Does thhat means its un repairable if the bearring have gone
Nothing
    Problem Solver:
  • 17 Answers
Be sure that the noise you hear is the bearing. Check to see if your washer is direct drive or if there is a belt drive. Check to ensure that the noise is not just a drum roller support vs. a drum bearing. Consider the age of the washer, the energy efficiency and operation of the current washer as part of the decision to repair or replace.
Posted on Dec 09, 2014
Ford explorer 2011 rear axle wobbling and propeller shaft hitting the fuel tank bracket possible causes.
Sorry to say it sounds like you have a bent axle, If you mean Drive shaft when you say propeller shaft, then that's either because you also bent the driveshaft or you have u-joints that have gone bad. It sounds like a mess, Did you hit something or run over something? Rear axle don't just get bent form nothing. Has there been a grinding noise for awhile coming from the rear area? Your axle bearing or wheel hub bearing may be shot causing the wobble,
Nov 01, 2016 | Ford Cars & Trucks
What does in mean when the tempture keeps going up on the transmission
I'm going to assume this is an automatic transmission. The main cause of increased temp is the fluid isn't being cooled. For this you will have to 1) Check the coolant level.mix. Pure water is a no-no. 2) Make sure the transmission fluid lines to the radiator aren't crimped/constricted. You may also need a transmission service. Meaning, complete drain of trans fluid, new filter, gasket and fluid. The temp sensor may have gone wonky as well. A Chilton/Haynes repair manual should help under the trouble shooting section. These repair manuals are found at auto parts stores, Walmart etc. They are invaluable in helping a person perform own maintenance and repair and will advise when repair is best done by professional. And can give ideas so that less than honest shops can't rip you off by advising un-necessary repairs.
Sep 19, 2015 | 2006 Pontiac Grand Prix GT
What dose it mean when my samsung tv keeps changing extetion ports on its own
I think it got corrupted at some point. un plug it for 30 seconds and plug it back in and see it this helps.
Dec 25, 2014 | Samsung Televison & Video
BLOWER IS HUMMING
Try cleaning the inside thoroughly. Use a can of compressed air for those hard to reach places. Could also try spraying some WD-40 on visible shafts and bearings, etc.
If that doesn't work, the bearings might have gone, which means replacing/repairing the offending part.
Jun 29, 2014 | Heating & Cooling
How do you replace a bearing block on a 1990 jaguar XJS
please be more specific here if you can ,as bearing block means nothing to me here ,do you mean the universal propshaft hooks cross ,if so then parts are available but it may mean have the shaft machined to accept the circlip as some models just hammed over instead of a circlip but this is repairable in a machine shop who can cut a groove for the circlip to hold the joint in place
Feb 28, 2013 | 1990 Jaguar XJ6
LOVE
Love means never having to say your sorry. Love is passion. You can speak a thousand words but without passion your just making noise. You could chop down a mountain for another person but without love it means nothing. You could give your eyes to the blind, without love it is for nothing. Love has no jealousy, is always there, is not selfish, shows no anger, finds hope in all things, endures all things, bears all and Love never fails. After your are gone someone will still Love you.
Jan 09, 2011 | Kitchen Ranges
2003 yz 250 leaking water from hole at water pump. does it mean bearings bad? and if so how do you change it. all i find is the cover or the propellar. i cant find the bearing
leaking water means the seal is gone, the bearing is in the clutch case, often needs a new shaft as well if it has wear marks, replace the bearing, it will help the new seal last longer
Apr 10, 2010 | 2003 Yamaha YZ 250
Washing Machines Logo
24 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
