Question about Food Processors
Because leak juice jam in three press contact switches. how to loosen them
None
  • 1,511 Answers
If juice has gummed up switches then they need to be replaced. You cant clean them.
Posted on Dec 09, 2014
Prinetti
You can, if you use a kitchen towel or something for grib, pull it out... it's hard but you can ease it out one side then the other. Just be carefule not to cut yourself.
I'm actually unable to juice properly... everything just splatters around the edge even when I peel things and sandwich as the manual suggests. Any ideas why? I push down but low setting isn't strong enough, high splatters it worse, and products get moist and clogg up the mesh!!!
Jun 23, 2013 | Food Processors
My magic bullet won't press down. It stays stuck and I cannot get the cup to push down onto the turning mechanism that is totally intact. It seems the side 3 pieces will not move downward when the cup is...
Had the same problem - it wouldn't press down. The little white plastic things inside of the base that go up and down when the cup is pushed down, were stuck. I think that something leaked into them so they wouldn't slide easily. I wiped out the inside of the base with a damp cloth and then I put a drop or two of WD40 at the top of the white plastic pieces and rubbed it up and down the length of all 3 of the white plastic pieces (this being done with the base lying on its side so the WD40 doesn't drip down into the mechanism). Then, with base upright, I used a screwdriver to try to manually push the white plastic pieces down. It worked. Of course before doing any of this - be sure the thing is unplugged (duh!).
Mar 18, 2010 | As Seen On TV Magic Bullet Food Processor
Oster In2itive blender leaks
The three most common sources of leakage are a worn/damaged gasket, a cracked jar, or a cracked blade assembly - all of these parts are available from Oster. If you are still under warranty, they might even be able to send whichever part you need for free. Their phone number is 1-800-334-0759 (they are owned by Jarden Consumer Solutions nowadays).
May 19, 2009 | Oster 6710 In2itive Food Processor
None of the buttons work on my Power Prep Pulse 11-CUP
Remove the work bowl from the base of the food processor, and separate the bowl, lid, and pusher sleeve.
Plug the base into the wall outlet, turn the food processor ON, and then use a pen to press in the dark grey or black button on top of the base of the food processor - if you hear some kind of noise, then your motor is still good.
Put the work bowl on first, with the handle facing the front of the food processor.
Put the lid on, with the hollow feed tube facing the back of the processor.
Put the pusher sleeve in the lid, with the sliding lock switch facing the front of the processor.
Your processor should now turn on.
If your food processor still does not turn on, call Cuisinart and see if you are eligible for an in-warranty repair - it has a 3-year warranty.
-Tha Mp3 Doctor (also loves Cuisinart)
Mar 23, 2009 | Cuisinart DLC-8S Pro Custom Food Processor
How do i seperate the housing on a robot coupe processor
There are 4 rubber shoes on the bottom of the white or gray base. Twist & pull these out. With a TORX long shank screwdriver (nothing else works, trust me) there is a screw way down in each hole. After removing the screws a gentle but firm bump should loosen the base. If you ever need to replace the motor, on the top around the drive shaft you will see three round plugs/disks, remove them by prying up with a pocket knife (works best) this will give you access to the three motor bolts.
Feb 20, 2009 | Food Processors
Operating switch
You could try a shot of contact cleaner inside the guts of the switch. Perhaps over time some sticky residue has built up causing the switch to become frozen. Unplug the unit, spray inside the guts of the switch, work the switch back and forth. repeat unit the switch loosens up. BE SURE to use a contact cleaner that won"t damage plastics, will say on label!
Jan 09, 2009 | Food Processors
Safety-rod of bowl does not depress microswitch of Cuisinart processor
Cuisinart does not have the original pieces available, but you can order a replacement work bowl, lid, sleeve, etc that will work from the company. First do a motor test to make sure the motor is still working:
Cuisinart Food Processors – Motor Test
First, do a motor test by removing the work bowl completely and using a pen to press in the grey button on top of the base (with the food processor turned on of course), toward the back. If the processor spins, the motor is still good. At that point, I would inspect the work bowl pieces, lid, pusher assembly, etc for cracks/damage. If all appears well, insert ALL the pieces back into place and try again. If even one piece is out of place, the processor will not spin.
If it no longer spins, the motor has a problem.
-Tha Mp3 Doctor
Oct 20, 2008 | Cuisinart DLC-5 Food Processor
Food Processor won't turn on?
Food processor housings MUST be assembled in a certain order. And each part usually clicks or snaps into place. When all parts are PROPERLY assembled, the safety interlock switch will engage. Until then, no workee.
Mar 05, 2008 | Food Processors
Cusinart little pro plus
I have this food processorfor years and I love it. If you need a copy of the manual go to the Cuisinart website - they have all of the maunals listed there. But, here is the instructinos for the juicer. Good Luck. Using The Juicer
The Citrus Juicer
Attachment includes:
Strainer Basket, which
locks into processor work
bowl. It has grooved cam
on one side and smooth
locking device on opposite
side. In its center is the:
Juicer Stem Adapter,
which fits over motor shaft
of Pro Plus™.
Small cone, for lemons
and limes. It must always
be attached to Adapter
when Attachment is in use.
Slot in center of underside
fits rib on Adapter.
Medium cone, for oranges
and large cone, for grapefruits.
Both fit over small
cone.
1. Place work bowl on Pro
Plus™ base in usual way.
Hold Strainer Basket
open side up, with
locking device facing
you. Align locking device
slightly to left of locking
tab on front rim of work
bowl.
Place strainer basket on
work bowl, fitting Juicer
Stem Adapter loosely
over motor shaft. Turn
basket counterclockwise
as far as it will go, until it
clicks into position.
Turn Juicer Stem
Adapter clockwise until it
drops into position.
Check that it is down as
far as it will go on the
motor shaft.
2. Hold small cone by top
and place it over Juicer
Stem Adapter, fitting slot
over rib on adapter.
Cut citrus fruit in half and
hold cut side down over
cone. With other hand,
hold control lever in
PULSE position and
press down fruit to
extract juice. For continuous
operation, move
control lever to ON. Twist
fruit to extract most juice.
Do not allow juice to
overflow center tube of
work bowl.
To remove attachment,
remove cone from Juicer
Stem Adapter. Loosen
adapter from motor shaft
by lifting it slightly, straight
up. Hold Strainer Basket
on both sides and turn
clockwise to unlock it from
work bowl. Lift straight up.
Remove work bowl from
base and pour out juice.
Feb 03, 2008 | Cuisinart DLC-5 Food Processor
Food Processors Logo
Top Food Processors Experts
Ross Keen
Are you a Food Processor Expert? Answer questions, earn points and help others
