Question about Vacuums
E2 BLACK POWER NOZZLE WONT COME ON. WHAT COULD BE WRONG WITH IT?
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 139 Answers
Dirty contacts loose connection /wire
Posted on Dec 12, 2014
New belt seems to be too short cant get it on
Is this the belt for the "Power Nozzle"? If so, once you have the bottom plate removed to get at the roller brush. You will be able to carefully pull/pry the roller out. It is one piece with bearing/bushings one each end. They are friction fit (held in by friction - no screws, glue or other fasteners). Remove the roller straight out, slip the belt over the roller and carefully put the roller back in. If it still won't fit, you might want to ensure you have the proper replacement belt.
see this video as an example:
Belt replacement on Rainbow e2 Black Power Nozzle
Aug 12, 2014 | Rainbow E series Canister Wet/Dry Vacuum
There is a black residue coming from the motor in the scent chamber. what could cause that/
Amanda:
The black residue is probably coming from the drive belt that goes from the motor to the beater bar. Lay the machine on it's back, and remove the foot plate (or cover plate for the belt) and check the belt for wear.
Feb 02, 2014 | Filter Queen Canister Vacuum Model 112C...
I have a Rainbow E2 which I purchased in early October. My Power Nozzle is not working right. When I used it before, it pulled, now it barely moves on its own. I cleaned all the hair off of it and it...
Does the brush turn freely when you try to manually turn it?
Does it rotate when the power nozzle motor is on?
If not, it's most likely the belt that turnd the brush has broken. This will result in the brush not rotating, which in turn doesn't provide the pulling action and ease of use it's supposed to have.
If it's a new machine, you need to take it to the nearest Rainbow store for warranty repair. Disassembling yourself will result in the warranty being voided.
Dec 19, 2010 | Rainbow E series Canister Wet/Dry Vacuum
MY RAINBOW VACUUM HAS LOST SUCTION POWER AND i DON'T KNOW WHY
Your Rainbow E series has lost suction power, because you need a new hepa filter, ot your water basin gasket is messed up, or the center motor gasket is messed up or out of position.
Make sure your water basin is not cracked or broken, also.
If you have any more questions let me know. I am a Rainbow seller, and a Rainbow expert also.
Thank you,
Ralph
May 19, 2010 | Rainbow E series Canister Wet/Dry Vacuum
Riccar 1700 power nozzle wont turn on
Make sure the 'Power brush' switch on the contol panel on the hose is depressed. Check the circuit breaker on the power nozzle; it will either be a button or a breaker that looks like a rocker switch, try to reset it.
Is the power nozzle motor running but the brush just isn't turning? If so you may have a broken belt. Not a likely solution since the belt is a lifetime belt, but still remotely possible.
Apr 23, 2009 | Riccar RC1100 Compact Vacuum
Vacuums Logo
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
