Question about Frigidaire Refrigerators
The feeler arm is stuck in the up position on my frigidaire gallery refridgerator's ice maker
Ive taken the ice maker out and cant get the arm to go down.
  • Frigidaire Master
  • 744 Answers
Hello;
My name is Peter. I am a retired field service appliance technician.
You have not given me any detailed in formation such as your model number to help you. You model number is on a label on the side wall near the top, in your fresh food section.
The one leg of your lever arm goes into the front part of the motor module, which is in the front of your ice maker. The arm is interlocked with plastic gear components one or more of these components are broke.
I am guessing if the following ice maker is what you have.
the feeler arm is stuck in the up position on my f - 25314741-li150hslu5ucqppqaoc0zevv-5-0.jpg 25314741-li150hslu5ucqppqaoc0zevv-5-3.jpg 25314741-li150hslu5ucqppqaoc0zevv-5-15.jpg
Posted on Dec 09, 2014
Are there a shut off for the bottom ice maker on a Frigidaire gallery refrigerator
Yes, the feeler arm that checks the tray for ice will turn off maker if you put the arm all the way up away from the tray.
Sep 03, 2017 | Frigidaire Refrigerators
My frigidaire gallery french door with ice maker is making a knocking noise every 5 seconds. Sounds like from the ice maker. How do I fix or stop the noise.
I have a different type. I rubber banded the little ARM in the UP position ( to fool the unit that I have enough ice). NO MORE SOUND>>
Jun 03, 2015 | Frigidaire FGHB2866PF3PCKIT Gallery...
How do I get the ice maker to produce for the first time
Is the arm that gets pushed up by the ice cubes (in order to stop making ice when it is full) in the down position? it is able to be pushed up and locked so that the icemaker doesn't make at ice and may need to be pushed down.
Aug 27, 2014 | Maytag MSD2454G Side by Side Refrigerator
Need to know how to turn on ice maker in whirlpool gz25fsrxyy2
Should be a wire feeler arm that runs front to back on that icemaker. If it is stuck in the up position---the icemaker is OFF. It should be hanging downward to be in the ON position. If up---just gentley pull it down until it is moving freely. As the ice bin fill with cubes that arm should move up and down with the icemaker. Once the cube level is high enough for the feeler arm to be held in the up position it will stop making ice until you use enough cubes for the arm to fall again.
Sep 26, 2012 | Whirlpool White Gold 25 cu. ft. ENERGY...
Kenmore 795.5102 will not make ice
The problem is the ice maker, the modular head of the ice maker has broken, hence the clicking sound and the raised arm stuck up. You will need to have an accurate model number and contact a local parts distributor for a new ice maker. It is a simple repair usually only 2-3 screws.
Apr 25, 2012 | Kenmore Side by Side Refrigerator
Ice maker not making ice
should be in the down position the way it works is when the ice is dispenced into the bucket the arm at the same time raises up once there is enough ice the ice keeps the arm up stoping the ice maker
Apr 14, 2010 | Frigidaire Gallery Series GLHS269ZDB 36"...
MY ICE MAKER FEELER ARM IS STUCK IN THE UP POSITION. CAN YOU PLEASE TELL ME HOW I CAN FIX THIS? MODEL LFX25950SB LG REFRIG
Water is getting into the area where the arm pivots and freezing. This prevents the arm from dropping down when it should. I use a hair dryer to melt the ice in the area of where the arms comes out of the base. As soon as the arm drops, the ice maker will make more ice. This LG in the door icemaker is junk.
Jul 14, 2009 | LG LRBN20510WW Bottom Freezer Refrigerator
Frigidaire Gallery Series Side by Side doesn't crush ice
hi there,
could be that the ice maker arm is getting stuck or may have some frost on it. can you supply the complete model # please?
Sep 25, 2008 | Frigidaire Gallery Series GLHS269ZDB 36"...
Inoperative Ice Maker
The icemaker stops working because excessive water gets into the control box(where circuit board is housed) through the shaft hole of "finger" and freezes the wheels to turn the "ice-bucket-full detector rod". This stops to send the signal to open water valve.
To fix, remove the icemaker from the wall (need remove two screws - make sure power switch is OFF) and carefully separate the snap-on cable (retangular shape) and a ground cable on the bottom side of the icemaker. (Now you can remove the icemaker out of the refrigerator).
You can open the contol box (need unscrew one and carefully prop it open using a screw driver or a knife. You can unplug color corded snap-on cables for easiness to work (very simple).
You will see ice formed around the plastic gear wheel controlling the "ice-bucket-full detector rod". Remove all ice and dry all the parts in the box and put them back. Make sure all the cable are back to the matching color receptable(only fits in the right place). Connect the cable(rectangular shape) and connect the ground cable. Mount the incemaker on the wall using two screws you removed at first.
Turn the power ON and reset the system by press down the ice cube size selector until the "fingers" make a full cycle. You will see the metal rod moves up and down as system resets. During this cycle the water will be filled into the icemaker.
I believe this icemaker has a design flaw but it's very simple to correct the problem you are experiencing. You do not need much electronic or mechanical knowlege to fix this.
Best wishes
Young
Jun 15, 2007 | LG LFX25960ST Stainless Steel French Door...
Refrigerators Logo
334 people viewed this question
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
