Question about Husqvarna Garden
I need owners manual for husqvarna 445 chain saw
How do i remove the carburator
Here is the illustrated parts manual for your saw. it explains how to strip the saw down and everything you need to know. Please click the 'helpful' tab if you find this useful. Thank you
http://www.mediafire.com/download/n25qmj9j7venncu
May 15, 2016 | Husqvarna 445 18" 45.7cc Gas Powered Chain...
How do I sharpen the chain
There are plenty off the shelf devices to aid chain sharpening, Husqvarna do a simple roller gauge, easy to use and very effective.
May 29, 2012 | Husqvarna "Chain Saw - 16" Bar, 3 Hp
Hi i have a Husqvarna 445 18" 45.7cc the automatic
Verify you have oil in the oil fill tank. Try cleaning inside the drive sprocket cover. Release the chain tension and carefully dislodge the bar and chain assembly. Clean sawdust and debris from behind and inside the housing and behind the bar. Use a wisker wire to clean the through ports and channels on bar( these ports are the path that the oil travels to the drag groove that the drive links on the chain uses to pull the oil to the tip of the bar).
Please refer to this link below for your saw maintenance-
http://www.chainsawsdirect.com/manuals/HUSQ_445_MAN2.pdf
If this does not correct the problem contact Husqvarna customer service or a local service repair.
May 13, 2011 | Husqvarna "Chain Saw - 16" Bar, 3 Hp
Trying to find an owners instruction manual for Husqvarna E. series 450 , 16 in gas chain saw.
Umm. Husqvarna makes both sewing machines and chain saws (good ones). But this needs to be posted in a category other than sewing machines. I would suggest "Home & Garden/Patio & Garden" as the most likely one I could find for you. Good luck.
Jan 26, 2011 | Husqvarna Sewing Machines
I need french manuals for my chain saw model 235 and registration quick start guide is english only
You can download the owners manual in French at this helpful website:
http://www.husqvarna.com/ddoc/HUSO/HUSO2011_USen/HUSO2011_USen__1154210-49.pdf
Oct 12, 2010 | Husqvarna "Chain Saw - 16" Bar, 3 Hp
Model 445 chainsaw. Was cutting all day and no problem. Good gasoline, Husqvarna 2 cycle oil. All of a sudden started racing like the carb was stuck full open even when throttle trigger released. Then...
Engine speeding up on idle is normally due to an air leak, check the carb securing screws are tight, if you have a leaking crank seal it will be a shop repair.
Feb 28, 2010 | Husqvarna Forest & Garden #966906636 445...
I have a Husqvarna 445 chain saw and it does not get enough oil to the bar and chain. I have to stop saw after about 10 minutes of cutting because it freezes the chain so I remove bar and chain clean out...
Your Manual nor IPL mention an oiler adjustment..
445 IPL (may not be your saw)
Is this the original bar? A longer bar requires more oil and your saw is not equipped to supply it.
http://weborder.husqvarna.com/order_static/doc/USA/2007/I07000/I0701086.pdf
Detail B (Clutch/Drum/Oiler)
We are seeing many of these does not oil/oils to much problems with these no adjustment models. I recommend you contact Husqvarna, there may be an unannounced recall/repair. If they aren't willing to help you consider contacting your Atourney General and the BBB.
Contact Husqvarna here:
http://www.husqvarna.com/us/homeowner/support/customer-support/
It has an outboard clutch, the oil pump is behind it. If you attempt a repair this will be helpful.
R² Drive Link Outboard Clutch by Drivelink.blogspot.com
http://www.youtube.com/watch?v=cdqkIuVNUQc
  1. Check the IPL for your saw to see if any special tools are needed.
  2. There are metal piston stops available, when square (almost never) with the piston top these work well, if not square they have been known to punch through the piston. I suggest a length of starter cord or nylon rope be used instead of the piston stop (retain 6" ± so you can remove it). Make sure the piston is near the top of the cylinder before feeding the cord or it can fall through the exhaust port and damage the piston as it rises.
  3. Everyone I’ve ever removed had a left handed thread (tighten it to loosen it).
    Let us know how it worked for you.
Source for Manual and IPL:
HusqvarnaUSA.com
http://www.husqvarna.com/us/homeowner/support/download-manuals/
Enter the 3 digit model number (no XPs, Es, just the numbers)
Serial number decode – for use with IPL
06 1500198
06 = year produced – 2006 (single digit before 2000)
15 = week produced - March
00198 = 198th unit Husky produced that week
Nov 24, 2009 | Husqvarna Chain Saw 20" Bar
Changing the chain on husqvarna 445
make sure the chain brake is off. Then undo the two retaining bolts and take the cover off.
Sep 19, 2009 | Husqvarna Forest & Garden #966906636 445...
Garden Logo
122 people viewed this question
Top Husqvarna Garden Experts
Phil Walker
Phil Walker
Roland W VanLue
Roland W VanLue
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
