Question about Dewalt Self-Leveling Line Laser Horizontal&Vertical - DW087K
How do I replace a level bubble in a Jobmate 57-5302-8 laser level?
Have a broken level bubble
Where can I get parts for jobmate 1500 pressure washer ?
This is from a Google search:
https://www.google.com/#q=jobmate+1500+pressure+washer+replacement+parts
Ebay is pretty good and you may get a gun extension that would fit and be more affordable.
Jul 03, 2016 | Garden
I have a pls 5 laser level and the laser dose not light up but the tilt will operate
It could be a broken wire. If it's a new PLS model, then you can remove the back cover and genitally remove the core, and look to see if any of the thin wires are broken. if not the laser diode is burnt out. If you have an old model with the power button on the top of the unit, then don't open it, it wont close again.
PLS tools are not designed to be repaired. There was a time when PLS made replacement parts, however they changed from that business model and now when things break or go out of spec. they are replaced with an ETN (Equivalent to New) units. Either for free, if they are under warranty, or at a lower cost, if not. Bring your laser to a PLS retailer, and they should be able to take care of you.
Mar 04, 2015 | Pacific Laser Systems Pls Pls5 Self...
I need new clasps for LL500 container box.
Yes part number is Q103224 for the New LL500 blow mold case.
Jan 15, 2013 | Spectra Precision Laser LL500 Exterior...
Topcon rl-60b
Hopefully it's the simple answer. The bubble vial may be out. start where the level vial says is level, and move outwards in slow circles to try and find a place the laser thinks is level. if you find a spot, use the 3 adjustment screws on the bottom of the bubble vial to make that your new center.
Otherwise, it's a not good news. A couple things could be gone wrong. The oil bath compensator could have leaked. If you open the laser, and it's oily inside, throw it away.
It could be the peep site could need adjusting, or the laser diode could be blown. If the laser diode is dead, same solution as the compensator leaking. There are no parts available for these anymore, chuck it out.
The peep site isn't a write off, per se. The laser operates by shooting the beam through a oil bath, which compensates for the instrument not being perfectly level, and then through a splitting lens. part of the beam travels up, and through the rotating head. And the rest goes through a peep site, to a light reflecting area of the main circuit board. if the board or peep site is no longer aligned, the laser will never think it's level. The bad news about that, it is a very tricky and time consuming repair, that few technicians know how to do, or if they do know how are most aren't comfortable doing it.
You can try taking the cover off, leveling the instrument, powering it up and trying to move the circuit board until the laser thinks it's level, but i wouldn't waste much time on it.
Aug 27, 2012 | Topcon Rl-60b Rotating Laser Level C/w...
I haven't used my Jobmate laser level in the last year and wanted to use it today and it is not working. I want to change the batteries (assuming it works on batteries) but can't seem to find where the...
Where the button is to push laser on & off, there is a metal ring around it. Just unscrew this ring & the batteries will come out. Replace batteries, & rescrew the ring in place.
Jan 05, 2011 | Garden
How do I calibrate my stanley laser level
to calibrate you need to have an area 75 to 100 feet in distance. place laser on tripod 20 feet from one end, take measurements on short and long end, then move laser to center of range and take measurements on both ends . the distance between both sets of marks should be within + or - 1/4 inch if not move level screw to move beam to center then center bubble
Jun 17, 2010 | Stanley 77 156 RL100 Manual Leveling Dual...
Jobmate 3 gallon air compressor parts list/diagram
Good luck on this one. I own 2 jobmate compressors, one I bought and used very little before it blew apart and another a freind gave me to use for parts. Guess what the same part failed on both and I know of at ;east three more that also failed the same way.
I gave up trying to deal with Canadian Tire and Jobemate and junked them, as though they weren't junk to begin witn. You get what you pay for. I have a new Hausefield compressor and it is fantastic.
Feb 23, 2010 | Air Tools & Compressors
I have a JobMate cordless drill and 2 batteries.
I found the Ryobi charger fits the jobmate as well.
Oct 20, 2009 | Drills
How to level my level for 360 degree range
The level is meant for 360* of USE not from one single position check both horizontal and vertical... I think that one is a Moveable
Laser? Level?
OH I just found .. is it on a tripod like attachment? there should be a small round "level" on the physical Base of the level itself .... (like the ones your drill would have for drilling down into the floor boards) You must level it that way First.... then you can use it ...
Oct 21, 2008 | Stanley Measuring Tools & Sensors
Dewalt Self-Leveling Line Laser Horizontal&Vertical - DW087K Logo
132 people viewed this question
Top Dewalt Measuring Tools & Sensors Experts
Matthew McGuire
Level 1 Expert
Richard Warren
Richard Warren
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Dewalt Measuring Tool and Sensor Expert? Answer questions, earn points and help others
