Question about Kodak ESP Office Equipment & Supplies
My kodak esp 6150 prints blank pages. I bought new ink and new print head and still prints and copies blank. Kodak support says I need new printer but there has to be a way to fix it. It was fine one day then next not. There is a build up of black ink in the small square area where the printhead sits
    Master:
  • 552 Answers
If u can't clean the print head and there is ink in the cartridge, then a new printer is in the plan.
try cleaning head by placing a pad soaked in alcohol (not Tequila) on the head for a while then gently wiping it clean. If u can remove other parts that r full of ink to clean them do that - careful that ink will get everywhere.
Posted on Dec 09, 2014
Www kodak com go support
We threw our 6150 into the trash (Florida does not recycle electronics) because it would not print correctly, even after we installed a new printhead and all new cartridges.
I recommend you cut your losses.
Aug 02, 2014 | Kodak ESP Office 6150 All-in-One Printer
Printer not printing document, prints out blank page
You may have a bad print head. Go through the troubleshooting in the Home Center>Resources first. It may have you run the clean print head function. If that doesn't do the trick you can order a print head at: http://www.kodak.com/ek/US/en/Home_Main/Inkjet_Products/Printing_Supplies.htm
Nov 19, 2013 | Kodak ESP Office Equipment & Supplies
Doesn't print magenta?
It appears the magenta print head nozzles are blocked.
Inkjet printers need to be used frequently to prevent ink drying out and blocking the print head nozzles.
If the print head cleaning maintenance routine does not clear the blockages, then print head needs replacing, but it may be expensive.
It may be more cost effective to buy a later model and better printer than replace the print head.
Apr 06, 2013 | Kodak ESP Office 6150 All-in-One Printer
Kodak esp office 6150 printing blank pages
Here's how I fixed my Kodak AIO 6150.
  1. 1. Remove cartridges
  2. 2. Remove the print head - lift up on the grey tab just above the bullseye - it'll pop right out - no tools needed.
  3. 3. Soak in alcohol - NOT RUBBING alcohol - Isopropyl 91% only for 1-2 hours - shake often.
  4. 4. Let it dry for at least 2-3 hours.
  5. 5. Reinstall everything. You'll get a new printhead message.
Dec 07, 2012 | Kodak ESP Office 6150 All-in-One Printer
My Kodak ESP 5 printer keeps printing out blank pages, while it functions as it is doing the actual printing process, it is just nothing has come out even the inks are full. Would you please advise your...
Hello Xuem,
To resolve the printing out blank pages problem visit the link provided below :
http://support.en.kodak.com/app/answers/detail/a_id/1098/selected/true
Jun 15, 2011 | Kodak ESP 5 Printer
Ive a kodak printer esp 7250 i have used it a couple times to print off my photos and its been fine,i got the printer out today and put new ink in ready to photo copy and it is not printing for some reason...
How long was the printer stored before you took it out to use it? You can't store a printer with or without ink cartridges in it. When a printer sits, the ink that is in the print heads settles and dries. Once that happens, the print heads are pretty much ruined. You can buy new print heads, but its usually cheaper to buy another printer instead. The reason it is not printing is probably because the print heads are plugged.
May 12, 2011 | Kodak Office Equipment & Supplies
I just bought a Kodak ESP 5210 and when it tried to calibrate after putting the ink cartridges in nothing comes out on the calibration page. Now when I try to print something, nothing is on the page. I...
Sounds like your print head needs replacing, exact same happened with me, appears to be a common problem with these Kodak printers, if new it should be covered under warrenty although good luck trying to get through to Kodak, I sent mine back in the end for a refund as long term print heads are around £65 each and they don't appear to last long
Jan 16, 2011 | Kodak ESP 3 Multifunction Printer/ Copier/...
Kodak esp 5 not printing properly and no yellow
Call Kodak @1800 421 6699 and get a new printhead free of cost.....Printhead has gone bad and it is the part in which we install the ink cartridges.It takes the ink out of the cartridges and spit the ink on the papers,...Cheers and Enjoy.
Dec 17, 2009 | Kodak ESP 5 Printer
My Kodak ESP 5 fades when printing then will go blank even when I have ink
try copying something from the printer in standalone mode and check if the same issue or not.....if it is then try and do print head cleaning from the menu option and if still does not resolve call kodak tech support as it is print head issue and needs replacement..........if the copy comes out fine and faded print is only when trying to print from the computer then it could be a software issue
Jul 01, 2009 | Kodak ESP 5 Printer
330 people viewed this question
Top Kodak Office Equipment & Supplies Experts
Are you a Kodak Office Equipment and Supply Expert? Answer questions, earn points and help others
