Question about Kitchen Ranges
Just moved in to a flat with Silavent Kitchen and bathroom extractor fans, the bathroom one does not make any sound even with isolator switch on. The one in the kitchen makes these short popping sounds, I assume this is rapid extraction and I shouldn't be worried about it blowing up or anything silly like that
    Master:
  • 574 Answers
It could be the vents snapping shut
Posted on Dec 09, 2014
SolutionGuy
  • 331 Answers
SOURCE: GE JGBP83WEJWW Gas Kitchen Range
Amy, F1 indicates that your ERC (electronic relay control) OR your keypad has failed. Here is the test procedure to determine which... GO OUTSIDE AND SHUT THE BREAKER OFF!!! Open the top oven door (the model number you posted is incorrect, I don't know if it's a single or double oven but the procedure is the same)and look at the bottom of the keypad console. You'll see 3 screws under there. Use a 1/4" nut driver or socket to remove these. Then remove the control panel (lift and rotate toward you). From here, you'll see the back side of the ERC. Look for the green "ribbon" coming from the keypad and inserted into the ERC. Remove the ribbon cable from the ERC and let it dangle all by itself. Then replace the control panel in the reverse order from what I described above. Now turn the breaker back on. OK.... this is waiting period. Now that the keypad is disconnected you've isolated the 2 components. If the F1 error reoccurs, the ERC is the problem. If not, it's the keypad. The time frame for this diagnosis is 24 hours. If, after that time, the error does not show it's definitely the keypad.
Posted on Aug 09, 2007
  • 833 Answers
SOURCE: kitchen aid stove problem
Peter,
First...be sure you cut power to the stove before you do anything. This is 220 volts and it can kill you. 220 Volts is based on two different lines of power coming to the stove, each of which is 110 volts...but opposite each other in phase. This may mean that some power to the stove is on and some is not. Let's go on.
I suspect a few things: First, the coil control for the burner is probably finished. What I also suspect is that it opened one of the two breakers (they are usually tied together in the panel and are either 40/50/60 amp units) causing some lights but no action.
What to do: Reset the breakers as a pair by turning them off and on. If one snaps off, you have a problem at the stove. If not,...which I doubt...you're in business.
Let's look at replacing the control. Shut the breakers. Now, take the burned control and remove it. Note the wiring positions if they are not on a plug. If they are terminals, tape the ends. Now, reset those breakers. If the other burners work, replace the control. Take the old one to the parts store. If it doesn't work, look around the burned area for broken wires. Repair and tape them up. Try again. Oh, and don't let anyone touch the stove while you're working with those breakers.
Posted on Dec 03, 2007
  • 1314 Answers
SOURCE: Fridgedaire Electric Kitchen Range
shut your oven off at the breaker and then pull it out and check the power cord where it connects to the ranges terminal block let me know what you find
Posted on Sep 11, 2008
  • 97 Answers
SOURCE: Repalcing an infinite switch on Kitchen Aid KERC607HBS4
Front panel is removable...4 screws i believe secure it from bottom....open door and look up under panel. remove screws and bottom of controls will come down. giving you access to switches.
Posted on Jun 10, 2009
leedavidian
  • 1420 Answers
SOURCE: I have a Bosch Hob
what model do you have and/ or series, Thanks, Lee
Posted on Jan 17, 2010
I have moved into a property with a Sector extractor fan in the bathroom - when you turn the light on the extractor starts up -when you turn the light off the extractor continues to run for a long time -...
On some Bathroom extractor fans there is a setting for the amount of time you want the fan to stay on after you turn off the switch, the setting dial is normally at the back of the fan so you need to take the fan down from the ceiling making sure the fan is electrically isolated.
Mar 31, 2011 | Home
Hi I have an alto extractor fan in my bathroom but it doesn't activate when I turn on the light. Any ideas on how to fix it? Thanks
you may have a fan operating from purely from a built in humidistat instead of being operated from the light switched . If that is the case an electrician may be able to alter the wireing to have the light switch overide the humidistat, or even adjust the integral humidistat to a lower setting and operate the boost at a lower relative humidity level.
Aug 15, 2010 | Heating & Cooling
My bathroom fan will not turn itself off, it is connected to the bathroom light, light is turned off but fan goes continuiously??????
Then it is not connected to the light switch as you think. This could be a dangerous situation, and you should have an experienced electrician look at it.
Mar 02, 2010 | HP Extractor Fan Kit 110V Rack Mount Fan
My Bathroom Extractor Fan does not work properly and for some reason the bathroom smells of cigarette smoke when the upstairs neighbours are at home!! Our landlord say's this is not possible!!!
Yes, very possible!. The bathroom fan is connected together, and the upstairs one is down-drafting to you. Have the exhaust checked for blockage, or buy a fan that has a built-in damper that closes the exit when not in use.
Oct 21, 2009 | HP Extractor Fan Kit 110V Rack Mount Fan
Bathroom extractor fan won't switch off
The fan most likely is turned on by the bathroom light switch. You likely have a defective fan motor.
May 01, 2017 | Hampton Bay 24002 Ceiling Fan
Kitchen extractor fan
hi! most of the time this will be sticky switch normally located on the inside edge of the extactor unit behind the filter mesh!.hope his helps
Dec 20, 2008 | Imperial C2036PS1-TW Kitchen Hood
Wireing a bathroom extractor fan to a three switch (fan=landing light=offswitch0
yes, if the three switches are all made together, then there is only one feed. sounds like a bad switch, or possibly bad exhaust fan. check voltage at fan with switch on, if not qualified, be careful, or call an electrician
Aug 10, 2008 | Dryers
The extractor on my Baumatic fan stopped working. Thsi was shortly after the light bulbs blew which I replaced and they work OK. Any suggestions as to how i can resolve this?
Sounds like it was the main fan motor - that caused the lights to blow in the first place.
Isolate from supply, and get the fan motor checked out. If it is burnt out (inside) you will need a replacement.
Hope this helps.
Jun 05, 2008 | Baumatic F60 Stainless Steel Kitchen Hood
Fan and light not working where is fuse box?
Hi - I have a neff extractor fan and have the same problem. The light and fan have both stopped working. Does anybody know where I can find the fuse as I suspect that this may be the problem too?
Dec 07, 2007 | Whirlpool GZ7730XGS Stainless Steel...
Kitchen Ranges Logo
141 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
