Question about Lands Phones
Why can i not receive incoming calls on my c4220+ phone?, rings and when answered its as if no one is there, sometimes works if i hit talk twice
Removed batteries, for at leasr half hour and reinserted batteries
SOURCE: UNIDEN 5.8 GHZ CORDLESS PHONES
Registering Handsets to the Base
Whichever handset you choose to charge in the base is automatically
registered to the base. Any additional handsets must also be registered to
the base before you can use them.
Be sure both handsets are fully charged.
One at a time, place each handset in the base. The charge/in use LED on
the base begins to flash, indicating the base is registering the handset.
Wait for at least five seconds, then pick up the handset and press
[talk/flash]. If the display shows TALK, the handset is registered. If not,
place the handset in the base to try again.
Press [end] and continue with the next handset.
Note:
Once both handsets are registered, it doesn’t matter which
handset is placed in the base or the charger.
When you charge the handsets, Caller
ID summary screen and the name of
the handset appears.
This can be find from uniden website.
http://www.uniden.com/pdf/DXAI4588-2om.pdf
Posted on Jul 08, 2008
SOURCE: receiver dosen't pick up line that is ringing
go to programming section 5
You want Automatic Line Selection
Press feature00
left intercom button press twice (system program)
press right intercom once (central tel program)
enter # of extension to be programmed (intercom #)
press **
press line buttons in desired order line1 line 2 etc and
end with left intercom then press**
enter feature 00 to exit programming
Dave
Posted on Oct 17, 2008
SOURCE: phone doesn't ring on incoming calls
i cannot fix the number of times for the ringer on my vetch phoneset
Posted on Oct 19, 2008
  • 37 Answers
SOURCE: Disconnects incoming calls after one ring
The problem may be a short on your line. (Have the local Teleco check your line.) If you have other phones, you may want to check them for dial tone(DT) when this happens. If you have no DT, your cordless may be the problem...unplug, and let charge overnight. If problem continues, replace the battery in cordless, or discontinue use.
Posted on Apr 29, 2009
SOURCE: phone won't ring with incoming calls
I just bought a new Uniden DECT 6.0 phone and had a similar problem. It wouldn't ring when plugged into my Linksys voip router, but my old 5.8 GHz did ring. It would get a dialtone and make calls, but when called via an outside line, it would appear as if it was ringing. If I picked up during this "silent ring," it would answer and take the call. It wasn't a ringer volume issue. I called tech support, they said on the main headset, unplug the battery, then unplug power from the base, then unplug the phone cord from the base. Wait 15-30s. Plug the phone cord, then power, then reinstall the battery. Press the End button on the phone. Put the phone on the base for 15-30s. Pick up the phone. Press and hold the Find button on the base. Do this Find thing 3 times. Put the phone back on the base. Wait 10-15 minutes. Then try calling it to see if it rings. Worked for me, finally got it to ring before I decided to return it.
Posted on Jan 13, 2010
Receiving faxes whilst connected to a phone line automaticly
Check video for 'fax receive set up' in similar model:
Manual receive: In coming call receives like telephone
Fax/tele: Incoming call rings like telephone if its not fax, if incoming is fax it will entered in fax mode automatically
Automatic: Incoming call converts in fax mode after ring count ends( ring to answer option also avail in fax set up mode rage 1-6 rings)
Fax: Incoming calls straight away converts in to fax mode.( this option only for dedicated fax lines)
Set up your best option as per your requirement.
Nov 29, 2012 | HP LaserJet 3050 All-In-One Printer
Auto dail in calling mode
maybe your green button (receiving button) is very sensitive, make sure to didn't type twice and typing when are you talking to someone by your face.
if my solution was helpful please rate my answer.
Jul 03, 2012 | Samsung star II duos GT-C6712
How do I set up the fax feature?
Introduction The HP All-in-One can receive faxes automatically or manually depending on the Auto Answer setting. If the Auto Answer option is set to On (the default setting), the HP All-in-One will automatically answer incoming calls and receive faxes after the number of rings specified by the Rings to Answer setting. (The default Rings to Answer setting is five rings). Refer to the given instructions to receive faxes automatically or manually. Receiving faxes The HP All-in-One can receive faxes automatically or manually. Receiving a fax automatically To receive faxes automatically, set the Auto Answer option to On (the default setting). The HP All-in-One will automatically answer incoming calls and receive faxes after the number of rings specified by the Rings to Answer setting. (The default Rings to Answer setting is five rings). Receiving a fax manually If the HP All-in-One has been set up to receive faxes manually (the Auto Answer option is set to Off ), or you answer the phone and hear fax tones, use these instructions to receive faxes.
  1. Make sure the HP All-in-One is turned on and you have paper loaded in the input tray.
  2. Remove any originals from the document feeder tray.
  3. Set the Rings to Answer setting to a high number to allow you to answer the incoming call before the HP All-in-One answers. Or, turn off the Auto Answer setting so that the HP All-in-One does not automatically answer incoming calls.
  4. If you are currently on the phone with the sender, instruct the sender to press Start on their fax machine.
  5. When you hear fax tones from a sending fax machine, do the following:
    1. Press Start Fax Black or Start Fax Color on the control panel of the HP All-in- One.
    2. When prompted, press the down arrow to highlight Receive Fax Manually , and then press OK .
  6. Press Start Fax Black again.
  7. After the HP All-in-One begins to receive the fax, you can hang up the phone or remain on the line. The phone line is silent during fax transmission.
    Trust this is helpful. Please vote. :)
Dec 11, 2010 | HP Photosmart C7280 Laser Printer
What is answer mode?
The answer mode determines whether the HP Fax answers incoming calls or not.
Different answer modes are :
* Fax
The HP Fax will automatically answer all incoming calls using the Rings to Answer setting. This is the default setting.
* FaxTel (unit with handset model only)
The HP Fax automatically answers all incoming calls using the Rings to Answer setting. If the call is a fax call, the HP Fax will receive the fax. If the call is a voice call, the HP Fax will create a special ring to indicate it is a voice call. The incoming voice call will need to be answered using the attached handset.
NOTE: If the HP Fax determines the call is a voice call, only the HP Fax will ring with the special ring tone. The other phones on the same phone line will not ring at all. You will not be able to pick up the voice call using the other phones.
* Tel
The HP Fax will not automatically answer calls. Faxes will need to be received manually.
* AnswerMachine
The HP Fax will monitor the line when an incoming call is answered by a person or by the answering machine. If the HP Fax detects fax tones on the line, it will receive the fax.
Jun 07, 2010 | HP Officejet 4315v All-In-One InkJet...
I want the fax to work with an identa ring. How do I program this? As it is now I have to turn on the fax to receive. Does this HP work with identa ring?
The following set up assumes you have one conventional phone line, but two different phone numbers. One being your regular phone number and the other a distinctive ring for your fax machine
If that is what you have then this is how you set up the phone. Its important to know what type of distinctive ring your phone company will send to your phone. If it doesn't work you can talk to them about getting a different one than their default distinctive ring.
2 Set the HP all-in-one to answer incoming calls automatically.
Press the Auto Answer button until the light is on.
3 Change the Answer Ring Pattern setting to the pattern that has been assigned to your fax number by the telephone company, for example, double rings or triple rings.
For information on changing this setting, see Change the answer ring pattern
(distinctive ringing).
Note Your HP all-in-one is factory-set to answer all ring patterns. If you do not set the correct ring pattern assigned to your fax number by the telephone company, your HP all-in-one might answer both voice calls and fax calls or it might not answer at all.
4 (Optional) Change the Rings to Answer setting to one ring or two rings.
For information on changing this setting, see Set the number of rings before answering.
5 Run a fax test. For information, see Test your fax setup.
Your HP all-in-one will automatically answer incoming calls that have the ring pattern you selected (Answer Ring Pattern setting) after the number of rings you selected (Rings to Answer setting). Then it will begin emitting fax reception tones to the sending
fax machine and receive the fax.
If it is easier or you want to know other options which may be more applicable to your phone setup. You can find that information here.
http://h10032.www1.hp.com/ctg/Manual/c00235090.pdf
Jul 09, 2009 | HP OfficeJet 7310 All-In-One InkJet...
Cannot receive auto faxes
This is a known problem with the MX850 - Canon thinks it works, but it needs to be FAX Only when you're out of the office and TEL PRIORITY when you're in the office - then you hit "Hook" when you hear an incoming call as a fax tone. It's a manual answer machine when in TELEPHONE Priority
Mar 18, 2009 | Canon PIXMA MX850 Multifunction Printer
Canon MP530 receive fax issues
Receive Mode Settings Select from the following receive mode options to suit your needs. Once you've decided on which receive mode to use, follow the below instructions to set the receive mode using the operation panel. Receive Mode Setting
  1. Press the <FAX> button to enter Fax mode.
  2. Press <Menu>.
  3. Press the right or left arrow button to select [Receive mode settings], then press the <OK> button.
  4. Press the up or down arrow to select the receive mode that best suits your needs, then press <OK>.
Types of receive mode
Select the receive mode according to your needs.
Receive mode
Purpose
FAX/TEL AUTO SW When you want to receive faxes automatically as well as voice calls. FAX ONLY MODE When you want to receive only faxes automatically with your machine, or have a dedicated telephone line for FAX use only. DRPD When you have subscribed to a DRPD service with your telephone company. MANUAL MODE When you receive mainly voice calls and sometimes faxes, or want to receive faxes manually. ANS.MACHINE MODE When you want to receive voice messages on your answering machine and receive faxes automatically. FAX/TEL auto switch
FAX :
The machine does not ring but will receive the fax automatically. Voice call :
The phone attached to the machine will ring. Pick up the handset to answer the call. Note:
  • Ring start timing and Telephone ring length can be specified in FAX/TEL auto switch in the Receive mode settings.
  • If you want the telephone to ring when it receives a fax, connect a telephone to your machine and enable the Incoming ring settings in RX settings.
  • The phone attached to the machine may not ring depending on the telephone type you are using.
FAX only
FAX * :
The telephone does not ring. The machine will receive the fax automatically. Voice call :
You will not be able to answer the call. * If you want the telephone to ring, connect the telephone to your machine and enable the Incoming ring settings in RX settings menu.
DRPD
FAX :
Your telephone line will ring according to the ring pattern you have chosen and receive the fax automatically. Voice call :
Your telephone line will ring according to the ring pattern you have chosen. Pick up the handset to answer the call. Note: Specify the FAX pattern in the DRPD: Set FAX ring pat. in RX settings menu.
Manual RX
FAX :
The telephone attached to the machine will ring. Pick up the handset and if you hear a beep tone, press the <Color> or <Black> button on the machine to receive the fax. Voice call :
The telephone attached to the machine will ring. Pick up the handset to answer the call. Note: If you are far from your machine, you can use the remote receiving function to receive faxes. Pick up the handset of the telephone connected to the machine and press 25 (the remote receiving ID).
Ans. machine connect
FAX :
First the answering machine connected to your machine will respond to an incoming call, and then the machine will receive faxes automatically. Voice call :
The answering machine connected to your machine will respond to an incoming call. Note:
  • Set the answering machine to answer on the first or second ring.
  • The entire message should be no longer than 15
Nov 24, 2008 | Canon PIXMA MP530 All-In-One InkJet...
Receiver dosen't pick up line that is ringing
Press feature00
press **
Dave
Aug 26, 2008 | Avaya Corded Phone avaparp18d
Tapping the answer button does not answer the phone
I had the same issue until I realized that I was touching the button twice,- first answering the incoming call, then immediately hanging up!
When you first tap the button there is a slight delay and the incoming call seems to be still ringing but you've really already "answered" it. Just tap once, be patient a couple of seconds and say"Hello". Your caller will be there!
Dec 12, 2007 | Motorola Mobility H500 Wireless Headset
Lands Phones Logo
Top Lands Phones Experts
Computer Repairing
Computer Repairing
Are you a Lands Phone Expert? Answer questions, earn points and help others
