Question about Zebra Stripe S600 Thermal Label Printer
WHAT PROPERTY SETTINGS DO I NEED ? IM HAVING TROUBLE GETTING MY ZEBRA TO PRINT
IT HAD BEEN WORKING FINE AND IT JUST STOPPED WORKING
jigeo
  • 57 Answers
SOURCE: Zebra LP 2844 fuzzy print
1. Clean the print head with cleaning pen.
2. Adjust print speed/darkness in software.
3. Check the media and verify that print surface is facing up.
4. Check that correct thermal media is in use.
Posted on Apr 24, 2008
  • 45 Answers
SOURCE: Zebra TLp 2844 (printer not connected error message )
Go to Control Panel, Administrative Tools (in Clasic view), and double click on Services. Scroll down and right-click on "Print Spooler". Start (or Restart) it and your printers will reappear in the "Printers and Faxes" window, and the spooler will try to send jobs to the printers again.
If you check the Properties of the Print Spooler, on the Recovery tab, you can set it to "Restart the Service". I set mine to Restart on the First Failure and Second Failure, and Take No Action on the Third Failure, in case something really needs attention.
Posted on Sep 23, 2008
  • 62 Answers
SOURCE: Printer port configuration and Zebra trouble
When you connect a printer to your pc the operating system adds a virtual port. Your pc will typically have 3 physical usb ports but can have as many virtual ports as you have devices to connect to it.
1: Ensure that your printer has media loaded and is powered up and ready to print. Connect the USB cable. You should get a message on pc screen saying device (printer) found.
Open printer driver ( double click on the zebra printer icon - Start/control panel/printers & Faxes/) Click print test page. If it doesnt print you will see a printer icon with a red question mark.on your toolbar, double click on this. This will bring up a small window showing status of the print job, Click printer/properties/ports. Select the next free usb port and click apply. Drag the print status window so that you can see the message in the status window change from Error print to error Restarting. repeat trying each of your usb ports until printer works. start with the higheat usb with highest number and work your way down.
Posted on Aug 02, 2009
  • 2976 Answers
SOURCE: MY ZEBRA TLP 2824 PRINTS IN THE MIDDLE OF MY LABELS.
Don't shoot it, they're too hard to cook.
Make sure your program is set for the label size you're using. Also, there is a photo eye under the paper path that picks up the labels. It will, in time come out of adjustment. It can be cleaned with a swab and alcohol.
Posted on Sep 01, 2009
SOURCE: zebra lp2844 printing incorrectly with paypal multi order
Anyone solve this problem?
Posted on Sep 03, 2010
S4m quick books
change the default orientation setting in printer properties.
May 10, 2013 | Zebra S4M Thermal Label Printer
Sep 01, 2009 | Zebra TLP 2824 Printer
Zebra TLP 2844 prints slow in WinXP, but fast in
when submitting the print, un-tick the collate box. Use the properties section to check the speed settings in the driver and try again
Aug 13, 2009 | Zebra TLP 2844-Z Thermal Label Printer
Jul 15, 2009 | Zebra LP 2844-Z Thermal Label Printer
Can't save the printer darkness in the printer
go to printer driver properties.. 1.click printing preferences set it to USE PRINTER CONFIGURATION 2.go to advance click Printing Defaults set it to USE PRINTER CONFIGURATION
you must set this two configuration note: fresh installed driver defaulth to software control
Oct 14, 2008 | Zebra Z4Mplus Label Printer
How do I reset the card-print counter on an Eltron P420C
u select the properties and search for tabs like card count,details etc and reset thecount to 0.im not sure about this answer this may work or may not be.
Aug 26, 2008 | Zebra Eltron P420C Printer
Jun 23, 2008 | Zebra Eltron TLP 2844 Thermal Label...
UPS Thermal 2844 Connection problem(USB)
Add the printer as a Local LPT1. Then go into the properties and switch the port to a USB port. Try a test label. If it doesn't print, go back to properties of the printer and switch it to another USB until it does. If all else fails there is a remove utility included with the Zebra drivers you downloaded. You can remove all zebra related drivers and printers and then reboot. The PC should redetect the printer when you turn it on.
Feb 21, 2008 | Zebra LP 2844 Thermal Printer
How to configure the Zebra S500 using a USB to Parallel adapter?
The Zebra Stripe S500 has a RS-232 SERIAL interface using a DB-25 connector . You'll need a USB to SERIAL converter, not parallel. Be sure that the baud rate and data/stop bits are set the same on the printer and interface converter. Generally speaking, use the fastest setting possible (19200 baud) unless you encounter problems.
Oct 30, 2007 | Zebra Stripe S500 Thermal Label Printer
Only every fourth label Prints
We've been having problems with ours. Make sure that the properties are correctly set, landscape, portrait, 180' rotation, label size, on the printer properties. Then check again through whatever package you are using 'printer properties' and try a print. You may have to re-enter properties each time you print.
Sep 01, 2006 | Zebra LP 2844 Thermal Printer
Zebra Stripe S600 Thermal Label Printer Logo
52 people viewed this question
Top Zebra Office Equipment & Supplies Experts
pkwc
CheckitRight
CheckitRight
Are you a Zebra Office Equipment and Supply Expert? Answer questions, earn points and help others
