Haven't received December minutes why
Called keep getting disconnectd 5x I tried
Why haven`t I received any SSI or SOCIAL SECURETY BENEFITS SINCE DECEMBER 2013?
If there is a local branch I reccomend that you go in and speak to someone at the bank itself. If this continues to happen you can also look to close the account and move to a different bank. I would also call social security and inform them of the problem if you are unable to resolve it at the bank an seek reimbursement for back missing funds. Give them the new infomation from the new bank's account and they will let the old bank refund the money to them, however you will need to try and get the old account closed and likely you will be able to recover the funds at that time and without having SS do anything but change to a new bank and new account. This all applies only if you get direct deposit.
May 13, 2014 | Computers & Internet
Have a 2004 grand cherokee keep getting P0455 code and all my fixes haven't solved it yet any obscure ones that i haven't done?
There is a website jeepcherokeeform that has a lot of good information. I'd try there also. Have you disconnected the battery waited 15 minutes and reconnect to reset? That use to work, not sure now with the newer Jeeps. Good luck.
May 15, 2012 | 2004 Jeep Grand Cherokee
We have a PD-800 dvd player. & it keeps saying "wrong disc". help
unplug for 2 minutes, then plug back in. This works,If you haven't done this already, try a different disc, preferably one it has played successfully before. If another disc works, then take a look at the working side of the disc that doesn't work and check for scratches or smudges. Or, if it's a recordable disc, it may just be a brand that your player can't handle. Every now and then, I even get a factory DVD that my player can't handle.
If this is happening with any disc, even ones it has played successfully, then we'll hope for dust on the laser lens. Get a lens cleaning disc and try it. If that doesn't work, you may have to replace the player.
Sep 15, 2011 | Protron Televison & Video
I ordered 7 Superman Black Aztec tees from Goodguycomics on 8/27/2011. My transaction # is 98T34544482761673V. I have yet to receive a thing, and when I e-mail Goodguyscomics they fail to acknowledge my...
hi betty, since you haven't recieved your tees, & you've email them, then here's what I suggest
go to paypal & login to your account
& either use the help section to find the resolution center or
look under accounts & you'll see the word overview across to the right you'll see the resolution center, just click on the tab & start a dispute about items not recieved
I've had to do disputes several time & got results
good luck
Sep 11, 2011 | PayPal Accounts
My phone keeps saying "use
the LG chocolate is bad and knowen by battery problem and low capacity,, with your problem you must get new battery with best quality but I recommand you to change your mobile when you go back from Puerto Rico and have a good vacation.. ;)
Jul 20, 2011 | LG CHOCOLATE VX8500 Cellular Phone
UNIT TURN ON THE THE SPEAKERS MAKE A LOUD SQUEEKING NOISE AND A POP THEN THEY GO OUT
You might want to disconnect the speakers at this point just in case they haven't been irreparably damaged by the amp problem.
Try the amp 'naked" (no speakers). Does it still cycle off? Take it to a technician. If it stays up try one speaker; then the next. At some point you will either have identified the failing component/channel or the failure will have gone away (doubtful).
Jul 10, 2011 | Denon AVR-1908
How do you use this stupid calculator? I had a TI-89 and had no problems but I had to get a standard calculator for college, they won't allow the graphing calculators but I keep getting an Error 02...
Standard calculators can not really understand abstract notation. So 5x3/5x to the calculator is not being read as 5x (times) 3 (divided by) 5x, it is actually trying to understand x as a number. and if x isn't assigned as a number you'll get an error. SO no x's or y's or any letters. Anything with letters you have to do on your own. So 5x*3 / 5x cross out the two 5x's and you're left with 3/1 so your answer is 3.
Hope that helps! -Joe
Jun 07, 2011 | Sharp EL-531VB Calculator
My nokia phone can neither call nor receive acall,,its barring codes are blocked
I am sure this solution will help you, Just follow the steps.
1- Go into the settings and find the option of call barring usually its in call settings option. 2- Then you find the option of deactivate barring on all outgoing & incoming calls select yes and if it ask you any code or password then its 0000 by default or your sim pin code if you haven't changed. 3- After deactivating barring of incoming and outgoing calls, your phone can make and receive calls.
May 22, 2011 | Cell Phones
26 people viewed this question
jasbo
jasbo
