I did get an answer. First you have to calibrate the machine to see if it is on level zero. Ours was and we ordered a new storage latch. Have not received it yet and do not know if it is a shorter one
This is not a question but a answer to your question
    Habit-Forming:
  • 91 Answers
What kind of printer talking about
Posted on Dec 10, 2014
I have a Spirit XT285 treadmill and it says it is at a zero percent incline but it is definitely not flat. I ran the calibration and it is still not level. I used a level to check and the bubble is not...
I have the same machine, and I have a feeling that it has a natural 1% incline which is supposed to simulate the difference with no wind resistance.
Sep 11, 2013 | Spirit XT285 Treadmill
Needs service code 66
The pressure sensor is faulty and needs a new/good secondhand one
You can get one from an old dead board,
But it needs to be calibrated to that board.
To calibrate the new one set machine to fill to low water level,
The plastic hex with red on it needs to be turned up to raise & down to lower the water level.1/8inch of a turn will adjust water by 15 to 20mm.
66. (01000001) Pressure Transducer Error [Ptx Frequency > 90 kHz]
Note: this supersedes Fault code 65 from V41 Motor controller code onwards.
The Motor Control module has received signals from the water level sensor (Ptx)
above normal frequency values.
Primary Source: Motor Control module
Action: Replace Motor Control module
Jun 17, 2012 | Fisher and Paykel Washing Machines
My maytag nepotune high efficiency model MAH550BWW door does not close properly...have to slam the door several times before the latch closes to set and start the wash cycle
There is wear in the door latch/lock mechanism, It will eventually fail completely and you will have to replace the door lock
Mar 12, 2012 | Washing Machines
I replaced my battery and now I have a engiine light vsc light and 4wd light warning no throttle response and problem code p2118. checked all fuses all good. any ideas please help.
Tests/Procedures: 1. Perform zero point calibration of the yaw rate sensor/deceleration sensor. Potential Causes: Deceleration Sensor Zero Point Calibration
Tech Tips: Code C1336 is for Deceleration sensor zero point calibration undone. To perform zero point calibration, have the steering wheel in the straight ahead position and have the vehicle on a level surface within an inclination of 1%. Turn the ignition switch OFF. Use a jumper wire and connect terminals TS and CG of Data Link Connector (DLC) 3. Turn the ignition switch ON. Keep the vehicle stationary on a level surface for 2 seconds or more and verify that the VSC warning light blinks. Diagnostic Codes: C1336
Jan 24, 2011 | 2006 Toyota RAV4
How i unfold it?
There is allot of weight on the "Storage Latch". You may need to push forward on the treadmill a bit, pull the black knob, then slowly let the machine unfold. Taking the weight off the "Storage Latch" will make it easier to release the latch..
Dec 16, 2010 | Nordic Track NordicTrack A2750 PRO...
Latch is not working properly
It's possible the machine is slightly twisted.
Try re-levelling it to start.
You can usually tell when the door is not quite closed if it looks out-of-centre.
The next thing to check is lubrication of the catch. Try some WD-40 in the latch mechanism.
If still no better, then the latch may need adjusting by removing the front panel (unplug machine before doing this).
Grease the moving parts and adjust catch for easy closing.
May 02, 2010 | Dishwashers
PROBLEM WITH WEIGHT CALIBRATION
Calibration procedure for Robinair AC machine.
NOTE:FOR SCAL CALIBRATION YOU SHOULD HAVE 9KG/20LB OF WEIGHT.From main menu go to change default (press 8787 for old type machine or 5454 new type machine)
then press enter/start key.after enter to default nenu you have to select calibrate scal option.press again enter/start key then follow the on scree message.once you done so,press stop/exit key to complete the prcess.
Aug 18, 2009 | Robinair Cool Tech 34700Z Recovery,...
Sub zero particles in ice from ice maker
This issue occurs if your Ice Maker is not clean or have dust particals inside, follow the below steps in order to clean it properly:
Step 1 Lift the power bar located above the ice maker storage tray.
  • Step 2 Unplug the refrigerator.
  • Step 3 Allow the refrigerator and freezer to defrost. This will melt any large blocks of ice that have accumulated in the ice maker.
    Clean the Ice Machine
  • Step 1 Remove the ice machine storage tray.
  • Step 2 Dump any water in the ice machine storage tray.
  • Step 3 Wash the ice machine storage tray using warm, soapy water. Rinse and allow to dry completely.
  • Step 4 Sanitize the lines of the ice maker. Consult your manufacturer's directions for steps to do this, because it's not available on all models.
    Reassemble the Ice Maker
  • Step 1 Replace the ice machine storage tray.
  • Step 2 Plug the refrigerator into the outlet to restore power.
  • Step 3 Lower the internal power bar located just above the ice machine storage tray. This allows the ice machine to make new ice.
  • Jul 20, 2009 | Refrigerators
    Locked ovens
    replace part number 12001656 it is the sensor. Maytag will not help you.
    Nov 25, 2007 | Maytag MER6772 Gemini Electric Kitchen...
    29 people viewed this question
    jasbo
    jasbo
