Question about Plumbing
How do I reset my motionsense
New batteries
Neither the wave sensor nor the ready sensor will turn the water on.
I would return back to the place of purchase and get a different brand of faucet.
Dec 05, 2015 | Moen 7594EC Arbor Single Handle/Hole...
Motionsense stopped working on faucet. Replaced batteries and reset. Still not working. It was installed in Feb of 2014. Any suggestions????
Contact the person that installed it, it should be under warranty. A quick check would to be sure the batteries are good and installed properly.
Jun 16, 2014 | Moen 7594ESRS Single Handle Kitchen Faucet...
Handle dome keeps coming off
Sounds like the setscrew that holds it on has either worked lose and is missing or is striped and no longer tightens properly. Replace set screw if missing and or replace set screw if the set screw is striped. If the threads are stripped in the faucet body the faucet itself will need to be replaced. This usually does not fall under Moen's warranty guidlines.
Mar 29, 2014 | Moen 7594EC Arbor Single Handle/Hole...
No water
No water, there is a host of problems that can cause this.
1. no water to the faucet
2. Sensor is not working
3. clogged water port
4. Dead battery for sensor
Does the faucet work on manual mode?
If not remove cartridge and check for debris. Flush out faucet before replacing cartridge to make sure water is getting to faucet. Replace cartridge. Check debris screens on pull out handle. There are a number of other things that could be wrong but first try the simple and report back on your findings.
Mar 20, 2014 | Moen 7594ESRS Arbor Single Handle/Hole...
How do remove the faucet cover of a moen 7594EC
MOEN Motionsense Faucet Leaking????
Turn off the water valves beneath the sink. Cover the openings to both the drain and the garbage disposal. Use an allen wrench to remove the tiny screw holding the handle in place. Once the handle is removed, the leaking is most likely from the seams around the large plastic nut behind the metal-like plastic cover. You might be able to see water dripping from around the big nut. Remove the nut and wrap nylon plumber's tape (Costs probably around a buck at any hardware supply store) around the threads for a much better seal. Wrap the tape tight at least a couple of times around the threads.
Screw the nut back into place with your hand, then tighten with a wrench.
Place the cover back over the assembly, install the handle. You can apply clear nail polish on the threads of the tiny allen screw that holds the handle in place to minimize the risk of it coming loose and falling into your garbage disposal.
Jan 19, 2014 | Moen 7594EC Arbor Single Handle/Hole...
I have a UPS Smart 5000va model :surtd5000xli I replaced all new battery for ups but when i started ups all leds in the battery column litting .I want to connect ups and pc to reset new battery (this ups...
Unplug your UPS from the wall. Disconnect the batteries. Push the on button. LED's may flash. This is how to reset the logic. Connect the batteries and plug back in. Everything should be reset.
Aug 03, 2011 | APC Smart-UPS RT 5000VA (SURTD5000XLI) UPS...
My Keyboard is brand new. We have replaced batteries, and pushed the reset button for 30 seconds, the indicator does not register new batteries or any batteries at all. Reset was synchronized with reset...
Possible reasons for no power to keyboard...
Batteries in wrong direction. Check orientation of each battery.
New batteries are actually bad. (replace)
Positive terminal is obstructed by packing strip (remove packing strip from batt compartment)
Positive nipple is too short and cannot reach terminal. (try a different brand battery)
New Keyboard is defective. (return to store for exchange)
Mar 08, 2011 | Computers & Internet
2004 bmw 545i dead battery had dealer install new battery now i have 2nd gear jerking with my autotransmission
LMAO take it back to the dealer and tell him to reset the ECM since he was stupid enough to onhook the battery and not reset it!
Jan 13, 2010 | 2004 BMW 5 Series
Plumbing Logo
67 people viewed this question
Top Plumbing Experts
Tom Chichester
Gil Shultz
Are you a Plumbing Expert? Answer questions, earn points and help others
