Question about Hotpoint Washing Machines
Soap does not despense and h20 keeps coming up.
Turning it off and on, cleaned the soap despenser.
Something wrong with the water inlet
perhaps the washers valves or filters
Posted on Dec 10, 2014
After switchig the machine.on the desplay unit showing despensing unit blocked
Open the draw remove it from machine run it under hot water in your tub till all the soap powder is cleaned out,then refit and fill with hot water to clear pipe to drum.
Feb 02, 2017 | Washing Machines
Tip
Fix simplehuman soap dispenser
Solution!!!!! to Simplehuman sensor soap dispenser with blinking red light no despensing of soap and new batteries. Rinse out soap with hot water. Fill reservoir with hot tap water. Use bulb end of turkey baster. Place on reservoir to form a tight seal. Force air into reservoir. Which will force the hot water thru the system unclogging the thick soap. Repeat this several times till clear of soap. Then turn on the unit and flush thru the rest of the hot water using the sensor till comes out nicely. Then fill with a thinned out soap. Good luck
on Jan 16, 2014 | Simplehuman Sensor Soap Pump ST1001
Water runs out around soap despenser
Necessary to clean the pallet of the loading the soap.
Jan 07, 2011 | Kenmore HE2 Plus Front Load Washer
What can i do if i dont have a soap despenser
With this unit, use a small shotglass of soap solution into the water container when you are filling it up. the soap will premix in the water there and be good for the system to continue using. Make sure that the dial is set on WATER ONLY so that you are not getting soapy water coming out of where the soap bottle should be.
Nov 04, 2010 | Bissell 1698 PowerSteamer ProHeat Upright...
Help! My dishwasher runs thru it's cycles but when I open it I find my second detergent cup still full of soap and my dishes still dirty. I have an older maytag dishwasher but have never had this...
There are three common problems that cause the Soap Dispenser or Cup not to open. I have a tip that will explain these problems in detail....
Dishwasher Repair Problem Detergent Cup does not Open
heatman101
Aug 27, 2010 | Dishwashers
Water is coming from soap despenser during rinse cycle, I think it maybe a clogged hose .
oull out the drawer and see if the pipe that is under the fabric softner dispenser compartment cap is all pligged up if so just clean it out w/ warm water
Feb 06, 2010 | Samsung WF337AA Front Load Washer
On my karcher pressure washer, how do i get the soap to come out of the spray nozzle?
Two nozzels came with your washer one has a cone shaped head, the other one is blunt, attach the blunt one to the trigger. You will notice on the barrel of the nozzel it says "mix" turn the indicator line to "mix" and it should work. This is a very low pressure setting and is used to "apply" the soap only. You cannot despense soap in the hight pressure mode.
Apr 13, 2009 | Karcher K2.26 Electric Power Washer
GE Front Loader will not despense Fabric Softener
We checked the cold water line that goes into the washer, it had some pretty nasty stuff in it, and once we cleaned it out, and soaked it in CLR, it cleared up the line. Once we reattached it and ran a cycle, it went great. I am assuming with the line being clogged it didn't have enough water pressure to flush out the fabric softener.
Apr 27, 2008 | GE Energy Star WCVH6260F Front Load Washer
Ice despenser not working
use a hair dryer, it will thaw the ice and not damage the plastic
Apr 26, 2008 | Kenmore 50522 / 50524 Side by Side...
Washing Machines Logo
53 people viewed this question
Top Hotpoint Washing Machines Experts
puggy666
Level 1 Expert
ptpumpman
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
