Question about GE JBP82 Electric Kitchen Range
Oven light bulb burned out-replaced-now won't turn off. GE JBP82 electric range
Unplugged for a few minutes, still won't turn off. Just took the light bulb out for now, but, would like light in the oven.
  • 1,511 Answers
The activation source switching mechanism may have frozen in the ON position. If you cannot turn it off when pressing the on/off button; the it is stuck ON. Since the ON/OFF is part of the Circuit Board, it cannot be repaired by itself. What you can do is just leave the bulb in the socket and unscrew it (leaving it partway in the socket) until it goes out.
Posted on Dec 09, 2014
  • 126 Answers
SOURCE: GE Range JBP82 Has 2 Burners Not Working
Could be bad infinite control switch.
Posted on Jan 02, 2009
  • 291 Answers
SOURCE: GE Profile Gas Range oven light doesn't work even after changing
  1. After self cleaning the range the door won't open
  2. Amana gas range conversion from NG to propane
  3. A tip on cleaning the surface grates
  4. Checking an common oven temp sensor
  5. Checking an common oven temp sensor: What does an oven temp sensor look like?
  6. Gas range repair aid - such as, my oven won't work or heat up, which style of gas oven do I have, the glow coil gets red but my oven burner will not light.
  7. GE gas range conversion from NG to propane
  8. How to change the oven temp on some common electronic controlled ovens
  9. How to re-light a surface or oven pilot light
  10. How to change a common oven glow igniter coil
  11. How a common gas valve works - click here.
  12. How Ranges, Ovens, and Stoves Work
  13. Help for storing an appliance
  14. Important Disclaimer
  15. Installing a gas flex line connector
  16. Maytag, (some) Magic Chef, (some) Jenn-Air gas range surface spark module - new module kit
  17. Maytag ( Magic Chef - Crosley - Jenn Air ) gas range conversion NG to propane
  18. My gas range flames die when I turn on more than one thing at a time
  19. My Range is flashing an " F1 F2 F3 F4 F5 F7 F9 " something, what does this mean?
  20. My surface burners keep "clicking" even after the burner is light
  21. Oven door and door hinge help
  22. Oven temp sensor - how to change helps
  23. Repair tips and information on surface burner spark modules and igniters
  24. Some "how to set the self clean" on my range
  25. Stainless Steel Cleaning
  26. Surface burners wont work
  27. This morning I noticed the range top ignition was clicking all by itself every 15-30 seconds
  28. Test for F1 fault code
  29. WCI - Frigidaire ( some Kenmore's ) gas range conversion from NG to propane
  30. WCI - Frigidaire /open burners/ (some Kenmore's) gas
  31. Whirlpool Direct Spark Ignition (DSI)
  32. Yes, your glow bar igniter can glow red and still be bad!!
Posted on Apr 01, 2009
MNTECH
  • 1543 Answers
SOURCE: My GE range and oven won't go on but the oven
Sounds like you are only getting 120 volts to the range. If your house has fuses, check for one of the 50 amp ones out. Best if you have a way of testing voltage. Could be a loose / poor electrical connection at the range power recepticle where the cord plugs in, or where the cord connects to the range. Of course it could be in the range wiring or possibly in the range control, but that is not as likely. Get a voltage meter and find out where you are loosing the other half of your 240 volts.
Posted on Sep 06, 2009
  • 382 Answers
SOURCE: GE Profile Spectra Electric Oven.
call a appliance and parts store give them the tear and model number from stove it is inside the door or on back it5 mkay also be on the top under the fuse panel access door
Posted on Dec 27, 2009
SOURCE: I have a GE TrueTemp oven/range - oven is not working
I had a similar problem.The power failure might just have been a coincidence.Sounds to me like your lower oven igniter may have gone bad such as mine did.
Posted on Sep 11, 2010
Oven element burned through into half, what do i do?
Here is that element to order. There is also a video on that same page to show you how to make the repair.
GE WB44T10011 Oven Bake Element AppliancePartsPros com
Apr 03, 2014 | GE JBP82 Electric Kitchen Range
Over the Range Light Stopped Working
It is a good chance that the bulb (s) have burned out. I would think they would last longer than that but things are not as good as they used to be. Unplug the microwave before removing the bulbs. Especially if they are the screw in type. GE usually has two bulbs in there and they could be the halogen type that just plug in or the screw in type.
Mar 28, 2014 | GE Profile JTP18 Electric Single Oven
GE jvm1653sh01 range lights won't turn off
Got a short at or in the switch assembly that is causing this and unit would have to be unpowered and checked to see if one or both switches are bad.
Oct 29, 2012 | GE Spacemaker JVM1640SJ Microwave Oven
JBP82 My oven does not heat up or stops at 350. I don't see the bottom element heating up.
CHECK THE ELEMENT MANNY TIMES WHEN IT BURNS OUT YOU CAN SEE A BUMP OR BURN MARK ON THE ELEMENT. OR REMOVE POWER TO STOVE THEN REMOVE THE SCREWS THAT HOLD THE ELEMENT IN PULL IT SLOWLY AWAY FROM THE BACK WALL AND DISCONECT THE WIRES. YOU CAN USE A OHM METER TO CHECK IT IF ITS OPEN ITS BAD.
Mar 06, 2010 | GE JBP82 Electric Kitchen Range
Oven light switch shorted out.
I scheduled a GE technician to make a home visit to replace the failed parts.
May 30, 2008 | GE Profile Spectra JBP95 Electric Kitchen...
No heat at burners or oven
check your fuse / breaker box make sure you have power (sounds like you dropped a leg of power) make sure breakers/fuse is on/good flip it to off the to on if oven don't work then take a look at the cord to the range check power at the wall then open where cord goes into range check power or you may even find the cord burnt in there if so replace all damaged wires good luck
Dec 21, 2007 | GE JBP82 Electric Kitchen Range
GE JBP82 Electric Kitchen Range Logo
75 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
 Fix Your Board
Fix Your Board
Are you a Kitchen Range Expert? Answer questions, earn points and help others
