Question about Microwave Ovens
Can anyone please advise on Lamona combi HSA7020 which will not work as a microwave despite all the display looking as if it will heat up but then it doesn't?
    Master:
  • 552 Answers
Mw not working is either the magnetron or the diodes in the HV power supply.
If u r brave and want to fix it start with the diodes as they r a lot cheaper than the magnetron. Otherwise, take it to the dump.
Posted on Dec 09, 2014
Testimonial: "Many thanks for your advice"
Lamona microwave fault fault. When we close door, light and turntable working automatically but not heating. Please note unit is 27 months old
When you close the oven door, some micro switches are working. One of them is blocked. Check and replace the malfunctioning switch.
Nov 12, 2017 | Microwave Ovens
Amw528 error5
Microwaves have fault codes to help us determine the problem. Click the link below, it will take you to the Panasonic Combi Microwave site. Look at the manual closely. Either the fuses are blown or the microprocessor board is fried. Good Luck and be careful! Safety first! Commercial Microwave Ovens Large Microwave Commercial Kitchen Appliances...
Feb 05, 2016 | In Microwave Ovens
My miele combi oven microwave doesn't heat but oven is fine!
Probably a faulty door switch has blown the microwave fuse. If you are lucky.
Nov 17, 2017 | Microwave Ovens
Whirlpool microwave surface light does not work despite replacing the bulbs. I suspect that a previous renter's cat was fascinated w the on /off switch and burned it out. The light switch operates and the...
I am suspecting that your microwave has cheap chinese relays inside and instead of plating the part where electricity goes through with a high temperature metal that is a thick enough coating they used a cheaper metal. When they do that a relay arcs an spot welds itself open or closed. A strong tap on the control board (once taken apart) will release it. I advise to have a look at the control board for overheating, or burnt circuit board traces as well.
Nov 09, 2013 | Frigidaire Microwave Ovens
Panasonic invertor slimline combi
The main fuse in the microwave oven has blown, usually caused by one or two defective door switches.
Mar 30, 2012 | Panasonic Microwave Ovens
Lamona microwave has stopped heating everything else is working but food is the same temperature when finnished
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
Jun 08, 2011 | Microwave Ovens
Food still cold after cooking
Is this a combi oven? If it is not-and only a micro then there is no heating element. Try it on micro(if its a combi) with a mug of water for approx 30 seconds to test it. If its a combi-is the micro function still working?
Jun 21, 2009 | Emerson Microwave Ovens
Kenwood microwave (KEN GJ/SS25) heating doesn't work but grill works
Generally, the most common causes of a failure to heat are:
- bad door switches or door switch mounts
- loose connection at the magnetron
- problem or loose conneciton on the control unit circuit board
- bad magnetron or other high voltage part
If you or a friend decide to look into it, we have critical safety information, info on door switch diagnosis and replacement, and
disassembly information at our site, linked here on Fixya: http://tinyurl.com/yzjozk
Nov 24, 2007 | Sharp R-303CW Convection / Microwave Oven
Microwave Ovens Logo
166 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
