: generally, I'll say the Trio machines are good economical alternatives to the perhaps more robustly engineered (and much more expensive) big brand items.
Regarding restoring personal preferences, and earlier installed apps I have no experience whatsoever. However there may be sufficient arguments to backup your personal data either on your home computer or on online "cloud based" services. Do the research, ok?
Happy New Year, 2015 ... & ....Good Luck!
Dec 28, 2014 | Trio 1 - MACHSPEED -STEALTHG210.1 10.1"...
How do I get flash player on my trio stealth
if your device is an android you may have to download and install the flash app or a player app that is capable to play flash files.
Oct 22, 2014 | Tablets & eReaders
I bought a trio stealth G2 tablet, it does not boot up past the second part of the start up.I cant take it back,to k_mart because i dont have the receipt and this was a gift.They dident want to do ev
I would take it back to the Kmart & request to speak to the Boss tell them you got it as a present & explain that its messed up & try to get another one.
Sep 28, 2014 | Mach Speed Trio Stealth G2 Tablet -...
Get my trio stealth to turn on?
By far the most common fault with Android tablets and in many cases there is no fix which is disgraceful...
Its called a Boot loop caused by too many apps memory consumption, os or bootblock corruption - press the reset button (its a small pin hole usually on the back of the tablet) with a pin
If that doesnt work switch on and press the power and up volume buttons
You will be in recovery mode
Select recover system then reboot
You can also load a new os from an sdcard -cyanogenmod - google it.
If that doesnt work then i am afraid you are in deep - you will have to attach to your pc with usb cable , download and run the android dev kit and use the command line to sideload or repair the tablet. You will probably find you can still browse you files but the OS is hosed - Difficult if not impossible to fix without a factory reflash/reload.
Sep 14, 2014 | Mach Speed Trio Stealth G2 8 inch Tablet...
Where do i find an app to upload an external bluetooth keyboard to my trio stealth g2 tablet?
I have not seen this model listed with built in Bluetooth. You could add a USB bluetooth device and it should work. Usb keyboards and mice will work for sure.
Jun 09, 2014 | Mach Speed Trio Stealth G2 8 inch Tablet...
Trio stealth g2 shows my internal storage space as "0", it won't let me download apps, or updates. I have reset my tablet several times (pwr down volume)... erased everything I could. I know my wifi is...
My daughters tablet did the same thing. After we had it for about 2 weeks. Called Trio tech support. Ended up having to send it to them and they sent me a new one.
Mar 17, 2014 | Mach Speed Trio Stealth G2 Tablet -...
Can kindle be install on my mach trtio stealth pro
Go to the android app's store and download the "Kindle" app or any of the Ebook reader app's.But be aware if you are a "Kindle" user you will have to use their app to read your Kindle books.
If the app doesn't work email Kindle for a patch for your tablet.
HTH
Jan 26, 2014 | Mach Speed Trio Stealth Pro 9.7cm 4.0 Trio...
Trying to download, Weather Bug App? Tablet says it's Downloading?
Sometimes the store app gets hung up. Go into Settings > Application or Application Manager. Locate your store app. Usually Play Store. Tab it and clear the data and cache. Restart the tablet and try downloading again.
Dec 08, 2013 | Mach Speed Trio Stealth G2 Tablet -...
Activate bluetooth on stealth g2
Hi Ali.. as far as i know and im pretty sure of this.. trio stealth aka Mach etc.. only has wi fi..no blue tooth. Here is a link with more info
for u.
http://youtu.be/mK-AGDPtoNU
Good luck
Chad man
Oct 26, 2013 | Mach Speed Trio Stealth G2 Tablet -...
Tablets & eReaders Logo
77 people viewed this question
Top Tablets & eReaders Experts
Are you a Tablet and eReader Expert? Answer questions, earn points and help others
