Not spinning machine is washing and emptying and rotating at slow speed. Will not enter into spin cycle
The motor brushes need replaced
because they are worn
you can type your model number into ebay and buy a set
its an easy job to change them and you tube have some nice videos just type how to change motor brushes on a washing machine look at a few of the tutorials and then go for it
youll do no harm and save a few quid
but if you dont feel like it then ask a pal who knows
or buy in someone too do it
getting them the part and just pay them too fit it
and avoid getting ripped off... should cost no more than £60 max for the service
Posted on Dec 09, 2014
Spin speed is slow
call the technician as the program is not progressing to high spin after the rinse cycle
Jan 21, 2017 | Speed Washing Machines
WFS1073DD front load WASHING MACHINE Everything works but will not spin fast enough to spin the water out. It spins very slow
Early automatic washers used a motor with multiple windings to provide the various speeds required by different parts of each wash programme. Modern washers use an entirely different sort of motor and the speeds are selected and controlled electronically with feedback to ensure the speed is correct.
I suspect the problem is the electronics - the part of the programmer and controller that regulates the motor speed but you should check the motor and motor brushes, the drive belt and all electrical connections as a matter of best practice before you spend money...
Aug 13, 2017 | Washing Machines
WSM2480 Clothes Still Wet After Slow Spin Cycle
It's possible that the tub didn't drain properly in the allotted time and the remaining water is slowing your drum from coming to maximum extraction speed.
Jan 10, 2014 | GE WSM2420D Unitized Spacemaker Washer /...
Tub not spinning with load
I would suspect a faulty motor control board. not much you can do to test it unfortunately, aside to replacing it and see if that fixes the problem, but definitely the best guess. Also known as a speed board.
Apr 07, 2010 | Frigidaire GLTF1240A Front Load Washer
Washer doesn't spin
Hello skull1829 ,
Was the Clutch/One-way roller bearing changed out for dc/UC errors in your FAV6800AW/FAV9800AW?
If you start a Spin Only Cycle with an empty wash basket will the wash basket spin up CCW and complete the cycle? Lift the washer top from the base a few inches to observe the wash basket CCW rotation in spin cycle. If the clutch spring is broken or end pins of spring aren't seated the tumblers will rotate and the wash basket will rotate slowly CCW.
IF the wash basket won't spin up can you pull the front cover off and insure the motor will rotate the clutch pulley CCW in a Spin Only Cycle? Let’s try these few basic tests and get some feedback for troubleshooting.
Rich
Jun 13, 2009 | Maytag Neptune FAV6800AW Top Load Washer
Washer won't spin fast, only slow
tyr removing the lower acees panel from the uint , ther is a "button trap" located there to catch debris from entering pump assy, chances are its clogged and if it cant drain all the water it wont go into high speed spin, also you MUST use an HE detergent. HE detergent specifically designed for front loading washers
Apr 28, 2008 | Kenmore 44102 Front Load Washer
Kenmore Washing machine spins slow
If it has a speed selection switch than this switch is likely to be bad, other than that are you sure that It once has high spin in the cycle you are using??
Jan 14, 2008 | Washing Machines
Washing Machines Logo
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
