Question about Health & Beauty
Jazzy 1143 has new batteries all lights are good still is very slow
    Problem Solver:
  • 3 Answers
It may be that the joystick has been programmed for indoor or slow reaction user, you will need it to be reprogrammed (this is normally a very cheap and easy thing to do, but you need a programmer or to get a mobility shop to re program it) with most joysticks it just plugs in to the charge / data 3 pin socket on the joystick and takes less than 5 mins. a lot of mobility shops will reprogram free in the hope you will use them for further work if needed. phone a few and see how you get on, you will need to be able to tell them the type of controller (joystick) your chair has, if you are unsure do a google "image search for "wheelchair controller types" look at the images to identify the type you have fitted.
Posted on Dec 23, 2014
2 Suggested Answers
  • 175 Answers
SOURCE: Go to turn the power on the controller of a Jazzy
Flashing lights indicates a fault. Here' the users manual which contains the fault codes for the flashing lights. Repost with more info re: the fault codes. Good Luck.
http://www.pridemobility.com/pdf/Owners_Manuals/US_Jazzy/US_Jazzy_1143_om.pdf
Also, make sure the charger is not plugged into the chair.
Posted on Jul 12, 2009
Jazzy model 1103 - one speed and speed light flashes
hi,when the speed light flashes,is there a pause or is this a continous flash ?regarding missing a connection, that i very much doubt...
Regards
Rob
www.gewizrepairs.co.uk
Dec 12, 2013 | Pride Jazzy Select 6
We have a pride jazzy 1143 select power chair. we have had problems with the batteries going bad. I purchased a new set of batteries last December. in June they would not hold a charge and I purchased a...
charger is no good or is not the correct charger for that chair suggestion have a dealer tech replace a original charger in chair,it should have a 3 yr warranty anyways
Oct 22, 2013 | Pride Jazzy 1103 Ultra Standard Power...
Jazzy 1143 power chair
well if u need the charger on then batterys are dead and need to be recharged,or have the batterys checked make sure they are ok by testing a load on them at a local auto parts store for free,if no good make sure u get same type of battery and make sure it is a gel battery not a acid battery
Sep 04, 2013 | Electric Health & Beauty
Why are the lights blinking and it won't go
read manual,lights flash when in security mode,everyt model has a unlock procedure with the buttons on the joystick control.
Jan 23, 2013 | Pride Mobility Jazzy 1143 Power Chair -...
1143 jazzy wheel chair new batterys @ new charger still not charging
With a new charger and new batteries there can only be one other problem assuming all the wiring is connected properly. There is a 7.5 Amp in-line fuse hidden in a fuse holder off the charging harness. This fuse may have blown. I usually check this fuse first since it is usually the culprit and most difficult item to locate under the back cover. In rare cases the ammeter burns open and will cause the unit not to charge. After checking the fuse you can jumper one or both these items to see if it will charge and then purchase new parts. Hope this helps.
Apr 16, 2011 | Select Jazzy Used Electric Wheelchair
I have a jazzy and the power meter keeps blinking a steady red light.... And now the chair is moving really slow....
Low batteries Outlaw. If you have charged the batteries and after only a little while you get the blinking red light -----Time for New batteries. Hope this helps you
Nov 10, 2010 | Pride Mobility Products Jazzy Select 14
I have a Jazzy Power Chair that hasn't been in use for several years. When I tried to charge the battery only the red light comes on. How do I get the yellow light to come on to show it is being charged?
Retired get new batteries if they haven't been charged for that long they're shot. Invest in 2 good U1 batteries, charge before use and you should be good to go Good Luck
Nov 01, 2010 | Pride Jazzy 1103 Ultra Standard Power...
New batteries chair slow
Instruction Manual:www.FixYa.com/Insrtuction+Manuals & for extra info type in a brouser: local dealer for your product giving its name & it maybe a seperate box for you to enter your Post Code,enabling easier searching for you.
May 12, 2010 | Select Jazzy Used Electric Wheelchair
I have a Pride 1143 Jazzy Electric wheel chair and the controller is constantly flashing. This happened after I drove into my van and locked into the e-zloc. My husband sid I drove in too fast and caused...
Hi
Rapid flash of lights indicates a fault in the VSI or the electrical system. You need to refer to " VSI Error Codes" on page#32 of this User Manual:
Pride 1143 Jazzy Electric wheel chair User Manual
Please do accept the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
Jul 25, 2009 | Select Jazzy Used Electric Wheelchair
Go to turn the power on the controller of a Jazzy 1143. The lights on the controller flash and no power goees to the chair. Have checked all connections and still nothing works.
Jun 06, 2009 | Pride Jazzy 1113 Power Chair
Health & Beauty Logo
66 people viewed this question
Top Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you a Health and Beauty Expert? Answer questions, earn points and help others
