Question about Xerox DocuColor 700 Colour Drum Cartridge 013R00656
Xerox 700 fault code 042-324 keep faulting when running
New ibt and cleaner
    Habit-Forming:
  • 24 Answers
Replace main moter
Posted on Dec 10, 2015
Xerox workcenter7346 has fault code 009-390
009-390= IBT belt home position sensor/patch. After examing ibt belt assembly and cleaning patch and sesor, noticed that the magenta developer unit was not in proper position, this was not allowing the ibt unit to turn. Re-positioned developer unit into proper position, installed ibt unit, this cleared up the problem and machine is running fine.
Dec 11, 2012 | Xerox WorkCentreR Pro 7346 Black Toner...
My xerox dc12 have this error system fault 3-380 what can i do to fix it
Did you recently replaced print cartridge? Because,if you did one thing that could be a problem is that you are using illegal or not original PC. Second thing that could make you some problem is IBT cleaner. IBT cleaner has two brushes on the each end of the assy. Their job is to clean silver patch on IBT. So maybe your IBT cleaner is worn out and those brushes does not do it's job anymore or maybe the sensor that "reads" that patch is dirty.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response
Thanks, Joe
Apr 07, 2011 | Office Equipment & Supplies
I tirnen on my xerox de12 and this message comes on the screen "3-380" dc12 system fault
your machine IBT brush is not cleaning the stickers of the IBT clean manually
Apr 07, 2011 | Xerox DocuColor 12 Printer
Xerox Dc12 9-345 error how i solve it please any body help me
The RAP does not lead you to the connector unless you trace the wiring in the BSD. This connector is located on an air duct on the bottom right hand corner of the IOT Drive PWB and acts as a double plug to connect on one side to the connector of the IBT Cleaner Blade home position sensor and the other side to a connector that leads to the IOT Drive PWB. After firmly plugging in the connector, the fault code went away. call 98413 40555
Dec 17, 2010 | Xerox DocuColor 12 Color Copier
How to change ibt belt and get the machine fault code 004-346 removed on xerox 7345
The error code 004-346 is an IBT home position sensor. The belt may be damaged or didn't move.
The sensor which is mounted on the frame looks at the belt to see if it made a full rotation. Perhaps the sensor is dirty or damaged. Maybe the home reflective mark is damaged.
The belt may be damaged or shredded. Find out why the old belt was damaged before you install another part!
You probably need to purchase a new IBT belt PN 802K208991. The Xerox technician has a proprietary laptop to clear the codes and calibrate the "Belt Edge." The belt is very fragile, so whoever installs it needs to be very mehtodical and careful.
These may preclude you from repairing that yourself.
Whit Item, Inc.
Nov 19, 2010 | Xerox Office Equipment & Supplies
Our xerox workcentre 7328 shows fault code 004-346
I don't have that manual, but similar manuals say IBT Home Sensor Error. Check your accumulator belt for damage. You may also have a dirty sensor.
The belt PN is 604K20891and is rather expensive and fragile
Whit
Item, Inc.
Aug 06, 2010 | Xerox WorkCentre 7328 Multifunction laser...
Error code 3-380 what does this mean
That error describes a number of things that can be foulty on your machine. First Did you recently replaced print cartridge (PC)? Couse if you did one thing that could be a problem is that you are using illegal or not original PC. Second thing that could make you some problem is IBT cleaner. IBT cleaner has two brushes on the each end of the assy. Their job is to clean silver patch on IBT. So maybe your IBT cleaner is worn out and those brushes doest do their job anymore or maybe the sensor that "reads" that patch is dirty
Aug 05, 2009 | Xerox DocuColor 12 Printer
Error 9-345
This is a failure of The IBT belt cleaner blade retraction mechanism. 2-3 hour job for a trained tech. It may not even need parts, it's just hard to do
Jul 05, 2008 | Xerox DocuColor 12 Printer
Xerox DocuColor 700 Colour Drum Cartridge 013R00656 Logo
733 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Xeroxrep
Level 1 Expert
Philip Hughes
CheckitRight
CheckitRight
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
