Question about Cell Phones
I am missing the cover to the battery compartment and it doesn't say what size batteries it takes. Could anyone tell me if they are c or do cells?
  • 1,511 Answers
It will only take one size. Take it to WalMart or Radio Shack and they will fit it up for you.
Posted on Dec 09, 2014
otacon
  • 1944 Answers
SOURCE: Need a new battery cover
You can buy one from here.
Posted on Jan 11, 2008
Ajkill
  • 2035 Answers
SOURCE: Having a hard time removing cell phone battery cover
Model number of the phone.
Posted on May 17, 2008
fuzzyfernie
  • 22 Answers
SOURCE: battery cover
You should be able to get it off by pushing it up away from you and to the right.
Posted on Oct 16, 2008
  • 5 Answers
SOURCE: Removing Battery cover for cell phone
There are so many models out there and many different ways to remove battery covers.
Besdies the brand I also need the model of the cell phone in order to tell you how to remove the cover.
Try looking up the model from the place you purchased the phone from, if you purchased it online you most probebly can find the model number in the description of the listing.
Posted on Mar 11, 2009
expert007
  • 179 Answers
SOURCE: I am planning to use pencil cell as a mobile battery. Can
go to youtube
Posted on Jul 19, 2010
Testimonial: "Thank you for giving me answer."
Battery replacement J-10A
Good Morning Fhaas153
Looking at a J-10 picture on eBay
http://www.ebay.com/itm/VINTAGE-CASIO-J-10-ELECTRONIC-CALCULATOR-8-DIGIT-TESTED-/331587643662 , the picture of the rear says '1.5V battery x 2. Looking at this other shot
http://www.casio-calculator.com/Museum/Calculator/FGHIJ/J-10/Casio-J-10-back.jpg It looks like there is a fairly clear Slide-to-Open Battery door at the top of the rear panel. Given the battery rating at 1.5 Volts and the door size, I'd suspect it'll take either AA or AAA batteries. You should be able to slide the door and look, and most battery compartments will have an indication of the specific cell.
To be sure I'm covering both the what and the how, slide the door open. Remove old batteries if still there. Clean up contacts with a bit of fine steel wool if they are corroded or covered with old battery fuzz. Put new batteries in - negative end towards the coil springs generally. Replace sliding hatch.
Hoping this covers what you're looking for!
D
Dec 09, 2015 | Casio Office Equipment & Supplies
Where has the replacement battery CR1620 must be placed?
1) Open the main battery compartment
2) Remove the battery tray
3) Inside the battery compartment directly behind the LCD screen there is a small cover about the same size as the CR1620.
4) Remove the cover
5) Replace the battery
6) Replace the cover
7) Replace the battery tray
Jul 20, 2012 | Polaroid Battery Grip for Canon EOS-7D...
I am trying to find out what type of battery my snapper sr 1028 takes?
If it's a 12Volt Lead-Acid battery, which are most common, then it really doesn't matter. If you have the old battery, then basically, just match the size. Take it into Walmart, Kmart, Sears, or wherever and match it up. The most important thing is that is FITS where the battery compartment is and that the voltage is correct (usually 12 Volts DC, but I did not look up your particular mower). Also, make sure the connectors on the battery are the same type. Hope this helps. Best of luck.
James
Aug 09, 2011 | Troy Bilt 5.5hp Self Propelled Mower
What size is the battery compartment for the Pride Jet 3? I am trying to order batteries on-line and don't want to take the power chair apart to make sure the terminals and size are correct . The Pride...
Raine you need to purchase two U1 batteries for your Jet 3. I would check locally with a battery outlet store first because your cost can be less that $200.00 for both batteries this way. If the on-line comany wants more than $200.00 for the 2 batteries plus shipping I would look hard in the local area. Hope this helps
Aug 28, 2010 | Jet 3 Ultra Power Chair
Replacing batteries on Energizer Hard Case Lantern
If you have the Energizer Hard Case Lantern TUF4D1, simply grasp the whole front of the lamp piece (including the rubber cover), and twist in a counter-clockwise direction to remove. Then squeeze together the two black tabs and pull the battery compartment out to replace the batteries.
Jul 05, 2010 | Energizer Eveready TUF4D1E 4D Cell Lantern
I am missing parts.
Sale me transmitter of HD
May 14, 2010 | Video Game Consoles & Games
I am missing parts.
search the manufacturer
Mar 25, 2010 | Toys
How do you open battery slot
(1)Remove the USB connector cover.
(2)Press and Move the battery cover in the direction of the arrow.
(3)Remove the battery cover and insert one AAA-size battery into the
battery compartment.
(4)Replace the battery cover.
Jan 23, 2010 | Nextar MA933A MP3 Player
Where is cmos battery located in Dell d505?
It's called the Reserve Battery in a Dell Latitude D505.
(It's also called an RTC battery in others, {Real Time Clock battery}, and CMOS battery in older laptops)
1.Remove the AC adapter if plugged in. (Charger)
2.Remove the Battery.
3.Right up against the outside edge of the battery compartment, in the middle. you will see the battery latch.
Push it down. The Reserve Battery Cover will come loose at the top. Rotate the top, towards the inside of the battery compartment.
The Reserve Battery is right there.
Pull the Reserve Battery towards the battery compartment.
(Comes right out of the small rectangular compartment it is in)
(It looks like three round coins put side by side, and has a green plastic coating around it.
In actuality, there are coin sized watch batteries inside that green plastic cover)
You will see a Red wire, and a Black wire twisted together, that go to a small white connector. The connector is two piece. Separate the connector, and you can take the Reserve Battery out.
http://support.dell.com/support/edocs/systems/latd505/sm/reserve.htm#1123661
Dec 19, 2009 | Dell Latitude D505 Notebook
Nikon Pro Staff 440 Range Finder
there is a silver quarter sized screw out cover on the battery compartment.  It has a slot so you can use a coin or screwdriver to remove the cover.
Oct 12, 2007 | Nikon ProStaff Laser 440 Rangefinder
Cell Phones Logo
22 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
