Question about Plumbing
How do you get to pump seal on a daisy 880 model, when pumping wont build pressure
  • 16 Answers
SOURCE: pwr steering pump failure GM truck
check to see if truck has a power steering pump cooler try to bypass cooler sounds like it has a blockage in the cooler not allowing fuild to circulate should fix problem
Posted on Nov 26, 2008
  • 32 Answers
SOURCE: annovi pump wont build pressure
try force feeding the pump first, this can help to clear any dirt which might be in the valves.
you have 6 valves which are all the same , but 3 are suction and 3 are for pressure.
just take them out and put under a slow dripping tap and fill with water, if the water holds inside the valve will be ok, if it leaks just check for dirt.
hope that helps
Posted on Jul 04, 2009
slave2aslave
  • 302 Answers
SOURCE: Can I order the free instruction manual for the
www.pyramydair.com
Try there for starters.
Hope this helps.
Posted on Sep 22, 2009
  • 10 Answers
SOURCE: water pump
Try cleaning the jet.
Posted on Oct 24, 2009
  • 5 Answers
SOURCE: cannot get daisy 880 air riffle to hold pressure,
Read through this https://daisymuseum.com/forum/forum_posts.asp?TID=3519&PN=1
Posted on Jan 15, 2010
Testimonial: "Thank you for your advise, it was helpful and I am glad there is a place to find answers and help. Keep up the good work."
880 daisy does not hold pressure when pumping
Seals are leaking and need replacement.
Sep 14, 2017 | Optics
Where can I get repair parts for the daisy 880
http://www.ebay.com/itm/Daisy-Powerline-7880-880-35-880s-Rebuild-Kit-Reseal-Seal-Gun-BB-Air-Rifle-Set-/151539675066
Oct 27, 2015 | Toys
After pumping up the rifle it had very little pressure
The piston seal has failed, or the pressure valve. Daisy manufactures in China now. If its a Red Ryder or other cheapie, then its a spring loaded gun and additional pumps do nothinga
Feb 18, 2011 | Daisy Toys
Model 880 Model 880 You cannot get it to pump up.
Chances are good that the internal pump seals are dryed up and need to be replaced. You might be able to hold the gun inverted (read upside down) then open the pump lever and inspect the inner metal tubing. You may see a "oil" marking here which will help those seals out.
Jan 12, 2011 | Daisy Toys
My model 822 wont pump and it sounds like th air is comeing out of the reciever when you do try to pump it
Hi, You may have to replace the seals or O'rings.maybe both. Who makes the 800? Daisy or crosman?I have a list of companys that service airguns.Please write me back and tell me.Hope I can help you out.Joseph A Bagli.
Feb 15, 2010 | Crosman Optics
Very hard to pump
It needs lubricating. Take it apart, clean it, then put machine oil on the moving parts and seals. If seals are damaged they need replacing. And, please only use it for target shooting.
Apr 30, 2009 | Vacuums
Plumbing Logo
Top Plumbing Experts
Donni Steen
Tom Chichester
Are you a Plumbing Expert? Answer questions, earn points and help others
