How do I link external speakers to Grundig 32VLC6110C
Is there a headphone jack? I cannot find one
The headphone output will be on the under ridge of the lcd at the front dont see it being at the back
looking at your TV's spec it says its got a jack
so youll need to hunt for it
seems it has 1 scart 2 hdmi and headphone jack
Posted on Dec 09, 2014
Ipad 3 sound garbled
Is there difference between speaker and headphone jacks ports
Not all computer headphone jacks will work with speakers. So, it would appear that your computer is one them. Read the article I've linked.
Jun 05, 2014 | Apple iPad 32 GB WiFi Tablet PC
Headphone jack on my compaq presariocq62 is not working
hi
maybe you have loss in jack connection otherwise check sound setting in volume bar right corner of desktop
Dec 04, 2012 | Compaq Presario 700 470024-192 Notebook
Grundig GU19WDVD10 external speakers
give each speaker it own separate ground
Oct 28, 2012 | Car Audio & Video
The speaker phone on our panasonic KX-T7633 dosn't go loud enough. We are trying to hook up an external speaker, but when we plug it into the headphone jack we just get a buzzing noise. Is there a...
There should be a way to do that. 1st make sure speaker jack is fully inserted. If you still have same problem try normal headphones and see if there still is foreign hum- then if headphones work, check the size of both the jacks to see if there the same- you might just have wrong size jack. If that is not the problem the Impedance(ohm symbol) is probably wrong and the phone doesn't have enough power to drive your speaker.. Use a speaker with same Impedance, you might have to use a speaker with its own power supply to get appropiate volume. You could try your PC external speaker. I hope this has been helpful.
Aug 25, 2011 | Panasonic KX-T7633 Corded Phone
When I plug in my headphones to the tv the external speakers don't turn off and can't hear the tv though my headset. can someone help with the setting
If you enter the analogue settings, you will probably find a setting for headphones and settings for loudspeakers.
You may have to mute the tv speakers whilst the headphone amplifier carries on for you.
Jan 01, 2011 | Grundig Televison & Video
( no sound from speaker) i detached the grundig headphnes from my satellit 800 millenium -- the speaker remained 'silent' --otherwise, the radio appears to be functioning normally -- the radio functions...
it maybe that the cut off switch in the headphone jack has stuck as you place in a jack to the headphone socket there is a small switch that mutes the normal speakers and this should switch back on as you remove the headphones, this may have stuck. you will have to open the back and check the back from inside. try to short the mute and see if that is the problem. maybe squirt a small amount of contact cleanrer spray in the jack hole and insert and remove the headphone jack a few times this may resolve.
I hope this was helpful
Dec 12, 2010 | Grundig Satellit 800 AM/FM/SW Radio
Adding remote control activated ''mute'' to TV headphone jack
Generally when the head phone jack is inserted the speakers will get disconnected automatically.
If you are going to use external amplifier you can try the AV sockets. Opening the TV you may require the special screw drivers some times.
Jul 07, 2010 | Televison & Video
Using headphones
You can get a set of speakers that has a headphone jack on front (it will shut off the speakers when headphones are in) or you can unplug the speakers and plug in the head phones. Some PCs have a red and green jack in front - plug in headphones to the green, you should have the speakers shut off till you unplug. All else fails they make a headphone/mic extender that sits like a hockey puck on the desk, has cables to the mic and speaker jacks on back of the PC and on the puck part has a jack for speakers, mic and headphone - some switched manually by you, some switch when the headphones plug in. If you had posted the model I could see if your machine has front red and green jacks.
Jun 19, 2010 | E-Machines eMachines Desktop PC
Can't mute inbuilt speakers
That is not a software problem.
The headphones/external speakers jack socket has a switch to exclude from audio the internal speakers, when a jack plug is connected.
This is a very simple device and is not software controlled.
The fact that it has gone faulty at the same time you reinstalled the system is a coincidence.
If it does not mute when you insert headphones, all you can do is trying to play with the jack plug , inserting and pulling it out. If this does not unlock the switch, the alternative is having the jack socket replaced by a technician. This is generally an expensive repair, asthe socked is soldered on motherboard.
A cheap alternative to a proper repair is using an external USB to Audio Adapter and mute the internal audicard when using headphones.
Oct 19, 2008 | Computers & Internet
Computers & Internet Logo
35 people viewed this question
David Payne
David Payne
