Sanyo LCD 42" is 5 years old. I was watching tv when the picture disappeared but still had sound. Only the power button on the tv worked. The remote wouldn't work the tv either.
    Top Expert:
  • Televison & ... Master
  • 74,482 Answers
Check the remote control for its infra-red emission. Check it with fresh batteries. Check by pressing all the buttons on it; and see whether all of it generates infrared signal while pressing. If it is found OK, check and replace the infrared sensor inside the TV. If you wish to get some details; check the site linked here. It has details about how to check a remote control; by one among the post. Surf the site with patience. Pull up older posts. http://electronicshelponline.blogspot.com/ If the remote control is found OK; check and replace the infra-red sensor inside the TV. Contact any service technician.
Posted on Dec 10, 2014
  • The Knight
    The Knight Dec 10, 2014
    Check the remote control for its infra-red emission. Check it with fresh batteries. Check by pressing all the buttons on it; and see whether all of it generates infrared signal while pressing. If it is found OK, check and replace the infrared sensor inside the TV. If you wish to get some details; check the site linked here. It has details about how to check a remote control; by one among the post. Surf the site with patience. Pull up older posts. http://electronicshelponline.blogspot.co... If the remote control is found OK; check and replace the infra-red sensor inside the TV. Contact any service technician.
alpug
  • 1961 Answers
SOURCE: Sanyo TV LCD 32 inch about 3 years old. No
the power supply of your tv is bad try to check the fuses if fuse are open try to replace them with the same value..try to power it on but if the fuse blows again replace the power supply board...
good luck plse rate my help.
Posted on Jun 04, 2010
  • 8457 Answers
SOURCE: Sanyo lcd tv blinking
Power supply board is dead.Replaced the power supply board will solved this problems.Tries Shopjimmy.com,Ebay.com to buy a refurbish power supply board for the replacement.
Posted on Apr 02, 2010
  • 8457 Answers
SOURCE: Sanyo 42" LCD will not turn on!!!
Power supply board is dead.Buy a refurbish power supply board at Shopjimmy.com,Ebay.com for the replacement.
Posted on Mar 26, 2010
SOURCE: LG 42 LCD no sound or picture
Did anyone find out the solution for this??????? I have the exact same problem with my LG 32 LCD. I only had it for a year and a half, and the green light blinks a few times and it shows no picture. Not even a red light when the tv is off. The same thing happened a couple weeks ago and by some miracle it started working again.
Posted on Nov 22, 2009
  • 10 Answers
SOURCE: Sceptre LCD TV power come on, but there is no picture or sound.
There are two easy fixes you can try. Both require you to take the back panel off. If you are not comfortable doing this, take it to a repair shop.
UNPLUG IT.
Place the TV face down on a soft/solid surface.
After you get the back panel off, there are three silver boxes. There are white and black wires leading from the off switch to the top silver box. Take the cover off that box.
Inside is a ceramic fuse. Test that fuse. If it is blown, your local electronics shop can find a replacement.
If not, disconnect the white and black wires from the PC board. Remove the 6 screws holding it in place.
Look for scorch marks under the board.
Cut a thick piece of plastic and tape id down over the scorch marks.
Re-attach the board with the six screws and re-connect the black and white wires.
Turn the power switch to the OFF position and plug in the TV.
Turn on the power switch while WATCHING the board you just removed.
If you hear a sizzle, turn off the switch and get a thicker piece of plasic.
If not, the TV should come back on.
Re-assemble the silver box and put the back on.
Hope this helps.
Posted on Aug 09, 2009
My 42" Sanyo LCD TV which is 4 years old no longer
This is not a user repairable fault. Should be checked from its main power regulator board, and is a skilled work. Actually this is a repairable fault, but can do only by any technicain.
Jul 11, 2013 | Televison & Video
42" LG plasma tv, 4
Probably filter capacitor in power supply if it
exploded should be easy to find may have caused other problems however
could be worth checking
Feb 25, 2011 | LG 42LC2D 42 in. LCD HDTV
My sanyo 42in lcd has just started acting up. I changed the batteries in my remote and now my tv turns on and off on its own and will not show a picture or sound. I cannot even change the channels. The...
Remove the batteries from the remote then see if the set returns to normal and you can use the buttons on the tv. If after the batteries are out and the set is still acting upreturns back to normal then the remote is bad, I have seen cases where something has been spilled on the remote and no one was told.
Dec 10, 2010 | Sanyo 42 in. LCD TV
The tv's green light comes on but there is no picture and no sound. When I push any buttons on the remote the only thing that shows up is the volume thing. It doesn't respond to pushing the channel buttons...
your main board has gone bad. Can be fixed, in my shop it would cost about $250. It is a real shame on the industry that these things last about 2 years or less. Hope you held on to your old crt style tv.
Jun 17, 2010 | LG 42LC2D 42 in. LCD HDTV
Jun 04, 2010 | Sanyo DP32746 32 in. LCD Television
Mar 26, 2010 | Sanyo 42 in. LCD TV
Jan 28, 2009 | Televison & Video
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
