Hi, can the Casio PCR- T480 be used without paper. ´Gives Error 014 and can`t even open drawer...
We don`t want to use paper as we basically use it for calculator and cash. Is there a way to bypass this error code? Thanks for your help.
    New Friend:
  • 41 Answers
Since is an electronic cash register, i think, at least, it want the inside registration paper. maybe a security "you cant bill without a log on paper" system. bye
Posted on Dec 15, 2014
  • 202 Answers
SOURCE: CASIO TE2200 Error E010 while drawer is closed
This type of problem is normally caused by a switch. When the drawer opens, the switch closes and the machine goes into 'drawer open' mode to prevent another transaction. The switch or the switch activator has probably failed.
Remove the entire drawer assembly, meaning everything that comes out when the drawer is opened. Use a flashlight and look at the inside rear of the drawer opening to see if you can see the switch. It may be a lever or a button and it may be in line withe the drawer or in may be off to one side. When it is located, try to press on the button or lever. If you can and the machine goes back to 'normal mode' the problem will be identified and you will know that the switch is good. Now you need to locate what actuates the switch to see why it is not making contact. Look on the part of the drawer that should come in contact with the switch. If a small, thin piece of plastic has broken off, tape a small piece of a hard substance in that area. Close the drawer to see if the 'open' message goes away. If id does not, try a thicker piece. Repeat until the 'open' message goes away. When that happens, glue the last piece in place.
If the 'open' message does not go away when the button or lever is press, it indicates that the switch is bad and needs to be replaced. Most of these switches make contact when the button or lever are not pressed. In the short term you could locate the switch and disconnect one wire. That would simulate the button being pressed. You would just need to remember to not start another transaction until the drawer is closed.
Good luck, and please let me know how it works out.
Posted on Feb 22, 2009
SOURCE: Casio PCR T2000 Register : CA=/AMT TENDER ERROR no code
There was some setting on the CA/Tender button that someone had accidentally entered. to clear this setting we put the register in program mode. then hit 3 / subtotal. then hit 0 / CA/Tender / subtotal. thats it. cleared the setting and the register works fine now.
Posted on Jun 19, 2009
SOURCE: Casio PCR-T2000 cash drawer will not open to
give it a kick
Posted on Jun 24, 2009
flexion1
  • 737 Answers
SOURCE: Hi i have a used cash register casio PCR-262 but i
On most drawers, the key is only used to lock the drawer to prevent it being opened. If you want to open the drawer manually, this cannot be done with the key. You should find a trigger under the drawer for this. If you are sure that you want to lock the drawer then you will need to order a key from a dealer.
If anyone needs / looking for a Casio PCR-262 manual, try here: http://the-checkout-tech.com/manuals/cashregisters/Casio2.php
Posted on Jul 20, 2010
maxcarson
  • 7627 Answers
SOURCE: where can I get a coin tray for the cash drawer for a casio pcr-265p register
wrong category
Posted on Dec 09, 2012
My Casio PCR T480 will not work when the CA/Amt Tender button is pressed. I have tried clearing a machine lock up, which does not work. I'm not sure what has caused the problem initially as the cashier...
Hi. This is usually caused by someone reprogramming the status of the cash button while they are changing prices.
Try this.
Turn key to program
Press 0
Press CASH
Press Subtotal
Press 3
Press SUBTOTAL
Press 0
Press CASH
Press SUBTOTAL
Jul 30, 2013 | Computers & Internet
Casio PCR-T480 , Is there a way to program server tips?
Can you please stop multiple posting, it doesn't get answered any faster.
May 30, 2013 | Computers & Internet
Casio PCR-T465 will not open when n/s or ca/amt tend buttons are pushed.
What happens when you try these buttons? Any beep, or error number? Also, does the drawer open when you finish with a different payment type e.g. credit? Does the drawer open when you print an end of day report in X or Z mode?
If anyone is looking for a Casio PCR-T465 manual, try here: http://the-checkout-tech.com/manuals/cashregisters/Casio_PCR-T465_users_and_programming_manual.html
Feb 15, 2011 | Casio Parts Cash Register PC Desktop
I have a Casio PCR-T2000 and drawer will not open, not lock and will open manually.
It sounds like you might have a bent drawer. The lock is totally independent of the latch, so if it won't open at the end of a sale and it won't lock with the drawer key, then you have a drawer problem that will probably involve some panel beating. ---------------------------------------------------------------------------------------
If anyone is looking for a Casio PCR-T2000 manual, c-tech collective have it here: http://the-checkout-tech.com/manuals/cashregisters/Casio3.php
Dec 17, 2010 | Casio Parts Cash Register PC Desktop
Hi i have a used cash register casio PCR-262 but i need the key for the drawer i dont have one.
Jul 13, 2010 | Casio Parts Cash Register PC Desktop
Casio pcr-265 e94 what is the error and how do i fix it
On the PCR-265, error e94 is caused by jammed printer paper.
1. Remove jammed paper.
2. Turn Mode switch to OFF, then turn to ON.
or
Turn Power OFF and then turn power ON.
There's an online manual for the PCR-265B register [ pdf file, that can be read with Adobe Reader ]:
http://www.casio4business.com/sa/products/downloads/manuals/other_models/PCR265PB_E0203A.pdf
note:
The additional letter B, could mean this printer has extra/other options.
May 17, 2010 | Casio Parts Cash Register PC Desktop
I have a Casio PCR T2000 cash register, which said E12, paper jam
yeah that's it, there is a paper jam. unjam it. hope this helped
Jan 29, 2010 | Casio Parts Cash Register PC Desktop
Cannot open register casio pcr-265p model pcr-265p
Hi. It has nothing to do with button pressing.
The machine is indicating printer failure. make sure nothing is jammed in the printer.
Mark
Dec 24, 2008 | Casio Parts Cash Register PC Desktop
Computers & Internet Logo
57 people viewed this question
David Payne
David Payne
