Bose CorporationDiscover product support for your Bose® Solo TV sound system. ... Learn about using existing universal remote controls with your Bose system. more » ...
Bose CorporationSolo. TV Sound System. Owner's Guide ' Brugervejledning ' Bedienungsanleitung ' ...10. Step 5: Plug the other end of the audio cable into your TV ......................
No, you need some sort of remote. Luckily this Bose uses IR for the remote and not RF. This means you might find a cheap universal remote that has a code for this. PC programmable remotes such as Logitech's Harmony, URC, and RTI remotes would definitely work.
yes I have a lifestyle 235, bose remote is rf but system also supports ir. Prestigo picked up most button and by going into setup on the bose and entering teach mode the prestigo learned the missing buttons.
Did you find a solution? I unscrewed the screw under the battery compartment lid near the rear end of the remote. The rattle is a broken radio frequency antenna. A replacement for this ancient remote is $89 plus shipping and handling. Supposedly the Bose systems can also be programmed with some universal remotes without rf antennae.
You need to use the IR emitter that came with the Bose V30 system. Bose employs a proprietary RF frequency remote which communicates to the hidden central control head. You plug in the emitter to the processor unit and run the emitters to the IR 'eye's' of the equipment you want to control. Once all this is done then and only then can you go through the remote codes to control a particular device. The Bose V30 has 2 IR emitters that come with the unit to control 2 devices. You can expand on that buy buying a IR emitter bridge that has several inputs for other devices.
Now when it comes to a DVR I am not so sure the Bose universal remote will work all the playback and FF and record control buttons and a DVD or VCR. I hear there is a new BOSE remote on the market that can do that but I have yet to see it in person or ask a sales rep about it. Sometimes they are non-tech's so its no help : (
call bose tech support and register your lifestyle system with them, they in turn will start sending you update CD's those CD's may include the new IR databases that would help you find the right code. the other alternative is to call VIaSat and find out what brand's IR codes they are using( and in the IR menu on the bose try that brand's codes) A lot of manufacturers will use the codes from Motorola(worth a shot) the alternative option is to program a universal remote to control your bose, and all your equipment (if your equipment is hidden in a closet, get an RF remote, I program these for my clients all the time (for their bose systems))
You don't need a code. Just follow the instruction as follows:
1. Tun on TV
2. Press and hold "code search" until light stays on, then release.
3. Press TV botton
4. Press on-off repeatedly until TV turns off
5. Press enter.
