Question about Android Cell Phones
How do enable disabled system apps on a kyocera icon plz help me
My phone keeps on displaying this massege:- "unfortunately, the process com.google.process.gapps has stopped." how can I solve it
Hi the gapps in the error refers to Google apps ENABLE THE DOWNLOAD MANAGER..step 1 : tap on apps ..step 2: tap ,& drag the application screen towards the right to access settings ,& then tap on settings icon 3: tap on more 4: tap on application manager under more tab. 5: now tap & drag the application manager screen towards left and access DISABLED application ( note if disabled tab is not available.go TO ALL TAB,) 6,: tap on download manager with Android icon. 7: tap on enable now Download manager is enabled ( disabled should B on screen ) ...8 restart you're device ...good luck
Jun 19, 2016 | Tablets & eReaders
I need to know how to uninstall muliple apps of the same thing
Uninstall, disable, and delete apps You can remove apps from your device if you don't want them anymore or you need to clear memory space. If you uninstall an app you paid for, you can reinstall it later without buying it again.
Uninstall or disable apps
  1. Go to your device's Settings app .
  2. Select Apps or Application manager.
  3. Touch the app you want to uninstall. You may need to swipe right or left to find the app.
  4. Touch Uninstall or Disable.
Uninstall vs. disable
There are two ways to remove apps depending on whether you downloaded the app or if it came preinstalled on your device:
  • Uninstall downloaded apps: If you downloaded an app from Google Play, you can completely remove it from your device.
  • Disable preinstalled apps: Some apps come preinstalled on your device. You can disable these apps, but you can't remove them completely. After an app has been disabled, it will be hidden on your device.
Note: Disabling a system app may cause other apps to misbehave and will delete your associated data for that app.
Mar 01, 2016 | Kyocera Sprint Echo Android Dual Screen...
I have a Kyocera Hydro and my Google play app is stopped. How do I fix it?
oogle play services has stopped - Google Product Forums
productforums.google.com/d/topic/play/ogWU42sBkOw
Google
Sep 10, 2015 - 27 posts - ‎18 authors
Check your apps from Google Play Store > My Apps or Application Manager list. ...My phone details: Kyocera Hydro Vibe model C6725.
Kyocera Phone Apps Crash - FreedomPop Forums
forums.freedompop.com > ... > Kyocera Hydro Icon
Sep 20, 2015 - Hi, @Jorge M. @admin I have 2 Kyocera Hydro Icons, and they both have this issue. ... Ever since I updated the apps/and Google Play services, whenever I open up an .... once I reverted back to the stock version everything stopped crashing. ... And how can I back up my apps/settings if I were to do that? 0. Kyocera Hydro Icon Fix Till Google & Kyocera Give the Proper ...
Nov 16, 2015
Tethering on FP Phones and Google Play Services Crashing ...
Nov 7, 2015
More results from forums.freedompop.com
Google Play Services not Working :( ' Page 2 ' Android Forums
androidforums.com > Android Phones > Kyocera Hydro Vibe
Feb 03, 2016 | Kyocera Cell Phones
How do you retrieve a disable app on Samsung ipad
go to setting than app manager you will find the app their.
Feb 06, 2015 | Samsung Galaxy Tab Tablet PC
What is qmicm on kyocera hydro vibe
QMICM is a debugging program specifically for Kyocera phones, generally used by software developers for debugging. Also QMICM is used when rooting some Kyocera phones.
Nov 25, 2014 | Kyocera Cell Phones
I want allshare cast to stop enabling and updating!
In the AllShare app settings there should be an option to enable and disable the "show icon" in notification bar.
May 10, 2014 | Samsung AllShare Cast Dongle
Every time I try to use freegate it says "Network connection problems" but my wifi is perfectly fine plz plz plz help
click start->run -> enter "command" without quotes-> ipconfig / flush dns-> ipconfig /renew... if this is not helping try disable and re-enable the WLAN adapters (control panel ->network and ...->click the adapter with right clik and disable/ enable)
Oct 13, 2013 | Computers & Internet
How ican unblock fbskins
t all depends on what app you used to get that I use PageRage for my Facebook layouts. If you used this app follow these directions:
To enable or disable from Internet Explorer: In the top menu, go to Tools > ManageAdd-ons > Enable or Disable Add-ons and click Enable or Disable next to either of the two instances of 'PageRage Toolbar'.
To enable or disable from Firefox: In the top menu, go to Tools > Add-ons. Select either of the two instances of 'PageRage Toolbar' and then click Enable or Disable. hope this helps you out goodluck
Mar 18, 2011 | Facebook Social Network
Update problem with symantec antivirus
Close the antivirus program and reopen it. When it isclosed, the icon yellow for norton will not appear on bottom right hand side along with volume icon etc. You may also restart the computer to see id that helps. Right click the Norton icon and see id it says ENABLE AUTOPROTECT or DISABLE AUTOPROTECT. Try enabling.Try the same update after a while. If that does not work, try reinstalling Norton. I get 100s of viruses from 100s of friends and all sorts of things happen to me anti virus etc
but I am told that pretty normal
Dec 13, 2008 | Symantec Norton AntiVirus 2008: Windows
Cell Phones Logo
Top Android Cell Phones Experts
Owen Barnes
Ron Durham
Gregg Errera
Gregg Errera
Level 1 Expert
Are you an Android Cell Phone Expert? Answer questions, earn points and help others
