Question about Health & Beauty
The control panel flashes its lights and chair wont move
Jazzy z11 hand control lights up,hut fare lashes the lights and wont move,normally that means the breaks are on or its plugged in
  • 27 Answers
There are a couple of possibilities. If some of the LEDs are flashing at the same time, it's a trouble code. You need to count the LEDs that flash (it's between one and ten) and refer to the troubleshooting guide here:
Pride Mobility Products Corp Basic Troubleshooting Instructions
If the lights are rippling, the controller may be locked. Locking and unlocking instructions are linked from that page too.
IIRC, the Z11 comes with a VSI controller. Use the link to the Jet 7. It has the VSI too.
Posted on Dec 24, 2014
  • 3 Answers
When my Pronto did this, it was diagnosed as a failure of the controller. Replacement was about $1200. Good Luck.
Posted on Dec 22, 2014
  • 692 Answers
SOURCE: jazzy 1121 power chair won't charge when plug in
you have either bad batteries or a bad charger or the charger might have come unplugged at the controller or power module. When you have the charger plugged in and you turn on the joystick the lights on the joystick should ripple to indicate the charger is plugged in. If you don't see this ripple then either the charger is bad or disconnected. Trace the charger cable from the rear of the chair (you have to remove the seat and shroud to do this) to the front module and make sure that the cable is plugged in. Hope this helps
Posted on Oct 23, 2010
dromtonpa
  • 40 Answers
SOURCE: lights just flash on controller and wont move jet 3 wheel chair
Do they flash in series? Like ten flashes then a pause then ten flashes?
Posted on Mar 30, 2009
SOURCE: lights on hand control flash off and on and chair will not operat
There is a series of diagnostic flash codes associated with the controller. The diagnosis depends on which color and how many lights are flashing. If you post the combination, I can help you. Or you can download the Basic Operation Instructions of the Pilot Controller from the Pride website. The codes are listed on page two on the troubleshooting instructions.
Posted on Apr 14, 2009
  • 4 Answers
SOURCE: my jazzy 1115 joystick controller flashing and the
look on jazzy web site for lockout procedures.I have seen people accidentally engage the lockout thru the joystick.It is a simple procedure
Posted on Nov 21, 2009
  • 5 Answers
SOURCE: Jazzy 1121 power chair won't go
I find a lot of the controller Problems are caused by the cable running from the joy stick down to the controller gets caught on something or rubbed against something and one or more tiny wires inside are broken ... If I find a spot on the cable that is worn through, that's where I start .. Open up the insulation and check the tiny wires .. fine the broken one and repair it .. usually that solves the problem and saves you a couple hundred for the cable
Posted on Oct 08, 2011
Jazzy 600 powewr chair intermittion operation
The small click noise is the parking brake releasing to allow you to drive. the flashing is called a flash code that will give you an idea of what is wrong. count the amount of lights flashing this would indicate the problem. Post the amount of lights flashing and some could give you the meaning of the code.
Apr 28, 2016 | Pride Mobility Jazzy 600 Powered...
What does a flashing red light on a jazzy power chair mean and it wont move
Need to count the number of flashes and consult your user manual. There is usually a section there that explains Fault or Flash Codes and will usually lead you to the problem.
If your still struggling please just message back
Thanks Dave
Nov 09, 2014 | Pride Jazzy Select Power Chair
Jazzy 1107 power chair won't move
3 flashes indicate that there is a short circuit to the left motor and battery connection. Check wiring and connections
Jun 14, 2013 | Pride Jazzy 1113 ATS Indoor Power...
Blinking yellow wrench light on pride jazzy 614 HD
Your version has a Dynamic Controls model controller and joystick.
Unplug the charger and engage the motor/brake lever so the chair is no longer in free-wheel mode (con't push by hand)
Turn the chair off, wait 5 seconds, turn the chair back.
If chair still does not run and your wrench is flashing you have a problem. Count the wrench flashes - the flash count indicates the error detected. 3, 4, 5, and 6 flashes indicate and error with the motors.
3=Left motor fault
4=Right motor fault
5=Left brake fault (may not be engaged)
6=Right brake fault (may not be engaged)
Any other fault code usually means the electronics or wiring is bad and not worth fixing.
Jan 06, 2013 | Pride Jazzy 614 Hd JAZZY 614HD
My hand controler on my jazzy 1120 2000 keeps blink and I can not get the chair to move the batteries are good
GAdams You need to count the number of flashes. The number of flashes will give you the flash code or error code. IE: 3 flashes pause 3 flashes pause etc. = left motor short If you have your owners manual it should list the flash codes and what they mean for your chair. If not you can contact Pride Mobility @ 1-800-800-8586 and ask for Tech Support. If medicare paid for your chair the they will pay most of the repair cost. Contact the provider where you got your chair to see if they can repair it or refer you to a service Company that can. Hope this helps
Oct 05, 2010 | Pride Mobility Products Used Jazzy...
Wont move yellow lights ,flashing
The number of lights that are blinking indicate what the problem is. Visit this site to locate the type on controller on your power chair and you will be able to see that the blinking lights mean:
http://www.pgdt.com/scenter/diagnostics/diagvsi.html
Try to reset your manual brake release as this is a common problem.
If you continue to have a problem, contact your manufacturer or dealer for service. If your insurance purchased they power chair for you, they may also cover the cost of repairs.
Sep 10, 2010 | Pride Jazzy 1103 Ultra Standard Power...
When turning power it makes a clicking sound but does not power up. battery charger has a red and green light on. When plugged in and turned on it flashes 8 times. I checked the power control connection,...
The chair will not move if the charger is plugged in. The flashes are normal with the charger plugged into the chair. The lights on the charger mean that the batteries have been fully charged. Red and yellow lights mean charging. After you unplug the charger from the chair (if off-baord charger, turn charger off or unplug from the wall) then unplug from joystick. after plug is removed from joystick press the on button and all the battery lights should be lit and when you move the joystick forward you will hear the electric bake release and the chair should move forward etc Hope this helps
Aug 10, 2010 | Pride Jazzy Select 6 Indoor Power...
All lights are flashing, and chair won't move when I try to use
The flash codes for the VSI controller used on this chair are located here:
These will tell you what the fault is; repost with more information.
May 23, 2010 | Pride Jazzy 1113 ATS Indoor Power...
Jazzy 115 will not move. Controller has 3 red and one amber bar flashing
Pride doesn't make a Jazzy 115. Please check your chair and owners manual to get the correct model so we can help. How old is the chair? The flash codes you are getting depend on the model, year it was born, and the tkype of controller installed.
Also, the flash code should be literally, flashes. 2 lights flash twice, stop, then go again, etc. They all mean something, so repost with more info please.
Jul 07, 2009 | Electric Jazzy 1115 Power Wheelchair
Lights on hand control flash off and on and chair will not operat
Apr 10, 2009 | Pride Jazzy 1103 Ultra Standard Power...
Health & Beauty Logo
267 people viewed this question
Top Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you a Health and Beauty Expert? Answer questions, earn points and help others
