Question about Home
How do I repair a shower to tub spout
A hammer
  • 1,511 Answers
Need more details?
Posted on Dec 09, 2014
Why does the water not flow from shower valve when turned on?
Do you have water coming out of the tub spout and not the shower head? If so how does the water get directed to the shower head,is it by pulling up the diverter on the tub spout?If water is still coming out of the tub spout then the diverter is bad and the tub spout needs to be replaced.
May 09, 2012 | Danze & Single Handle Tub And Shower...
Help! When I pull out the control stem on the tub spout to send water through the shower head most of the water continues to flow out through the tub spout. Is there something that I can replace or...
You can replace the assembly and not have to worry about taking apart the stem or, you can get a replacement diverter. The spout will twist off turning counterclockwise.
Jun 14, 2011 | Price Pfister 01-111 Shower Head, Tub...
Seem to have a clogged shower tub spout is there a screen or something I can clean
The only solution to tub spout is to replace the spout part, they are usuallyless than $25,00.
Good Luck
Tool Belt Diva
May 10, 2011 | Moen & One Handle Tub & Shower Faucet
We have installed a moen 82490 one handle tub & shower unit. When we turn on the water you could shower and bath at the same time. If you pull the plug for just a shower the water to the spout stops...
If you pull the silver knob on the tub spout up, the diverter located located inside will redirect water up to the shower head and when lowered it will return the water to the tub spout. It sounds as thought the diverter is not working properly. Hope this helps..
Mar 08, 2011 | Moen & One Handle Tub & Shower Faucet
I have a Moen tub and shower system similar to the Moen 2919 Chateau two handle above. When I turn on the faucets up to 1/2 way everthing works fine. If I try to increase the water capacity by turning up...
To talk about your problem forces me to assume a few things.....If you allow the water to flow without cartridges and handles, the water must be flowing straight through the cartridge channels and out into the tub. It is not flowing through your tub spout or shower head when you test the water this way. If I'm correct, then the problem is isolated to the water mix operation. That means coming out of your spout or shower head. So now I have to ask a question. When you operate as normal (cartridges and handles installed) does your problem show up only on your shower head or does it also show up when operating out of the tub spout? If the problem is isolated to the shower head, try a head replacement. It may be partially plugged. If it's head or spout there may be something in the mixing pipe that only shifts around as pressure increases. I hope that is not your problem. It would require pulling those pipes out for inspection and most likely replacement. Nimsgame
Feb 19, 2011 | Moen 2919 Chateau Two Handle Tub and...
When lever on tub spout is pulled up for shower use some hot water still comes out of the tub spout...reducing water pressure and temperature of water coming out of the shower head... Tub spout does NOT...
2 things can be happing here depending on the age of the tub spout. If the spout is more than 5 years old, you may need to replace it. if not that old then you may have a screen filter blockage in the shower head itself. remove the shower head from the shower neck and see if there is anything in the filter. while you have the head removed, try the tub spout again and see if problem continues. this should guide you in the next step to either replace the tub spout or just clean the shower head screen filter. Hope this helps.
Dec 29, 2010 | Cifial 295.604.625.SO Polished Chrome...
At what height is the shower rough in body installed
I set my valve were it feels comfortable when i stand up in there tub or shower.Most people shower any way.. the one sitting in the tub can still reach it I usually set shower valves at 42 to 44 inches and the shower arm at 74-78. You want it I usually rough the tub and shower valve spout at 4" above the tub rim, shower valve 10" above the spout. This is for tub and shower combo.
Aug 08, 2010 | Delta & Single Handle Shower Faucet
When the shower valve is engaged I still get water out of the tub spout and limited water out of the shower head. I just replaced the cartridge thinking that might be the problem but no luck
it sound's like you need to replace the tub spout.there should be a set screw on the bottom of spout loosen and twist off. replace with moen spout for ease of re-install.it's a real pain in the *** to try and replace -o- ring spout.
Dec 05, 2009 | Moen & One Handle Tub & Shower Faucet
Shower/spout
The valve is installed upside down and needs to be reversed. There is a diverter in the valve that gives the spout priority. When the valve is upside down it gives the shower head priority. Thats why it runs without the diverter being activated. You will need to get in the wall from one side or the other. Cut the valve out and either flip the faucet Or change the direction of the diverter depending on the style of valve.
Good Luck, Phil
Dec 10, 2008 | Price Pfister 01-111 Shower Head, Tub...
Ghroe Seabury 25502 roman tub filler leaking at liftrod control
It can be repaired.
You can see an exploded diagram here
I can post more if you need more specific instructions.
Nov 22, 2008 | Grohe 19.045.000 Seabury Thermostatic...
Home Logo
52 people viewed this question
Top Home Experts
Donni Steen
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
