Question about Drills
Add the auxiliary handle - Drills
My auxiliary makes a whining noise on the radio on my 08 Jeep Liberty.Any ideas?
auxiliary now that really begs, a real NOUN.
really all things attached to and engine could be called auxiliary.
P./S
AC
ALT
idler there.
I guess he means the ALternator
and all ALT's do that,it's a 3phase alternator,with diodes that rectify these pulsed to pulsating DC, (noise)
the battery sucks up most this noise.. fact.
if one diode in the Alt SHORTS,OR OPENS,then NOISE GOES BALLISTIC,
I'm a radio man ( MIL and others)
car radio
ham radio
cb radio.
as you rac the engine ,the noises , a whine increases in tone.
tell you its ALT.
if ALT is OK on a SCOPE
then we add high pass filter to the radio power lead.
there are 2 paths here
power (conducted path)
and antenna (radiated path)
Jan 29, 2017 | 2008 Jeep Liberty
My Pioneer radio the DEH-2460R has on the back the white and the red cabel plug in, but i can't seem to activate the aux function is this possible with this type of radio?
That's not an auxiliary input, it's an output. Pioneer units that have an auxiliary input use a 3.5mm mini jack, not RCA jacks. Your model does not have an auxiliary input, or any way to add one..
Aug 28, 2015 | Pioneer DEH-2460R CD Player
How do I add the auxiliary handle to my DeWalt 510 Hammer drill? The 511 manual shows a hinged collar, not found on the handle I have or on any I've seen for sale. That sort would make it easy and sma
Unscrew the handle from the collar and see if it will open wide enough to slide over the chuck and onto the drill neck.
If not, you may have to remove the chuck. Open the chuck jaws completely and look down inside you will see the head of the screw which is holding the chuck onto the drill.
Dec 09, 2014 | Dewalt Drills
Jenerico po 460
Hi there:DTC P0460 - Fuel Level Sensor "A" Circuit
P0460 can be caused by the installation of aftermarket equipment such as remote starter systems and auxiliary fuel tanks.
  1. Example, Ford offers a remote starter system which is recommended. If the vehicle has an aftermarket remote starter system, it would need to be removed / disabled before diagnostics for P0460 can be started.
  2. Auxiliary fuel tanks that continuously replenish the vehicles main tank will cause a P0460. Customers that replenish the vehicles fuel tank from the auxiliary fuel tank while the key is on and engine is running, can set P0460. For vehicles with an auxiliary fuel tank, it is recommended not to use the gravity / continuous fill style auxiliary fuel tanks. It is recommended to add fuel to the vehicles main tank with the key off.
Hope this helps; also keep in mind that your feedback is important and I`ll appreciate your time and consideration if you leave some testimonial comment about this answer.
Thank you for using FixYa, have a nice day.
Aug 17, 2012 | 2001 Kia Sephia
How do I hook up auxiliary speakers to my 15" LED flat panel TV?
I'm looking at the picture of the inputs/outputs for your TV, and it appears that your only audio-out option is digital (the "AUDIO OUT/COAXIAL" orange output). You won't be able to just plug speakers in directly. If you have a receiver/system with a COAX input, you're good to go. If you have analog equipment, the digital output won't work.
Aug 12, 2012 | Coby Televison & Video
How do i open the hood.
there should be a lever that is on the bottom edge of dash that is under the steering wheel along the trim. if the handle is broken you can use pliers to grab the cable and pull it to get the hood to realse. if you found all that and i seems to work ok then when pulling the release lever have a friend hit or shake the hood to get it to pop up a little so that you can open it all the way.
Nov 20, 2010 | 1997 Ford Explorer AWD
Does this model have remote start the installer told me it did not
The Viper 3203 does not have remote start capabilities built in but an add-on unit can be installed to give you this functionality. The add-on unit would be controlled by one of the auxiliary channels.
Nov 09, 2010 | 3203 2way Security System
Auxiliary audio input for 2008 Mazda MX-5 with Bose sound system
Yes you can add auxiliary or ipod interface also xm radio
go here for more information
http://www.oemautosound.com/c-161-mazda-products.aspx
Jun 30, 2009 | 2008 Mazda Mx 5 Miata
Av3 2 1GS Media center
Yes, Try Media Receive Ltd - 0845 20 20 118
Dec 14, 2007 | Bose 3·2·1 GS II System
Drills Logo
61 people viewed this question
Top Drills Experts
Are you a Drill Expert? Answer questions, earn points and help others
