Hi I need door handle for 8kg brilcon front load washing machine
    New Friend:
  • 9 Answers
Get model and serial number get it from local appliance repair shop
Posted on Dec 09, 2014
SOURCE: Broken front door
you need to buy a new 'handle'. to open the door for the time being, disconnect power and then use a coat hangar to pull the latch towards you, ie. outwards
Posted on Jun 09, 2008
gittos73
  • 244 Answers
SOURCE: Broken door handle for a Thor washing machine
there r 2 ways to get the door open 1)use a normal knife and place in front of the door handle push it in and it should open 2)pull the plug out take the lid off now place your hand down to where the catch goes into the washer using your fingers u should be able to pop it open with a bit off fiddling
Posted on Dec 16, 2008
  • 566 Answers
SOURCE: door handle of washing machine broken
if clothes are still in washer? and machine has finished cycles? then handle broke so unable to open ??? your best option is to unplug/ and if necessary disconnect water supply hoses then remove the top screws from rear panel which also secure the top panel as you will observe ? then pull backwards top panel and loft off ? you now have access/visual of the door catch inside front machine look?? at the catch and you will see how it locks ? you can lever the catch gently and door opens to fit a new door catch is easy diy and not expensive if you are confident usual problem these break ? is the time delay micro switch sticks with age /moisture try dw40 and work plunger b4 you refit door back after replacing handle/catch assy
Posted on Feb 16, 2009
SOURCE: hoover washing machine door handle
if any one is stuck fitting a door handle to a hoover washing machine HNL 6146 nextra series then please email me johndgill49@hotmail.com
Posted on Oct 16, 2009
SOURCE: i need a user manual for hotpoint washing machine
go to hotpoint website, then support and you can download all manuals there
Posted on Feb 09, 2010
What does Eo3 mean cannot open door
Could be blocked pump, if water is in the machine the door will not open, open the filter and give it a clean, its normally located bottom right hand side of the case....
Oct 02, 2016 | Hoover DYN8163D8X White 600 mm Washer...
I cannot get my washing machine door to open and alos have error code e07?
On your washing machine control panel you have little icons, find the security. Icon and it should have a line going from it to another button on the control. panel. Press both buttons at dame time and hold till it enters service. Mode. This should make it so the door will open, and will probably tell you what is wrong. with. the machine
Oct 14, 2014 | Hoover DYN8164D White 600 mm Washer Front...
I cannot get the door open and have error code eo7
Unplug from the wall socket,this should unlock the door
if the door locks after plugging in again then there is a fault which needs diagnosing..
Len...
Bosch exxcel 8 washing machine, display dead when you turn on and door locked, fuse is fine..
probably the main board, you need a proper machine expert these day to reset the codes, designed so only they can do it.
Aug 17, 2014 | Bosch Exxcel 8 WAQ28461GB White 598 mm...
To whom it may concern hello I have bosch washing machine was32794 , 1-can I use bleach?may be it damage the machine? 2-how can I distinguish the weight of cloths is more than the capacity of machine?...
Yes, you can use bleach -- about 1/2 cup oer load -- or more if specified in owner's manual.
The machine could handle easily one full laundry basket -- see below.
  • Capacity of typical Laundry Basket = 6 kg (dry weight)
Calculation: [(36 cm x 51 cm x 26 cm) / 28317 cubic cm] x 3.5 kg = 5.9 kg
Charlie
Feb 23, 2011 | Bosch Axxis WFL 2060 Front Load Washer
Hoover washing machine door handle
Aug 29, 2009 | Indesit W 123 Front Load Washer
Change grip/handle on a indesit washing machine w105tx
Undo any screw that you can see on the inside of the door frame, and then prize the two halves apart,
This should give you access to the door handle assy.
Hope this helps.
Dec 02, 2008 | Indesit WA 125 Front Load Washer
Broken front door
Jan 29, 2008 | Washing Machines
Washing Machines Logo
Top Washing Machines Experts
