Question about Panasonic Televison & Video
My panasonic p50c3b flickers when on analog perfect when on digital
    Top Expert:
  • Panasonic Master
  • 73,710 Answers
Contact the authorized service centre for Panasonic. A firmware update is necessary. Electro help
Posted on Dec 10, 2014
Panasonic com contactinfo
There is no such cable, but can buy a digital to analog converter.
May 24, 2013 | Panasonic TC-P42U1 42 in. Plasma HDTV
Panasonic Viera TH-50PX80A. After lighting strike, inputs do not work.
The set MAY have a hard reset but you would have to call Panasonic to find out.
What happens with lightening strikes is RF gets into the set in two ways--via the power cord (usually a dead set is the result) and via the coax or cable fitting.
It sounds like it was the latter--it may have confused the microprocessor in the set(input issues) so unplugging set and or a box if used (receiver unit also!) may or may not help.
Surge protectors rarely operate quickly enough to stop this and even if the cable feed is protected stray RF can get past that also.
try my suggestions and then call Panasonic.
May 17, 2012 | Televison & Video
How do you re-tune the panasonic DMR E85H DVD Recorder. I have done exactly as it says in the manual and still it does not find any channels? Is it digital?
The tuner in the DMR-58H is a NTSC tuner (analog). Unless you have a low power station in your area, you will need a digital-to-analog converter box to record OTA stations. It can record analog cable without a box as well. (Digital cable will require a box.)
The manual for the DMR-E85H is available from Panasonic here: http://service.us.panasonic.com/OPERMANPDF/DMRE85H.pdf .
I hope this helps.
(at least in my area there is only one station broadcasting an analog signal; it is a low-power transmitter and thus wasn't required to upgrade to digital with the rest of the stations.)
Mar 27, 2012 | Panasonic DMR-E85H DVD Recorder
How do I retune my Panasonic Viera TV?
Hello
To tune your Panasonic Plasma to on air TV channels do the following:
Connect the antenna connection to its antenna in at the back panel.
Automatically searches and adds available channels to the memory.
Select "ANT in"
Select Cable or Antenna Select "Auto"
Select a scanning mode
Auto channel setup
Select "Auto program"
Select "ANT in"
Select "Auto"
Select scanning mode (ALL channels/Analog only/Digital only
Start scanning the channels
Available channels (analog/digital) are automatically set.
All channels: Scans digital and analog channels
Analog only: Scans Analog channels only
Digital only: Scans Digital channels only
Confirm registered channels
If OK is not pressed after selecting "Apply", the channels will not be saved.
The channel will be saved when no operation is performed for 60 seconds and
the "Manual program" menu will also exit automatically.
If you perform scanning more than twice, previously saved channels are erased.
About broadcasting systems
Analog (NTSC): Conventional broadcasting
Digital (ATSC): New programming that allows you to view more channels
featuring high-quality video and sound
[Use "UP ' DOWN ' RIGHT ' LEFT] AND 'OK"] keys to selcet and proceed.
Mar 07, 2011 | Panasonic Viera TH-42PZ80U Plasma TV
Samsung monitor flickers on digital but not analog
1. this may be due to cable select and or cable not being secure at connection point
2.check your instruction manual for proper setup for digital signal to the LCD monitor and the to your video source.
Mar 27, 2010 | Samsung SyncMaster 204B 20.1" LCD Monitor
Rx 2700 dts keeps flickering on and off causing
Your symptom sounds like a poor digital connection. The receiver is probably configured to prefer the digital feed if both digital and analog are present from a given source. That it blinks the 'analog' indicator means it thinks the digital signal is degraded.
I believe you're using HDMI. If your cable box has either optical or coaxial digital outputs, try one or both and proceed from there. You could also certify the health of the receiver input that's failing by connecting another device (your Blu-Ray?) to it to test it out, or simply borrow its cable.
If the input works with another device THAT would indicate a problem upstream and external from the receiver - cable, output of the cable box. Optical cables are more finicky than coaxial and do not tolerate being routed in tight radious bends.
DTS isn't Dolby. Read up on it here - http://en.wikipedia.org/wiki/DTS_(sound_system)
Jan 29, 2010 | Yamaha RX-V2700 Receiver
My samsung R5067W DLP tv is showing green horizontal lines that flicker. If you unplug it and then plug it back in a picture will come on an stay for awhile and then the green flicker horizontal lines...
unfortunately your tv will require an expensive repair, digital and analog boards and possibly the dmd board. Julio milleniumtvsvc@gmail.com
Jul 25, 2009 | Televison & Video
Analog Video transfer to DVD
You need a device called a "Analog To Digital Converter" attached is one such device from Amazon Amazon com MyGica Capit USB Video Capture for Windows Capture Analog Video...
Jun 28, 2017 | Panasonic PV-DV100 Mini DV Digital...
What kind of phone line?
ALL fax machines require an analog phone line. There are no digital fax machines.
Nov 12, 2008 | Panasonic PanaFax UF-8000 Laser Fax
Panasonic nv-rz15
ihave problem with my jvc camcorder,firstly the does not go in itself i have to hold the tape after awhile it sits in but when ipush any button to play rewind etc on screen it says that you needto reinsert &safeguuard is on when its no. will the head cleaner solve the problem or shall i take to repair it.please answer as quick possible thank you. Mrs Bahia
Mar 05, 2007 | Panasonic NV-RZ15 VHS-C Analog Camcorder
Televison & Video Logo
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Jaime Hernandez
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
