Oce cm 3522 has error code c-1183
Says open front door and try again
Josue Pongco
  • 154 Answers
SOURCE: IT COMES UP WITH ERROR CODES: 3609
It means that the Printhead needs to be replaced. call Kodak 1800 421 6699
Thanks
Posted on Aug 17, 2009
SOURCE: OCE TDS600 Error Codes
It might need a new fuse which is located where the hot wires are when the paper feeds through or it might need a circuit an Ormon G3NE-220 TL-US load 20A 240VAC 50/60hz input 24 VDC.
Posted on Aug 31, 2009
  • 990 Answers
SOURCE: Error code E020 0181 on oce cs115 how do we remove the code
Hello sir; Try to replace yellow color developer and then running"stir" or "install". should removed the error code.
Posted on Oct 10, 2009
Kevin Hayes
  • 167 Answers
SOURCE: error code 2152
Trans belt retraction failure. Its a common error that can be reset by opening and closing the front door with the machine on.
Look in the trouble history and if has happened often, better order a new belt.
Posted on Jan 06, 2010
  • 1297 Answers
SOURCE: Getting a malfunction code c-0096 on my oce printer
The error code refer Transfer belt separation.Check the transfer belt unit.
Posted on Feb 05, 2013
My oce fx 2081 trouble code 05 help me pleas
OCE clear error message replace toner oce fx 2081 ... - Fixya
www.fixya.com/tags/clear_error_message_replace...oce_fx_2081/.../oce
Ask your Clear error message replace toner OCE fx 2081 questions. ... ...error code0501 message, though we've vacuumed it the toner as best as possible. ... ...error 2201 switch on/off messages very frequently on my oce 9400 machine, any solution!!! thanks Might be NTC6, which is located in ... 05 is appearing on the.
clear error message replace toner oce fx 2081 Questions ...
www.fixya.com > Forum > Tags
Find solutions to your clear error message replace toner oce fx 2081 question. ... ...error code 0501 message, though we've vacuumed it the toner as best as possible. Well ... ...error 2201 switch on/off messages very frequently on my oce 9400 ...
Sharp ARM 550/620/700 Reset Machine with Error Code ...
Dec 15, 2015 | Office Equipment & Supplies
I cannot get my oce fx3000 printer to print
After you install the New Drum unit you need to reset the drum counter to be able to use the Oce FX3000 again. Open the front door cover (the one you open to replace the drum or toner ctg.) On the control pabel hit the clear/back key. The display should say something like reset drum? Hit 1 for yes, close the door and you should be up and running again.
Oct 08, 2014 | Canon Genuine Oce Imagistics Fx3000...
Oce tds error code 12502
Error 12501, Error 12502, Error 12503, Error 12504, Error 12505, Error 12506, Error 12507, Error 12508, Error, 12509, Error 12510, Error 12511, Error 12512, Error 12513, Error 12514, Error 12515
Error codes related to External Paper Input Module
Oce VarioPrint 110
Oce VarioPrint 120
Oce VarioPrint 135
Apr 28, 2014 | Office Equipment & Supplies
Hi, oce 3165 machine is giving error 1104,kindly help me get a solution to this
Output OP paper rejection roller drive malfunction.Try to reset the malfunction code to Open/close the front door.If not reset:
Turn OFF the copier.
Press and keep pressed the Utility key and turn On the copier.
Keep pressed the Utility key and wait while Trouble reset message displayed.
Release the Utility key and touch the message.
Turn OFF the copier ,wait 1 minutes and turn ON.
Apr 19, 2013 | OCE 3140 Copier
Jan 08, 2013 | OCE Office Equipment & Supplies
My Oce Scanner has the 10514-246 error. Please help me !
my oce tcs500 error code 10514-246 start of scan failed
Sep 07, 2011 | Office Equipment & Supplies
C1183 error
C-1183 = Elevator Motor Ascent/Descent Drive Failure
This code means something is stopping the finisher exit trays from moving. Check your finisher exit trays. Make sure nothing is under them blocking the movement. Make sure they are level and have not been knocked out of place. Open and close the front door and reset the machine power and see if the trays move. They are suppose to move and find home position when resetting.
May 24, 2010 | Konica Minolta Bizhub 362 Copier
Oct 09, 2009 | OCE Office Equipment & Supplies
Jul 13, 2009 | OCE Office Equipment & Supplies
k24674
jasbo
jasbo
