Question about Canon imageRUNNER 5000 Copier
Close the drawer on a Canon Imagerunner5000?
Opened the drawer to fix a jam, now I cannot for the life of me get it closed. Any kind of help with be much appreciated! Thank you!
    New Friend:
  • 64 Answers
Depending on which drawer? The machine has two LCT drawers.(large capacity tray) They use a cable lift that lifts a plate,I have seen the cable break. Its on the back of the tray. In the rail that it rides on there are two screws on either side of the tray .remove and the tray lifts straight out. If the pick up rlrs are down it won't go in. If its one of the two lower trays ? They use I lift arm that lifts the paper plate. If the the lift arm is in the up position this will keep them from going in. I have seen it being as simple as a screw that has backed out keeping the customer from being able to re install a tray. If its a arm just try resetting power. I also have seen one of the paper side fences or guides popped up and out of position cause it. Look for the oblivious and keep it simple. one of the mentioned has happened. I have seen a screw on the frame sides a screw cause it. 5000 is a older unit and the screws are loosening up. Or to long of screw put back in is possible.
Posted on Jan 06, 2015
Cogz
  • 1326 Answers
SOURCE: CANON 6085 PROBLEMS
Was it working before the problem? Did the user have a paer jam? You may have a jammed pice of paper in the paper feed unit
Posted on Jun 12, 2008
iservice
  • 318 Answers
SOURCE: Canon 3035 missing drawer options
On your computer go to the start menu,select control panel,printers and faxes,right click on the ir 3035 driver,select properties from there go to device settings.In the paper source options inable the casette unit.
Then you will be able to print from the extra cassette unit.
Posted on Mar 13, 2009
Cogz
  • 1326 Answers
SOURCE: My cannon imagerunner C3380i keeps jamming.
Make sure that the paper in the tray are set to the correct paper size. Also, the paper trays can be removed from the copier, remove them & look for any paper jammed or present blocking the paper path... Good Luck
Posted on Mar 20, 2009
  • 66 Answers
SOURCE: alarm - paper jam slide platen left - but no jam - won't copy
the paper jam is more than likely in the fuser assembly. unfortunately you will need a service tech to come out and fix that issue.
Posted on May 28, 2009
FixinFax
  • 3085 Answers
SOURCE: Canon NP7130F does not close the top cover. A small part
Sorry, it is not worth fixing.
Posted on Jun 14, 2010
Canon ir-adv c5240i when there is no jammed paper it shows me paper jam how do i fix it fixya - did not match any video results.
Make sure you have opened the drawers and opened and closed all the doors. Look for little levers and light sensors throughout the machine to see if any of them are blocked by a torn scrap of paper.
Jan 20, 2017 | Canon Office Equipment & Supplies
How can i fix paper jam, close left cover or drawer cover ir 2016 canon
hi . be sure there is no paper jam inside the machine . turn off and on if problem persist maybe some of the flag sensors maybe stuck.
Mar 23, 2016 | Canon iR 2016i Black and White Copier
I have this error codecode e000 and 0105 under when i turn on my Canon CLC 1180. where was the fuser user in the CLC? How can i check it?
I think the 1180 is close to the 1120 copier I know. The error code is indicating an upper heater open circuit. The fuser is the very left item when the main drawer is pulled opened to remove a paper jam. There are two handle grips front and rear to remove the assembly. You have to check continuity of the heat lamp, fuses, etc.
Jun 13, 2011 | Canon CLC 1180 Copier
Can not get the copier to pull paper from the top draw with out jamming each time.
first, pull out the top drawer and open the right lower cover and door. now if you look into the "hole" where was drawer, on right side you will see the 3 rollers that pick, feed and separates the paper.
Remove all rollers and clean them with alcohol and dry them out, or change the places with rollers from lower drawer. Also when the right door are opened you will se two axis with two rubber rollers, clean them very well.
The iR2270 has issues with pressure on lower right cover and you need to put the rubber or similar in wide and narrow slot on lower cover, so that when its closed presses the inner paper guide which touches the rollers on axis. If You already have metal "wings" on lower cover, you don't need to apply any additional pressure.
But necessarily change the roller for paper of both cassete's and in fixing unit the fixing cleaning roller.
Hope that helps!
Mar 22, 2011 | Canon imageRUNNER 2270 Copier
Canon MX860 Rear Paper Jam
I have a small piece of paper jammed in my Canon MX-860 that Cannot be seen from anywhere. Can you help me find so I can clear it
Jun 27, 2009 | Canon Office Equipment & Supplies
My CD drawer will not open or close
I had a mini system with the same problem, out of guarantee so was either fix it myself or bin it.
I opened the unit and removed the whole cd drawer assembly from it's housing. I then, not really recommended, plugged it back in and by pressing the open/close a few times the drawer finally opened. Put it all back together and it now works fine. I think what had happened is that I use the cd player once every couple of months and combined with the lack of use is the fact that there are several smokers in the living room and basically it got jammed by a build up of nictotine or whatever.
Apr 01, 2009 | RCA 5-cd 300w Stereo System Shelf System
Canon printer error 073
The transfer drawer connector or the transfer frame drawer connector is not connected as the front door is closed.
Nov 04, 2008 | Canon imageCLASS 1100 Laser Printer
CANON 6085 PROBLEMS
Jun 08, 2008 | Canon NP 6085 Copier
When attempting to print, I receive an error message which states "Inner conver is open. Close the inner cover and press OK". However, the inner cover is closed...? I have opened and closed...
Are you looking at the canon error window picture that show up on your monitor: It is the front inner flap you see after you open up the two top "covers". I forgot I opened this one looking for a paper jam. The printer cartridges would not even move to the front with this flap opened. After I closed the inner flap it all works (after opening and closing the top two "covers" many times!
Apr 16, 2008 | Canon PIXMA MP830 All-In-One InkJet...
CD drawer stuck, then won't close
1. Most of the player drawer fixed over the chasis for a rigid support
2. try to remove the drawer safely without damagind the chasis and drive mechanism
3. there might be some shaft jam.
4. Look for the thread. how does the player drawer moves in and out
5. there may be some sensors to sense the door close/open. if it is jammed then open/close function cannot be done. why because this problem occurs
6. unwear the mechanism read the mechanism moving technique. see which has got jammed.
7. if you feel too risky then
8.contact service centre... all the best
Dec 21, 2007 | NAD L40 CD Player
Canon imageRUNNER 5000 Copier Logo
57 people viewed this question
old marine
old marine
