Question about Sunbeam Kitchen Appliances - Others
I need the little rubber feet on the bottom of the base where can I buy them at?
Can i replace base "feet" on singer 338 sewing machine?
many home improvement stores sell rubber feet that you could glue or screw on .
Feb 12, 2017 | Singer Sewing Machines
How to replace Frigidaire Range model FPDS3085KF Grate Rubber Feet
Hello Friend, I am happy to assist you!
I understand you are looking for instructions on how to replace the rubber grate feet on your Frigidaire range, FPDS3085KF (part number 5304475129). You can do this by removing existing rubber feet. Then clean and remove any residual adhesive. Typically adhesive is provided with new rubber feet kit. Apply adhesive to bottom of rubber feet and install rubber feet on bottom of grate. Most parts can be purchased directly from the manufacturer or through a parts distributor in your area (part numbers may vary based on distributor). I hope this proves to be helpful to you! - Z
Jun 04, 2014 | Frigidaire FPDS3085KF Stainless Steel Dual...
One of the bottom aluminum and rubber feet on which the subwoofer sits has gone missing, where can I get hold of a replacement Thanks
Unless you contact the parent company its close to impossible to get that feet. But you can buy a set of four rubber feet at any hardware store and replace them all.
The feet come off when one tries to push a heavy sub like Velodyne instead of lifting it off the floor and placing them . The rubber grip is so good on the floor and when we push the top part of the Sub the feet rip off.
Jul 29, 2011 | Velodyne DD-15 Subwoofer
I have a Meade ETX 80AT telescope that only slews left or right intermittently. Is there any way that I can get into the base for a closer look as to why this is happening. many thanks
Yes under the rubber feet on the bottom are three screws -- take them out and you can get into the bottom. peel of the rubber feet to expose the screws.
Jan 09, 2011 | Meade ETX-80AT (240 x 80mm) Telescope
I wish to know how to open a Roland JUNO-D synth to access the little rubber strips with the key contacts; I have the typical key-not-sounding problem.
Usually there are a number of screws from the bottom to remove. SOmetimes they hide some under a label or rubber feet. The top should remove and pone must be careful of the cables from teh top to the base of the unit.
Keep track of where screws go as often they have different length and using the wrong length when re-assmbling caan cause trouble.
Aug 07, 2010 | Roland JUNO-D Synthesizer
My phone base seems to slide around on the table how can i secure it...
buy some rubber feet from the hardware store, they stick on the bottom, or try the rubber drawer liner.....
Jan 07, 2010 | Panasonic KX-TG5632 Phone
How do we get the original xbox open to blow it out & reseat the cords?
6 Screws located Underside ( 2 under Silver Warranty Stickers ) Void if removed. And the other 4 Are located Under The 4 X Rubber Feet on the Base.
Turn Over Lift The Top Off.
Mike @ compurepair.
Nov 05, 2009 | Microsoft Xbox Console
I am looking for the little rubber feet for the grates of my Kenmore gas range Model 36275980890
Rubber feet for kenmore gas oven range, These are rubber plugs that fit into the bottom of the grate and are shaped like upside down mushrooms. There are 4 of them for each grill. The part number is wb2k101 from sears (special order). Cost is about $5 for a bag of 4 rubber feet.
Jun 04, 2009 | Kenmore 79012 / 79014 / 79019 Gas Kitchen...
Holmes HM5601 quit working
I had the same problem with my Holmes HM5601 humidifer unit - right out of the box. I almost returned the unit to the store, but was able to figure-out the problem. Not enough water had been filling the heating section (where that black knob-like protrusion is) and the lack of enough water had caused the unit to shut-off soon after plugging it in. The problem is in valve at the bottom of the water tank! The valve is a factory defect. It needs to open more when you sit the water tank onto the base so water fills the reservoir. I had solved the problem by going to the hardware store and purchasing some small, rubber pads or feet. These rubber pads are the type used to place under things where you want to protect a table-top from being scratched or you want the item not to slide too easily on a table-top. These rubber feet or pads have an adhesive on the bottom of them. Find the size that matches the diameter of the valve stem on the bottom of the water tank. Once installed, the valve should open and close with your finger without the rubber pad interferring with the operation of the valve. The pad, if installed properly, makes contact with the water reservoir base when you placed the water tank down onto that base. The valve open a bit more allowing water to pass-thru and fill the water reservoir. Water fills the heating section as needed and the unit runs perfectly after! The round rubber pad I had used was about an 1/8 inch thick and 1/2 inch in diameter.
Nov 30, 2008 | Humidifiers
Top part of base broke off
This just happened to me too, and I think I just fixed it.  First you have to get a replacement part called the "blender coupling" (I got mine online from Goodmans for $3.99).  I also replaced the square drive and slinger (two parts come together for $2.99)-that's the little part that sticks up and attaches to the pitcher.
Unscrew the bottom four screws of the base where the rubber feet are.  Remove the rubber skirt to reveal four screws that hold the motor in.  They are way in there so you'll need a long screw driver.  Remove the motor and unscrew the old coupling.  Mine had not been replaced since my grandmother bought this blender who knows when, so the coupling was really stuck.  I did not have a tool narrow enough to get a good grip to apply enough torque to remove the coupling so I had to try a few other tricks.  If your blender is the same, remove the bottom nut, fan blade and two washers.  This gave enough of a rod to grip to get the old coupling off.  (I also had to use some WD40, and heat and cool the coupling a few times to break the old seal).
Good luck!  Hope that helps!
Jan 09, 2008 | Oster 465 Work Top Blender
Kitchen Appliances - Others Logo
Top Sunbeam Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Are you a Sunbeam Kitchen Appliances - Other Expert? Answer questions, earn points and help others
