Question about Haynes 1993 Isuzu Amigo Manual
I am stuck i got my dash off now i cant find out how to get the heater core out for my 93 isuzu amigo
I am looking at how I get the heater box out. I only see three bolts holding it in but don't know how to get the box out now please help.
    Scholar:
  • 103 Answers
Do a search on google for "heater core 93 isuzu amigo" look at the images - there are several exploded views on exactly how to do that.
Posted on Dec 10, 2014
I need heater hoses diagram for 93 Isuzu amigo 2.3. My system was bypassed & I need help
People rarely bypass the heater core unless it's either cracked or clogged beyond fixing!
Heater cores are usually behind the dashboard and it's about an 6_10 hour job if you know what you're doing.
Mechanics charge around $750 to $1200 to replace a heater core.
Dec 21, 2015 | Isuzu Cars & Trucks
Where do my heater hoses connect on 93 Isuzu amigo 2.3
you lost them. or just fell off?
if you fill the system with just water
the 2 places it leaks horribly is it.
HOW DO YOU REMOVE THE HEATER CORE IN A 1992 ISUZU TROOPER
You must remove the complete heater core and a/c evaporator from under the dash. It goes from the center of the dash to the passanger side of the dash. You have to remove the glove box, remove the heater hoses, vac. lines to the controlers. Bolts that hold the unit to the firewall. Also must remove small vents at bottom of the dash. Would be much easier if you would just tell me what area you are having problems with. After you are done you will have to recharge your a/c system. This is not a job for a novice.
Oct 21, 2014 | 1992 Isuzu Trooper
1993 ford ranger
Any chance you got an air bubble in the system? Try loosing the return hose from the heater and make sure your getting fluid through the heater core.
Feb 24, 2014 | Cars & Trucks
1999 isuzu amigo water in passenger and driver floorboard no antifreeze smell at all.
this sounds like a build up of condensation (water) possibly in your ac/heat ducting or possibly in the plastic casings under the dash that house some of the heating and cooling components. cold ac components close to warm or hot heating components will lead to water build up this is why there should be a drain tube for the plastic housing under the dash board that leads to the outside of the vehicle. this drain tube may be clogged or may be disconnected and not draining to the outside but instead its allowing the water to fall into the area under your dash board. FYI you can sometimes see these drain tubes drip water on cars that use their air conditioner a lot, it looks like the car is leaking water from the bottom but it's just the water draining away from cool air conditioner lines on a hot day and draining properly to the outside of the car and not on the floor inside.
Feb 08, 2012 | 1993 Isuzu Amigo
Where is the heater core located at on the 93 caprice ,is it behind the glove box ,or do I have to remove the whole dash
WOW, sorry it has taken so long for someone to see and respond to your question. You've probably figured it out on your own by now, but if not, here is your answer. The heater core in your Caprice is located behind the glove box. To gain access, you have to remove the lower right dash insulator panel (below the glove box) and than the glove box. Remove any vaccuum lines ( mark their locations.) Then remove the lower instrument panel brace and then the heater core cover. Remove the heater core clamp bolt and clamp. Disconnect the heater hoses from the heater core on the left hand side of the engine compartment( looking at the engine from the front of the car.) Then remove the heater core.
Feb 23, 2011 | 1993 Chevrolet Caprice
Have 93 Amigo replaced O2 sensor but still will
check for a blocked catalytic convertor, disconect the exhaust from the manifold or the conection to the convertor and start run the vhicle and see if it makes a difference if so replace unit, if not, then check the IAC sensor and mass air sensor
Oct 28, 2009 | 1993 Isuzu Amigo
Removing heater core from a 93 chevrolet blazer s-10 .how do i remove it and install it back
heater core under dash passenger side . Remove 2 hoses on fire wall carefully then take cover off the heater box & remove heater core. be careful not always an easy job!
Sep 11, 2009 | 1993 Chevrolet S-10 Blazer
Cant get heat in the cab
Make sure that you have 2 heater hoses going into the dash. These are 5/8" hoses coming from the water pump and going into the top of the engine. The 2 hoses go through the firewall into the heater core. If you don't have the 2 hoses going to the heater core, the previous owner may have it routing itself back to the engine. It the hoses are routed back to the engine, there's a chance of the heater core being bad as well and this is why it's by-passed.
Nov 09, 2008 | 1993 Ford Econoline
Haynes 1993 Isuzu Amigo Manual Logo
54 people viewed this question
Top Haynes Heating & Cooling Experts
Mike
Lawrence Oravetz
SimplyNo
Are you a Haynes Heating and Cooling Expert? Answer questions, earn points and help others
