Need a ignitor for York propane furnace model #P2UDD20P1331C
    New Friend:
  • 9 Answers
Get model and serial # go to act parts. Dealer
Posted on Dec 09, 2014
I need to find replacement parts for a Magic Chef propane furnace model EG6E80. How can I cross reference them with other brands?
good luck, what parts do u need, most of them can be re placed with other furnace name brands, like ignitor, blower motor, gas valve, pressure switch, ignitor board, transformer, ventor motor, they have replacement for all those parts, remember most companies use the same parts
Dec 16, 2015 | Heating & Cooling
Looking for a hot surface ignitor part number. York propane furnace model P2UDD20P13301C. I do not have the old ignitor.
Go to a local heating and air conditioning wholesale parts supply and sales point and they should be able to get you an OEM or an aftermarket part OR go to a rheem rudd distributor or supply and service point
Dec 10, 2014 | FACTORY AC PARTS Hot Surface Ignitor...
Need a ignitor part number for York propane furnace model # p2udd20p13301c
Found it on repairclinic website:
Manufacturer Number S1-47320937001
Dec 09, 2014 | York Tools & Hardware - Others
Can I convert a propane furnace to electric?
Actually yes! You can install electric elements in the plenum that turn on by your thermostat. The convection blower from the furnace can be used. You can also install a heat pump system that will give you both heat and air conditioning.
Feb 10, 2010 | Heating & Cooling
York Diamond 80 furnace (propane conversion), about 1998 model. Solid Ignitor comes on, but no flame. Main fan works for about 90 seconds then cuts off. Fan only switch on thermostat does the same, fan...
Check for 24 volts across the two terminals on the gas valve when the ignitor glows. If yes, bad gas valve or blockage in the gas train. If no, bad ignitor or circuit board. Even if the ignitor glows, it still may be bad and not sending the proper signal to the board. If you jump the R and G terminals on the circuit board, does the fan still only run for 90 seconds? If so I would say replace the board.
Dec 28, 2009 | Heating & Cooling
York furnace model p2mpd12h06401f flashes 4 times for trouble code does'nt have code list inductor motor comes on but ignitor does'nt come on
Check pressure switch for inducer motor. If switch closes, check for crack in ignitor. If gas valve opens and you can hear/smell gas, the ignitor is bad probably. If pressure switch isn't closed you need to check for blocked vent/chimney/heatexchangers.
Dec 18, 2009 | York Furnace Draft Inducer Blower Fasco #...
90 + gas furnace. inducer full of water
need help with gas furnace put in new presure switch and it worked for a while now i have to blow into it to get it to turn on ignitor .
Dec 05, 2009 | York Furnace Draft Inducer Blower Fasco #...
Our york furnace is not Lighting
you may have a bad ignitor, that would be the simplest thing, but without more info thats all i got
Nov 24, 2009 | Heating & Cooling
Heating & Cooling Logo
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
