Question about Yamaha Audio Players & Recorders
My remote works fine except for the volume control to the receiver(HTR5440). How can I set this for response?
Have a RAV206 remote and it works okay except for volume response. How do I adjust remote to correct this? Power and Mute are active. Batteries are new.
Http://usa.yamaha.com/products/audio-visual/av-receivers-amps/htr/htr-5440_black__u/
a good start would be a glance at the owners manual
this will help
perhaps you have a faulty remote
perhaps it got banged and needs the insides soldered like the IR diode at the top end
i see you mention it isnt working
so try another or take the remote to an electronics buddy who can click it open and check for a bad solder or etc...
Posted on Dec 09, 2014
After switching off and on last night the volume and mute on stopped responding on Humax remote. IT is PVR9150T and remote RT531B. TV Remote works fine with volume. Humax remote works fine on all exce
Note that this type of device is designed to be left on at all times, so should not be switched off each night. I suspect that it has some slight corruption in the user-settings, so a factory reset may be required.
Apr 03, 2014 | Humax Televison & Video
I can not control the volume with the remote control
I am going to assume that this is an IR remote. Take your digital camera, I use the one on my phone, aim it at the transmitter on the front and push the volume buttons. You should be able to see rapid flashes but only through the camera. This should at least narrow it down to a remote or tv problem. Let me know what you find. Otherwise, will need to know more about your set up.
Apr 11, 2013 | Audio Players & Recorders
Yamaha rxv 870 - volume does not work from remote(s)
hi i have the same problem. yamaha rx-v870 with a remote control that works perfectly except for the volume up/down. i pressed the buttons for a minute and applied some lemon gunk remover liquid and this helped for a very short period. i am wondering if the problem is with the little motor inside the receiver that rotates the volume knob itself, as opposed to an infrared problem on the transmitter/receiver.
Dec 24, 2012 | Yamaha RX-V870 Receiver
I have a Dish IR. Not sure of the model number. Uses 4 AAA batts. The problem I have is the every function seems to work fine except for the volume control. In order to change volume I have to use the TV...
It is possible that those buttons have failed, but a bit more likely the remote lost the codes for the TV itself... since almost everything the remote controls... is on the DVR. I apologize if I am guessing wrong in assuming other "TV" buttons (like INPUT) don't function either.
To re-program your remote to recognize your TV (like when the tech first set up the system) choose from the following receiver types to find the correct remote control TV codes for your Zenith.
Remote TV Codes for 722/622/612/411/222/211 Receivers
Remote TV Codes for 625/522/512/510/508/501 Receivers
Remote TV Codes for 811/381/322/311/301 Receivers
Aug 29, 2011 | DISH Network IR Remote Control
Where can i find a cheap RemoteControl for my "Yamaha RXV520 Receiver"? it could be also a replica or generic. thanks, Arik
Original $61, copy $39
http://remotes.com/remotes/servlet/rs?v=1&o=c&o=c&a=Search&uid=0&m=rxv520&uuid=A12997127730091
The model forthe remote is RAV206.
If you lurk around eBay and search for "rav206 remote" or "RXV520 remote" and check the "include description' box, you may eventually find one for cheap.
Mar 09, 2011 | Yamaha RX-V520
For RM-YD023, I need to control my Receiver volume while in TV mode. I can control my Sony Receiver while in AMP mode, but cannot change independent volume control so that I can keep the remote in TV mode...
I contacted Sony support for this same concern. Their response was that there is no volume lock option, you must switch back and forth from "TV" to "AMP" :(
Jan 29, 2011 | Sony RM-YD023 Remote Control
Need instructions for Yamaha remote RAV206
This is the instruction manual for the whole receiver that uses that remote. There is no manual for just the remote, but this should be what you are looking for. I imagine you want to know how to use the remote with your receiver that it goes to, correct? The manual is at the end of my answer here...
Please make sure you rate my answer 4 thumbs up, it is extremely important to me. I would be forever grateful if you could do so. If you need more help on this question please just respond to my answer here and I will get right back to you.
http://www2.yamaha.co.jp/manual/pdf/av/english/re/HTR-5460.pdf
Thanks so much, let me know if that's not what you are looking (if that is the case) before rating my answer lower than 4 thumbs please :)
Thanks
Tim
Oct 15, 2010 | Yamaha Televison & Video
Kenwood VR-6070: Broken volume knob; will IR sensor still work?
Looks like you have several faults?
First try to fix the remote:
http://www.instructables.com/id/Repair-your-remote-controls/
May 28, 2009 | Kenwood VR-6070 Receiver
No response from remote
Hi on my ONKYO amp i have to press the receiver button to work most features if you press the volume button and this dose not light up the remote is trying to work something other than the amp,eg if the dvd button lights up it is working your dvd player if you have it set for this.PRESS the receiver button and it should work.
hope this helps.
CABLE GUY.
Jul 12, 2008 | Onkyo TX-NR801 Receiver
159 people viewed this question
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
