Question about Cycling
How do I adjust the brake levers on the Carrera kraken
2 Suggested Answers
  • 67 Answers
SOURCE: my carrera kraken crank arm keeps hitting the
Bent maybe? Use an allen wrench or the appropriate tool and loosen the bolt near the end near the shaft and use a wide blade screwdriver to slide the crank out a little on the shaft it has splines on it. This will give it a little room without hitting anymore.
Posted on Sep 22, 2009
Adjust handbrake in Hyundai tucson
The adjustment is made at the handle under the console:
ADJUSTMENT OF PARKING BRAKE STROKE
1.Pull the brake lever with a force of approx. 196 N (20 kg, 44 lbs.) and check the number of clicks.
Parking brake lever stroke (Standard value) : 8 clicks
2.If the number of notches is not the standard value, adjust the cable length with the adjusting nut on the equalizer.
3.The indicator light will go out when the brake lever is fully released, and will light up with the lever pulled one notch. If it does not operate properly, replace it.
4.After the adjustment, check that the rear brakes do not drag with the parking brake lever released.
Mar 05, 2015 | 2007 Hyundai Tucson Limited
Brake lights flicker when brakes are applied. Seem to work when clutch is engaged but intermittent when clutch car is in neutral. Any ideas?
check wiring and shorts around clutch lever, make sure its not pushing another wire onto brake light switch?
Nov 22, 2013 | 2001 Porsche 911 Carrera
Porsche parking brake light and convertible top
you should be able to get to the ebrake switch by the e brake lever. If you can, to get top up you can cross the two wires going to the switch together and get the top up normally with switch. If this turns the parking brake indicator on on the dash, then order yourself a new switch and replace.
Mar 18, 2012 | 2001 Porsche 911 Carrera
Remove replace rear brakes on ford t bird 1996
1989-97 Vehicles Drum Brakes (Let me know if you need the Disc Brake Instructions)
  1. Raise and safely support the vehicle.
  2. Remove the rear wheel and tire assemblies, then remove the brake drum.
    Fig. 4: View of the drum brake assembly with the drum removed
    Fig. 5: Use a commercially available brake spray to clean the
    components before removal
  3. Install Brake Cylinder Clamp D81L-1103-B or equivalent, over the ends of the
    rear wheel cylinder.
  4. Disconnect the parking brake cable from the parking brake lever.
    Fig. 6: Detach the parking brake cable and conduit from the
    parking brake lever
  5. Remove the 2 brake shoe hold-down retainers, springs and pins.
  6. Spread the brake shoes over the piston shoe guide slots. Lift the brake
    shoes, springs and adjuster off the backing plate as an assembly. Be careful not
    to bend the adjusting lever.
    Fig. 7: Lift the brake shoes, springs and adjuster off the
  7. Remove the adjuster spring. To separate the shoes, remove the retracting
    springs.
  8. Remove the parking brake lever retaining clip and spring washer. Remove the
    lever from the pin.
    Fig. 8: Drum brake components - 1995 vehicle shown
    Fig. 9: Exploded view of the drum brake components, removed
    from the vehicle
    To install:
  9. Apply a light coating of caliper slide grease to the backing plate brake
    shoe contact areas.
  10. Apply a light coat of lubricant to the threaded areas of the adjuster screw
    and socket. Assemble the brake adjuster with the stainless steel washer. Turn
    the socket all the way down on the screw, then back off 1?2 turn.
  11. Install the parking brake lever to the trailing shoe with the spring washer
    and a new retaining clip. Crimp the clip to securely retain the lever.
  12. Position the trailing shoe on the backing plate and attach the parking brake
    cable. Position the leading shoe on the backing plate and attach the lower
    retracting spring to the brake shoes.
  13. Install the adjuster assembly to the slots in the brake shoes. The socket
    end must fit into the wider slot in the leading shoe. The slot in the adjuster
    nut must fit into the slots in the trailing shoe and parking brake lever.
    Fig. 10: Install the adjuster assembly in the slots in the
    brake shoes
  14. Install the adjuster lever on the pin on the leading shoe and to the slot in
    the adjuster socket.
  15. Install the upper retracting spring in the slot on the trailing shoe and the
    slot in the adjuster lever. The adjuster lever should contact the star and
    adjuster assembly.
  16. Install the brake shoe anchor pins, springs and retainers. Remove the brake
    cylinder clamp tool
  17. Install the brake drum, wheel and tire assemblies and lower the vehicle.
  18. Apply the brakes several times while backing up the vehicle. After each
    stop, the vehicle must be moved forward.
Oct 07, 2010 | 1996 Ford Thunderbird LX
How to installing brake shoes on back ?
First you have to compress the parking brake cable spring and attach the parking brake lever.
Clean and lubricate the brake backing plate.
Use silicon Brake Caliper Grease and Dielectric Compound.
Then,
install the rear brake shoes and linings:
1) position the rear brake shoes and linings
2) position the parking brake lever
3) install the brake shoe hold-down spring pins and the brake shoe hold-down springs.
Install the parking brake strut
1. install the parkig brake link spring on the parking brake strut
2. install the parking brake strut
3. Install the brake shoe anchor ping guide plate.
Install the short brake shoe retracting spring
1. Place the brake shoe adjusting lever cable over the anchor pin, with crimped side in
2. Install the short brake shoe retracting spring
Note: Make sure the brake shoe adjusting lever cable is positioned in the cable guide groove
Install the long brake shoe retracting
1. install the cable guide
2. position the brake shoe adjusting lever cable in the cable guide groove
3. install the long brake shoe retracting spring
Note: to prevent incorrect installation, teh socket of each brake adjuster screw is stamped R or L
Assemble the brake adjuster screw assembly.
1. apply silicone brake caliper grease and dielectric compound
2. install the brake adjuster screw into the brake show adjusting screw nut to the end of the threads and then loosen one half turn
3. install the brake shoe adjusting screw socket on the brake shoe adjusting screw nut.
Install the brake adjuster screw assembly
1. Position the brake adjuster screw assembly
2. Install the brake shoe adjusting screw spring
3. Position the brake shoe adjusting lever cable
4. Position the adjusting lever return spring and the brake shoe adjusting lever
5. Hook the brake shoe adjusting lever cable to the brake shoe adjusting lever.
Test the operation of the automatic self-adjuster
1. Pull the brake shoe adjusting lever cable and check that the brake shoe adjusting lever rotates the brake shoe adjuster assembly
2. Release the brake shoe adjusting lever cable and check that the brake shoe adjusting lever advances to the next notch on the brake shoe adjusting screw nut.
Adjust the brakes.
Install the brake drum.
Thats it
Sep 10, 2010 | 1998 Ford Ranger SuperCab
My carrera kraken crank arm keeps hitting the frame ?
Sep 22, 2009 | Cycling
Change drum brakes
Brake Shoe: Service and Repair
REMOVAL
1. Raise vehicle and remove rear wheels.
2. Remove and discard spring nuts securing drums to wheel studs.
3. Remove brake drums.
NOTE: If drums prove difficult to remove, retract brake shoes. Remove access plug at the rear of backing plate and back off adjuster screw with
brake tool and screwdriver.
4. Remove U-clip and washer securing adjuster cable to parking brake lever.
5. Remove primary and secondary return springs from anchor pin with brake spring pliers.
6. Remove hold-down springs, retainers and pins with standard retaining spring tool.
7. Install spring clamps on wheel cylinders to hold pistons in place.
8. Remove adjuster lever, adjuster screw and spring.
9. Remove adjuster cable and cable guide.
10. Remove brake shoes and parking brake strut.
11. Disconnect cable from parking brake lever and remove lever.
INSTALLATION
1. Clean support plate with brake cleaner.
2. If new drums are being installed, remove protective coating with carburetor cleaner or brake cleaner.
3. Clean and lubricate anchor pin with light coat of Mopar multi-mileage grease.
4. Apply multi-purpose grease to brake shoe contact surfaces of support plate.
5. Lubricate adjuster screw threads and pivot with spray lube.
6. Attach parking brake lever to secondary brake shoe. Use new washer and U-clip to secure lever.
7. Remove wheel cylinder clamps.
8. Attach parking brake cable to lever.
9. Install brake shoes on support plate. Secure shoes with new hold-down springs, pins and retainers.
10. Install parking brake strut and spring.
11. Install guide plate and adjuster cable on anchor pin.
12. Install primary and secondary return springs.
13. Install adjuster cable guide on secondary shoe.
14. Lubricate and assemble adjuster screw.
15. Install adjuster screw, spring and lever and connect to adjuster cable.
16. Adjust shoes to drum.
17. Install wheel/tire assemblies and lower vehicle.
18. Verify firm brake pedal before moving vehicle.
Aug 12, 2009 | 1997 Jeep Cherokee Country
I need a schematic for the rear brakes on an F150 super cab with 4.6L automatic trans 4wheel drive
Drum, Rear Brake System Standard Rear Brake
Item Part Number Description 1 2069 Brake Shoe Hold-Down Spring Pin 2 — Rear Wheel Cylinder Retaining Bolt (2 Req'd) 3 — Washer (2 Req'd) 4 — Anchor Pin (Part of 2211) 5 — Wheel Cylinder 6 2028 Brake Shoe Anchor Pin Guide Plate 7 2A637 Parking Brake Lever 8 2296 Brake Shoe Retracting Spring (Short) 9 2296 Brake Shoe Retracting Spring (Long) 10 2200 Rear Brake Shoe and Lining (Secondary) 11 — Washer 12 2106 Parking Brake Lever Pin Retainer 13 — Brake Shoe Adjusting Lever Cable Guide 14 2A642 Primary Brake Shoe Parking Brake Lever Link 15 2A601 Parking Brake Link Spring 16 2068 Brake Shoe Hold-Down Spring 17 2A176 Brake Shoe Adjusting Lever 18 2048 Brake Shoe Adjusting Screw Socket 19 2047 Brake Shoe Adjusting Screw Nut 20 2041 Brake Adjusting Screw 21 2049 Brake Shoe Adjusting Screw Spring 22 2200 Rear Brake Shoe and Lining (Primary) 23 2A178 Brake Shoe Adjusting Lever Cable 24 2211 Brake Backing Plate
Heavy Duty Rear Brake
Item Part Number Description 1 — Rear Wheel Cylinder Retaining Bolt 2 00538 Lock Nut 3 2212 Rear Brake Backing Plate 4 2262 Rear Wheel Cylinder 5 2A642 Primary Brake Shoe Parking Brake Lever Link 6 2A601 Parking Brake Link Spring 7 2A637 Parking Brake Lever 8 2106 Parking Brake Lever Pin Retainer 9 — Parking Brake Lever Bolt 10 — Secondary Shoe Assembly 11 2A179 Brake Shoe Adjusting Lever Cable Guide 12 2068 Brake Shoe Hold-Down Spring 13 — Adjusting Lever Pin 14 — Adjusting Lever Return Spring 15 2A176 Brake Shoe Adjusting Lever 16 2047 Brake Shoe Adjusting Screw Nut 17 2049 Brake Shoe Adjusting Screw Spring 18 2041 Brake Adjuster Screw 19 — Primary Shoe Assembly 20 2068 Brake Shoe Hold-Down Spring 21 2200 Rear Brake Shoe and Lining 22 2035 Brake Shoe Retracting Spring 23 2A178 Brake Shoe Adjusting Lever Cable 24 2092 Brake Adjusting Hole Cover 25 2069 Brake Shoe Hold-Down Spring Pin
The rear drum brakes:
  • Have internal shoes that expand against the brake drum (1126).
  • Are a single-anchor type.
  • Are actuated by one rear wheel cylinder (2262).
  • Have two pistons in the rear wheel cylinder (2261). One exerts force against the upper end of the primary shoe; the other exerts force against the upper end of the secondary shoe.
  • Adjust rear brake shoes and linings (2200) automatically.
  • Need manual brake adjustment if the adjusters are not operating properly or after the rear brake shoes and linings have been replaced.
When the brake pedal is applied, hydraulic fluid pressure forces the pistons in the rear wheel cylinder outward, moving the rear brake shoes and linings against the brake drum.
The rear drum brake system includes the parking brake mechanism. Refer to Section 206-05 .
Apr 04, 2009 | 1997 Ford F150 Regular Cab
Tomb raider Underworld-Can't go through kraken
You need to move all of the gears (three in total I think) in order to release the Kraken. Then you have to make your way back to the top and shoot the two retaining chains that hold the object above the Kraken's head. It will drop and strike the creature sending it to the bottom of the water. Then finally, at the bottom of the room there is a final gear-crank that opens the door to allow you to pass.
Hope this helps!
OpenSource13
Apr 03, 2009 | Eidos Interactive Tomb Raider Underworld
HOOD RELEASE
try getting another person to push hood down whilst you pull the release lever if this does not work locate cable behind puller handle and use pliers to pull just a little more then when opened be sure to adjust cable a little tighter
Aug 03, 2008 | 1999 Porsche 911 Carrera
Cycling Logo
158 people viewed this question
Top Cycling Experts
Michial Gueffroy
Andrew Taylor
Andrew Taylor
Are you a Cycling Expert? Answer questions, earn points and help others
