Question about Onkyo Audio Players & Recorders
Onkyo Tx NR626 receiver cooling fan does not run. Normal or not? Does chassis to need to reach certain point before it comes on?
    Genius:
  • Onkyo Master
  • 1,054 Answers
Most cooling fans in receivers only come on when they are needed. Some turn on at higher volume levels, others will not turn on until the unit gets too hot.
Posted on Dec 10, 2014
Lost the video but still get the audio from our cable tv box. Cable tv tech restored the video by bypassing the receiver, but still get the audio through receiver
No idea what the question is. If you want audio to match the TV then you need to take it off of the receiver and go direct to the TV. If you want it the way it was then you will have to have the receiver looked at and diagnose the problem.
Feb 18, 2016 | Onkyo TX-NR626
Two of legs missing, where can i find
Hi Greg, you can purchase them via our Parts and Service Department at 800-229-1687, they are here from 9am to 5pm eastern standard time, Thanks, JT
Sep 15, 2015 | Onkyo TX-NR626
How to run the speaker wires from the subwoofer to the onkyo 7.2 tx-nr626
See Onkyo manual here: http://filedepot.onkyousa.com/Files/own_manuals/TX-NR626_English.pdf
Insignia manual:
http://audio.manualsonline.com/manuals/mfg/insignia/nsht51.html?p=1
Best hookup method for sub is to use the LINE LEVEL INPUT on the Insignia, wired with RCA cables to the Subwoofer Pre Out jacks on the Onkyo
Jul 20, 2015 | Insignia NS-HT51 Speaker
Onkyo tx nr626 when volume high like 70-80 it turn off sign check speaker wires
soundslike a shorted speaker or a speaker that is being over-driven
Jan 07, 2015 | Onkyo Tx-sr507 A/V Receiver
How to set up one pair of ceiling speakers
what i would is get a stud finder so i could secure the speakers to a solid joist...i can help you through the installation if you like..
Jul 20, 2014 | Onkyo TX-NR626
NR626 - no sound
If none of your speakers gives any sound, perhaps you pressed the mute button on the remote control?
Make sure you have a source selected, that will give sound. Choose a low volume, before switching anything. You can destroy your speakers, when switching on with full volume.
If some speakers work, and only the surround does not work. check if you have surround sound as input. If you only feed 2 channels you can't expect to hear more than 2 channels.
Jul 01, 2014 | Onkyo TX-NR626
I have a new NR626 and I am unable to get the Sub Woofer Pre Out to work with my Bose Lifestyle Series II system with speakers. I tried connection the Bose through RCA to the NR626's Pre Out jacks, bu
usually if you have a sub out (line level) on the receiver..u can plug it directly into a pwrd sub and its plug and play..try putting another source into the woofer to see if its blown..if its not..then play with your menu settings on your nr626..get back to me if you need more help
Jan 08, 2014 | Onkyo TX-NR626
Onkyo TX-SR508 cooling fan
I don't know the psecific answer but wouldn't it be easier and safer to just locate the fan turn-on signal and cheat it? The fan is already on a 12v feed. I don't think you want to arbitrarly place an inherently noisy (electrically) device like a fan on a 12v buss in an audio device.
Jun 19, 2010 | Onkyo TX-SR606 Receiver
Onkyo tx sr804 receiver turns on by itself
I have the same receiver and the way to fix is simple. in the main board of this unit there are 5 connectors and they slide into other components like Lego. the issue is the king of material they are made of it's cheap. if you reseat the mainboard it will fix it for a day or two, them it will start again. the easyway is to re seat the board and put a fan inside of the receiver between the transformer and the inside of the amp pointing down about 20 degrees connect the fan to a ajustible voltage adapter and connect it to the outlet in the back of the unit. so it comes on when you turn it on. this voltage adapter is cheap. the adapters people buy for phones and or MP3's at Radio shack or Best buy it goes from 1.5v to 12 volts/ this way you can control how loud the fan is in side the receiver. i find 4.5V does the trick. The connectors on this board start to loose contact with some of the pins when heated. the fan keeps it cool enouth to fix the issue. I fixed manny these ONKYO 804's this will fix it. you just have to do it. the main board is inder the HDMI board in a Vertical position running from one side to almost the Power supply. it has 2 screws also holding it in the inside middle back of the amp. Becarefull with these amps 75 V at 23amp's DC is no joje leave it off for a couple of hours to satart working on it. Good luck.
Aug 26, 2009 | Onkyo TX-SR804 7.1 Channels Receiver
243 people viewed this question
Top Onkyo Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you an Onkyo Audio Player and Recorder Expert? Answer questions, earn points and help others
