Question about Bosch GL4Ti Ariston Pro Ti Electric Mini-Tank Water Heater
Bosch GL4Ti Ariston Pro Ti Electric Mini-Tank Water Heater user's manual
Tried to reset heater but no go.
4 Suggested Answers
  • 5 Answers
SOURCE: What is the difference between Bosch GL4 Ariston
The difference between the Bosch GL4 and GL4Ti is the GL4Ti has a glass lined tank with titanium inside and an 8 year warranty. The GL4 has a glass lined stainless steel tank and a 6 year warranty.
Posted on Jan 14, 2011
  • 5 Answers
SOURCE: Bosch GL4ti Ariston water heater - have no hot
Check if unit has power to the plug. If so, could be bad heater element or bad thermostat. Also could be reset button on thermostat and yes, the reset button is different from on/off switch. Element about $38, thermostat about $30 from www.plumbingsupply.com
Occasionally, the high temperature limit shut off device may trigger and shut the
system down. This occurs when water temperature exceeds 190° F and shuts off
power to the heating element. The shut off device may also trigger from a power
outage or electrical storm.
To reach the thermostat:
1. Pry off the round cover plate (V Fig. 3/1) from its right hand edge (W Fig. 3/1) with
a small flat-head screwdriver.
2. Remove the Phillips screw revealed beneath the round cover plate.
3. The cover (C Fig. 3/1) can now be removed by pulling out its left-hand edge. When
reassembling, work in the opposite way being careful to insert the tongue of the
cover into the slot.
4. Firmly press reset button (B Fig. 4). Reconnect power.
5. IMPORTANT: Check the operation of the thermostat, turn temperature dial from
high to low, if the red light does not go off on low setting, turn off power supply and
call a service person to replace the thermostat.
6. If the system works, place dial setting to desired setting. Note: a lower setting is
more economical and reduces the risk of scalding. Replace cover plate.
CAUTION: Call a technician if the high limit needs to be reset frequently.
PlumbingSupply.com has the Ariston repair parts that you need.
ariston-gl2546components.png Diagram # Model # Description Price & Quantity 2 570241 Anode Rod for GL6 and GL8Ti $13.99 2 574305 New Style Anode Rod for GL2.5 and 4.0 $12.95 3 994147 Element Gasket $11.95 4 994140 Element Locknut - 4 Each Req. Per Element - sold each $2.99 5 994103 Element for GL2.5 and GL4.0 $37.95 5 994104 Element for GL6 $39.97 11 65105602
old #994062 Thermostat for GL2.5 and GL4.0 $29.52 11 65150322
old #994102 Thermostat for GL6 $32.57 GL25-4KIT Element, Element Gasket and Anode Rod Kit - For GL2.5Ti & GL4.0Ti $47.65 GL6-8KIT Element, Element Gasket and Anode Rod Kit - For GL6 & GL8Ti $48.65 Note: If you don't see your number unfortunately it is no longer available
  • 5089 Answers
SOURCE: how do i install a Bosch GL4 Ariston 4-Gallon Point-of-Use Indoor Electric Mini-Tank Water Heater?
Bosch GL4 is plug-in style electric water heater
Copy following for product manual, and for step-by-step illustrations.
http://waterheatertimer.org/How-to-install-under-counter-water-heater.html
Posted on Oct 30, 2012
We have an ariston pro pi water heater and water is dripping all over from the bottom. How do you drain this? It is less thasn 5 years old
The tank is drained by removing tank, and using hot water outlet as a drain.
Under-counter tanks are not made with thick steel hull that adds cost and weight to product.
Water heater can rust out quickly if anode rod is not checked and replaced each year.
Anode rod depletion is faster if home has water softener.
All tank-type water heaters have replaceable anode rod that protects tank from rusting, and most water heater manuals include general description of anode and maintenance.
http://waterheatertimer.org/Replace-anode-rod.html#ariston
Rusted water heater must be replaced.
Take a moment and rate answer:
And take advantage of fixya expert assistance live.
For a price, expert works with you while you work on water heater or any do-it-yourself project.
Fixya is always less expensive than a service call.
Sep 06, 2011 | Bosch GL4Ti Ariston Pro Ti Electric...
Ariston GL6+ Occasional rusty water. Can this be remedied? Thank you Ed
Ariston GL6 6-gallon electric water heater has anode rod to prevent steel tank from rusting.
Once anode rod depletes, the tank rusts.
All tank-type water heaters have replaceable anode rod that can stop rusting, but will not repair damaged tank.
Open following links for resources + manual with parts number and illustration on page 7 and 10. Part number is shown as 570241 anode rod.
http://waterheatertimer.org/pdf/Bosch-GL_English.pdf
Jul 12, 2011 | Bosch Ariston GL6-plus GL6+ Point-of-Use...
I have a Ariston Pro TI water heater. I am getting a lot of rust/junk/green/black, particals in the hot water plugging my shower heads. How do if fix this problem? Thanks Tom
If problem is hot water side only, then water heater is suspect.
1) If water heater temperature is set above 140F, it causes minerals to dissolve out of water.
2) If water heater is exposed to minerals in water, like hard water, those minerals will gather at bottom of tank.
3) If anode rod is depleted, the metal tank will begin to rust.
4) Combination of problems listed above.
To fix these problems, flush tank and replace anode rod, and possibly install water softener, install water filter, and turn down temperature setting.
http://waterheatertimer.org/Clean-sediment-out-of-water-heater.html#flush
Jul 11, 2011 | Bosch GL8Ti Ariston Pro Ti Electric...
My Ariston 4 gallon water heater is given out hot dirty water?... Any Suggestions?
1) Dirty water implies degraded metal inside unit:
The anode rod protects metal parts. Once anode is depleted, metal parts react with water.
2) Open following troubleshoot pdf showing Ariston parts
http://waterheatertimer.org/pdf/How-to-Troubleshoot-Bosch-Ariston-Water-Heater.pdf
3) Ariston manual: Read manual cover to cover, make sure water heater receives yearly maintenance as outline in manual.
4) Information on anode rods
5) For Bosch gas and electric tankless: Open following link for troubleshooting resources, including Bosch contact information, typical manuals, error codes, tech support, parts, fuel-saver calculator, service bulletins, water heater forum, fixya links, disclaimers, and links for finding service technician.
http://waterheatertimer.org/Troubleshoot-Bosch-Tankless-water-heater.html
6) Add a comment with your experience so others with same-similar problem can benefit.
Also take advantage of fixya expert assistance live.
Apr 02, 2011 | Bosch Ariston GL4 GL4 Point-of-Use...
We just had a Ariston GL 4Ti water heater installed. The water is just not very hot. Does this unit have a temp adjuster on it? If not can you reset the water heater? The way it was installed I cannot...
After installation check the water temperature. If adjustment is necessary, remove front
cover to adjust thermostat under cover. Clockwise to increase the temperature and
counter clockwise to decrease it.
1. Pry off the round cover plate from its right hand edge with
3. The cover can now be removed by pulling out its left-hand edge.
When reassembling, work in the opposite way being careful to insert the tongue
of the cover into the slot.
Sep 17, 2010 | Bosch GL4Ti Ariston Pro Ti Electric...
Bosch GL4ti Ariston water heater - have no hot water is it worth fixing or should I replace? Also, is the reset button different from the on/off switch?
Feb 02, 2010 | Bosch GL4Ti Ariston Pro Ti Electric...
My ariston electric hot water heater keeps tripping off
Tripping off at the water heater or at the breaker box?
Jan 24, 2010 | Bosch GL4Ti Ariston Pro Ti Electric...
What is the difference between Bosch GL4 Ariston and Bosch GL4Ti Pro Ariston?
Sep 02, 2009 | Bosch GL4Ti Ariston Pro Ti Electric...
Bosch GL4Ti Ariston Pro Ti Electric Mini-Tank Water Heater Logo
65 people viewed this question
Top Bosch Water Heaters Experts
Colin Stickland
Colin Stickland
Donni Steen
john h
Are you a Bosch Water Heater Expert? Answer questions, earn points and help others
