Question about Irons
Steamglide 2200 not heating up fuse ok
Checked fuse
  • 1,511 Answers
The internal element may have shorted out and thus the sole plate with heating elements will not operate any longer. The cost of repair exceeds the cost of replacement.
Posted on Dec 09, 2014
My tefal keeps tripping elcb in fuse board what could be wrong
Next time it happens and it trips.. use a dry towel to unplug kettle, just in case.
Is the base wet? Check the kettle for cracks. Check the cable. Is it damaged? Try replacing the fuse in the plug. Is the steam that the kettle produces affecting lighting or other electrical items around it? Try moving the kettle to a different location.
Aug 05, 2015 | Tefal Irons
Get the red light off, no heat and so no steam.
check main wire or main plug of wire
Dec 22, 2014 | Irons
How can I replace thermal fuse on steamglide iron?
If you are comfortable with working on mains appliances then have a look at this forum post on how to replace the thermal fuse.
http://mendmy.com/answers.php?id=78119
Aug 17, 2014 | Russell Hobbs Irons
Rowenta Dz9080
Check or replace fuse in plug. If that don't do it, then change fuse inside iron. Make sure iron is not plugged to supply.
Apr 28, 2013 | Irons
Iron not working no power nolights
check the circuit breaker in the main fuse box in case a breaker has tripped.
check the fuse in the power plug, if it is no good replace it.
Try the iron in another socket /outlet in case the one you are using is faulty.
Jan 23, 2013 | Black & Decker D6000 Iron
Our Tefal Aquaspeed110 Iron will not turn on when we plug in the power chord. Is there a fuse that needs to be replaced? If so, where may we get one and where in the iron do we find it please? Karl...
Majority of the iron don't have fuse, you should check the plug and cord. Often it is become open meaning no continuity circuit, no heating. To be able to check it unplug, you should use a analog tester. Also check thermostat dial control, when it is not in right adjustment it is also cause a no heating symptom.
Good luck.
Jul 17, 2011 | Tefal Aquaspeed 155 Iron with Auto...
Will not power up
First thing you have to do is to check the power cable if it is okay, the power cable normally have fuse which you have to check, if otherwise you have to open the Iron to check for the faulty part, The Iron consists of three parts namely the element, the thermostat and the fuse, so check the one after the other with the use of a multimeter to which is bad or not in which it will be replaced...
Hope this will helpout in solving the problem....
May 17, 2011 | Euro-Pro Shark GI490 Iron
Irons Logo
59 people viewed this question
Top Irons Experts
Are you an Iron Expert? Answer questions, earn points and help others
