Question about Sharp Microwave Ovens
I want usermanual for sharp R-352 DC(w) microwave
    Master:
  • 552 Answers
What u r saying is that u don't know what google is all about yet.
enter "usermanual for sharp R-352 DC(w) microwave" into ur search bar and it is amazing what u find -- like this
http://www.usersmanualguide.com/sharp/microwave/page5
Posted on Dec 09, 2014
User manual for a model R-209 AK counter top carousel microwave
Free Sharp Microwave Oven User Manuals ' ManualsOnline ...
kitchen.manualsonline.com > ... > Sharp > Kitchen Appliance Sharp
Products 1 - 50 of 359 - Top Automotive Device Types ..... Sharp M I C R O WAV E O V E N OPERATION MANUAL. Pages: 0 ... Sharp Microwave Oven 209H ... SharpOperation Manual Microwave Oven R-308H, R-305H .... Sharp Microwave OvenMODEL R-2197 ... Sharp over the counter microwave oven operation manual ...
SHARP MICROWAVE OVEN Parts ' Model r209ak ' Sears ...
www.searspartsdirect.com/model-number/r209ak/0958/0123245.html
Shop for SHARP MICROWAVE OVEN repair parts for model r209ak at Sears ... Find part in diagram SHARP Countertop Microwave Model # R-209AK.
Jan 07, 2016 | Sharp Microwave Ovens
User manual for 1200 w carousel ser# 57088
Products 1 - 50 of 359 - Sharp Microwave Oven 11452 User Guide. Pages: 0 Saves: 0 ... Sharp Operation Manual Microwave Oven R-308H, R-305H. Pages: 0 ...
Free Sharp Convection Oven User Manuals - Kitchen .
Nov 15, 2015 | Sharp Microwave Ovens
Why my sharp r 9h20 microwave oven noyzey during operation?
You are probably referring to the cycling of the klystrom in order to maintain the power lever you have chosen. The noise is characteristic of yours and other cycling type ovens. For a quieter operation that is not "all off" and "all on" in succession, try a DC powered next time. Panasonic makes one called Inverter...maintains cooking level without switching.
Nov 10, 2014 | Microwave Ovens
Sharp convection microwave oven model R1875F. It's cooking on the left side faster then the rest of the oven. It seems to burn on the left side and not cook in the middle.
see the next causes. God bless you
Diode The high voltage diode converts the A/C power output of the transformer to D/C, doubling the voltage to nearly 5,000 volts. This high voltage powers the magnetron which emits the energy that cooks the food. If the diode burns out, a lower A/C voltage reaches the magnetron, which is not sufficient to power the magnetron. When the diode fails it is often visibly burned out. If it appears to be good, it can be tested with a volt-Ohm meter capable of testing diodes. High voltage diodes frequently fail and are one of the most common points of failure in a microwave oven.
Door Switch If the microwave does not heat, one of the door switches might be defective. Microwave ovens normally have three door switches, if any of them fail the microwave does not turn on and does not heat. Check the switches for continuity with an Ohm meter.
Magnetron If the microwave oven doesn't heat the magnetron tube might have burned out. The magnetron uses high voltage, high current DC power to generate the microwave frequency that cooks the food. If the microwave oven is turned on when it is empty this can cause the magnetron to burn out. Once it is burned out it has to be replaced, it's not repairable.
High Voltage Capacitor If the microwave doesn't heat the high voltage capacitor might be defective. The high voltage capacitor works with the high voltage diode to convert the output of the transformer to DC voltage and to double the output voltage. If the capacitor is burned out the entire high voltage circuit stops working properly. The high voltage capacitor can be checked with a special VOM meter which has a capacitance testing capability. Be aware that the high voltage capacitor can retain a charge of more than 3,000 volts and can injure or kill a person if not handled properly. Only trained technicians should perform this type of testing.
High Voltage Transformer If the microwave does not heat, the high voltage transformer might be burned out. Microwave ovens produce a very high voltage in order to power the magnetron antenna, which emits the energy that cooks the food.
Thermal Fuse If the microwave doesn't heat the thermal fuse may have blown. It can be tested for continuity. Watch our fuse testing video for more information.
Thermoprotector If the microwave doesn't heat the thermoprotector may have tripped. This is a safety device to prevent the microwave from overheating. It can be tested for continuity to see if it's blown.
Main Control Board If the microwave doesn't heat the main control board may be defective. This is not common. When a microwave doesn't heat the problem is usually within the high voltage circuit; either the high voltage capacitor, diode, transformer or magnetron.
Oct 03, 2012 | Sharp R-1870 Convection/Microwave Oven
Sharp micro doesn't heat
see this causes and fix it. God bless you
Oct 02, 2012 | Sharp Microwave Ovens
User Manual Needed for Sharp Carousel Microwave Model R-303CW
mcdevito75 here, Best Bet, contact Sharp online, try sharp microwave oven.com Or in any store that sells Sharp microwave ovens get contact info off that package.
Jul 07, 2010 | Sharp R-303CW Convection / Microwave Oven
How to set the time, and can i download a usermanual anywhere? Thanks
Touch the clock pad. Enter in the correct time of day by touching the numbers in sequence. Touch the clock pad again...should set.
I have not seen a manual on-line for your model...ut htere are many others...perhaps browsing thru a few might help you. If not...try going into a store and looking for that model...the management might copy if for you...I would. :-)
Apr 24, 2009 | Microwave Ovens
Sharp convection/microwave R8310 owners manuel
I have the manual for the R-8310 convection microwave oven by Sharp. Contact me @ mimi@CookbooksPlus.com.
Feb 23, 2009 | Sharp Microwave Ovens
Enameled Cast Iron Pans In Sharp Convection Microwave 820
It should be fine, but to be sure I'd contact Sharp.
You can contact Sharp at 1-800-BE-SHARP (1-800-237-4277).
We're happy to help and we appreciate your thoughtful rating of our answer.
Dec 10, 2007 | Sharp R-820B Convection/Microwave Oven
Microwave Ovens Logo
83 people viewed this question
Top Sharp Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Sharp Microwave Oven Expert? Answer questions, earn points and help others
