Question about Blu Dash Jr Cell Phone
Attempting to reset blu dash jr, but Speadtrum Factory Test is displayed
How do i execute a factory reset for this phone
  • 61 Answers
SOURCE: How to reset blu neo jr
Since you didn't suggest which one you wanted, soft or hard reset, I have included answers for both:
To Soft Reset. First method:
1) Remove and replace the battery.
2) Press the Power Button.
Second method:
1) Press the Power Button until the menu which shows "select option turn off phone" appears or
Third method:
1) Press the Power button until the phone turns off, then press it again until it turns back on.
There are a couple of methods to hard reset your Blu Neo phone back to default factory settings.
1) Depress the power button until the unit is on.
2) Browse to Menu > Settings > Privacy > Factory Data Reset > Reset Phone.
The resets your phone to out of the box settings. Only to be used if you wish to return the phone back to the condition it was in when you first purchased it.
The second is to:
1) Turn you phone off.
2) Hold the Volume Down and Menu and Power buttons [all three at the same time]. Hold all three fingers down on those buttons until you see the Recovery Menu [it may take a few moments], then release your fingers from the three buttons listed above.
3) Select "Wipe Data/Factory Reset" using the volume buttons to navigate between the choices. The use the Power Button to select the choice.
4) Confirm "Yes - Delete All User Data"
Either of these two methods will reset your Blu to its out of the box configuration. BE SURE you have a back up if you wish to restore your settings.
I hope this helped you.
Posted on Mar 13, 2015
ladywritr2
  • 954 Answers
SOURCE: My BLU Win Jr Cell phone will not power up. I have change the battery bugt no result.
Be sure you are using the correct charger. If it still won't work, its battery may need replaced.
Posted on May 10, 2015
  • 4 Answers
SOURCE: how to do a factory reset on a Blu Advance 4.5 cell ph
Are you sure you want to do that? Go to settings go to account. You also can contact your phone company to give you directions.
Posted on May 25, 2015
jerardi
  • 14162 Answers
SOURCE: Where can I find the Puk code for a Blu dash Jr?
Press the home key, volume key, and power key hold for 10-15 seconds, when screen changes only release power key and continue holding volume key and home key. A menu will appear on your screen just follow instructions to do a reset. Good luck
Posted on Jun 09, 2015
hichbiri
  • 3462 Answers
SOURCE: Need unlocked code for a blu dash jr SIM card
you need to contact your network/ service provider, they are probably the safest source for such assistance.
Posted on Jun 14, 2015
Forgot password BLU dash jr. IMIE 353**********04 how do I recover it
You can't recover the password, not possible. In order to regain use of the phone again you must do a "factory reset" this will erase the password and also all of your stored data that you inputted into the phone like phone numbers and pictures.
Oct 31, 2016 | Blu Cell Phones
How do I reset the blu dash jr 4.ok
press the home key, volume key, and power key hold for 10-15 seconds, when screen changes only release power key and continue holding volume key and home key. A menu will appear on your screen just follow instructions to do a reset. Good luck
Feb 18, 2015 | Blu Dash Jr 4.0 K Cell Phone
How do I unlock my phone?
You will need to perform a factory reset
Jan 30, 2015 | Blu Cell Phones
How do i reset a blu dash jr 4.0 k phone? model part is D142k
There should be an option to reset your phone in 'settings'.
Back Up and Reset should give you the option to reset with no problems. As you enter this option, the last option here is 'Factory Data Reset'. Try this and let me know what transpired after....
Dec 21, 2014 | Blu Dash Jr 4.0 K Cell Phone
How do i unlock my blu dash jr 3.5 after too may parten attemps
You may have to do a factory reset. Reply for info!
Oct 12, 2014 | Blu Dash Jr Cell Phone
How do i factory reset blu dash jr
www.bluproducts.com/index.php/contact-service
Jun 24, 2014 | Blu Cell Phones
How to install stock rom on blu dash jr d140?
hardrest sir if will done!!!
check diz one
If You Can't Boot
If safe mode doesn't help fix your device, you can perform a hard reset by booting into a special recovery mode. First, ensure your device is fully shut down.
Press and hold the correct keys to boot the device into recovery mode. This will vary from device to device. Here are some examples:
  • Nexus 7: Volume Up + Volume Down + Power
  • Samsung Galaxy S3: Volume Up + Home + Power
  • Motorola Droid X: Home + Power
  • Devices With Camera Buttons: Volume Up + Camera
Similar devices will likely use similar key combinations. For example, the Nexus 4 also uses Volume Up + Volume Down + Power.
If your device isn't on this list and none of the above methods work, do a Google search for the name of your device and "recovery mode" - or look in the device's manual or support pages.
Release the buttons when the device powered on. You'll see an image of an Android lying on its back with its chest open and its internals revealed.
Press the Volume Up and Volume Down keys to scroll through the options until you seeRecovery mode on the screen.
Press the Power button to restart into recovery mode. You'll soon see an Android with a red triangle.
Hold down the Power button and tap Volume Up. You'll see the Android system recovery menu appear at the top of your screen.
Select wipe data / factory reset with the volume keys and tap the Power button to activate it.
Select Yes - erase all user data with the volume buttons and tap Power. Your device will be reset to its factory state and all your data will be erased.
If your device freezes at any point, hold down the Power button until it restarts.
If You Can Boot
You can reset your Android phone or tablet normally from its Settings screen. Tap the Backup & reset option on the latest versions of Android or tap Privacy if you're using Android 2.3.
Tap the Factory data reset option and to through the reset of the steps to confirm the factory reset.
If the factory reset process doesn't fix your problems - or doesn't work at all - it's likely that there's a problem with your device's hardware. If it's still under warranty, you should have it fixed or replaced.
(There's one exception to this: If you've been flashing custom ROMs and messing with your device's low-level software, it's possible that you could have overwritten the stock recovery software. In this case, it's possible that you have a software problem and not a hardware problem.)
goodluck
Jun 22, 2014 | Blu Dash Jr D140 Cell Phone
Will not let me reset the phone! Can you help!
do as i say:
call 3845#*910*
choose factory reset, give him 5 minw
and it work
Jan 10, 2009 | LG KC910 Renoir Cell Phone
Blu Dash Jr Cell Phone Logo
27 people viewed this question
Top Blu Cell Phones Experts
Hjalmer Lamminen
Hjalmer Lamminen
Dustin
Dustin
Are you a Blu Cell Phone Expert? Answer questions, earn points and help others
