Question about Saws
I keep geting crookked cuts, i've checked the guides and pivot bearing all are good . Still slanted cuts. What could this be?
  • 1,511 Answers
There should be an Alignment Adjustment setting. Check the guide, band alignment, slot adjustments. The base plate alignment must be horizontal. Lay a small LEVEL on the base tray to see if it is tilted somewhat?
Posted on Dec 09, 2014
2004 ram 1500 wont start
Could be coils,fuel filter,how old spark plugs.
Apr 24, 2013 | 2004 Dodge Ram 1500
2000 Pontiac Grand Prix GT, front end shakes at 35-40mph?
You have worn front end parts or the tires have a separated cord in them.
Feb 28, 2017 | 2000 Pontiac Grand Prix GT
My 1199vsr is not getting power
check motor brush maybe stuck in dirt
or power cord conductor cut
Nov 20, 2012 | Bosch 1199VSR 8.5 Amp 1/2 Inch Hammer...
Hit pothole and now tire makes clicking noise and tire slants inward
If you feel that you've hit the hole that hard, you should have the wheel and suspension checked by a professional. The strut or control arm may be bent and in need of replacement, but that's only if you've really hammered it.
May 21, 2012 | 1992 Saturn SL1
Front c/v axle will not come out of the hub/bearing assembly...need help!!!
I have had them so stuck that I have had to pull the whole spindle off with the axle still attached.....be prepared to buy a new axle and probobly a new hub and bearing assembly....when out try more heat....I had to borrow a torch last time it happened to me on a Stratus....ended up having to almost cut it out with torch....a new axle will have a smaller core charge than a reman. one if you ruin the axle....and all that pounding cant be good for the bearing/hub assembly...good luck...Lee
Feb 19, 2012 | Cars & Trucks
I have purchased Poulon pro 42cc 18 inch chainsaw. I am extremely satisfied with my chainsaw until now. I have only owned it for about two months. I only used it maybe 10 times for easy tasks. my chainsaw...
The chain needs sharpened or replaced. You can purchase the tools from any hardware store, and sharpen the chain yourself in about 15 minutes. Don't worry, your saw is just fine!
Sep 25, 2011 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
05 deuce, front end shakes, think its neck bearings? I put lots of grease in fitting, it took quite a bit, think it might have been dry. How do I change neck bearings?
There's a lot of things that I'd check before I started tearing into the steering head of the bike. Have you had your front wheel balanced and the bearings checked in it? Is the tire seated properly on the wheel? There's more to a front suspension system than merely changing the bearings out. Unless you've been using a pressure washer on the bike, odds are nothing is wrong with the bearings. I've restored many bikes built in the 60's and never found a bad set of steering head bearings and they didn't have grease fittings on them. The tension of the steering head bearings have a particular setting on them. Called the "Fall-Away" setting, it is how far the front end will turn before it "falls" all the way to the fork stops. At least the earlier bikes had this. Since I've never had to mess with the steering head of a bike as new as yours I can't tell you how to change the bearings. But, you can got to http://www.bikebandit.com and look up the suspension system on your bike to get an exploded view.
Good Luck
Steve
Aug 15, 2011 | 2004 Harley Davidson FXSTD - FXSTDI...
My saw is not moving up and down smoothly(jamming)tight
First off, blow out the saw completely with compressed air to remove any debris that may be lodged in the mechanism. While doing so, pivot the table back and forth to be sure you reach into all crevices. Then try spraying the hinge area with silicone lubricant or WD40 and working the saw up and down to work the lube into the mechanism. Even though the bearings are sealed this can alleviate friction, and periodic maintenance with silicone spray will make it more of a joy to use.
If that doesn't seem to help, here is a link to a parts breakdown to guide you in examining the possible source of the problem. Check to ensure that the main pivot points are securely fixed with locking screws in place, make sure the compression spring is not being interfered with, etc.
If you're not mechanically handy, I'd recommend taking it in for service if there's nothing obvious you can determine that is preventing the smooth operation. But if you go through it piece by piece and lube the appropriate friction points, you'll probably be able to free things up considerably.
Let me know how it goes,
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
Aug 02, 2011 | Makita LS1214F 15 Amp 12 Inch Dual Bevel...
Abs light and brake light on goes off once in awhile but keeps comin on
Just had that problem..one of your wheel bearings is going bad..The ABS Sensor is a magnetic device sensing teeth going by inside the "wheel bearing assembly" . If there's side to side play or top to bottom play ..the sensor will pick it up and ABS light will flicker on and off or stay on. So, jack up your front wheels and check for play also, listen for bearing noise. The Fix: Replace the bad wheel bearing assemble (it comes with new sensor ) You may want to swing by your local garage and have them pre-loosen your 35mm Hub nut before you start the repair. YouTube has a good video to help with repair.
One last note: Sometimes sensors go bad , interal wiring breaks...by pulling calipers off and rotar will expose sensor...take it off with an allen wrench and bench ck it for continuity.. ( I've had a new one go bad on my new bearing assembly ..broken internal wire ..I just cut both ends off and re-wired it...)
Jun 13, 2011 | 2001 Chevrolet Blazer
Saws Logo
47 people viewed this question
Top Saws Experts
Bill Boyd
Tom Chichester
ray gallant
Are you a Saw Expert? Answer questions, earn points and help others
