Question about Hardware & Accessories
How do I set the Intertek 3075048 timer Model #YL-13M-1
Moving the dials. It comes on and off at goofy times.
  • 5,089 Answers
Post photo of timer so it can be identified.
Or describe timer in detail, including what it controls and if timer is digital or analog
Otherwise this model number appears to be fixya fiction
http://waterheatertimer.org/How-to-set-timers.html
Gene
Water Heater Timers Save Money
Posted on Dec 10, 2014
How to set Intertek indoor timer
Try Googling (Intertek)(model)(manual) without parens for instructions.
Apr 20, 2017 | Hardware & Accessories
How do I set this timer Intertek 3075048 Model #YL-13M-1
Timer not identified via google search or image search.
Attach photo to identify timer
Otherwise this model number seems to be a fixya invention, or older timer that pre-dates internet
Following link has many timer manuals
http://waterheatertimer.org/Woods-timers-and-manuals.html
Gene
Dec 09, 2014 | Hardware & Accessories
Need instructions to set a intertek timer BND-60/U4N
There are many BND-60 timers
1) Do you mean Intermatic timer? Instead of intertek?
http://waterheatertimer.org/Intermatic-timers-and-manuals.html
2) Is this BND-60-u or BND60-b analog timer from china?
3) is this BND-60 programmable timer from china?
http://waterheatertimer.org/Woods-timers-and-manuals.html#46-1022
4) Add comment and include photo of timer, or describe timer in detail for possible identification and further assistance.
Dec 04, 2012 | Hardware & Accessories
I have 2 intermatic lamp & appliance programmable timers. On the package the model number says: TN811C and on the timer itself says: TN811. Anyways I have read the instructions and I can't figure out...
1. To Set Program:
Pull up one tripper
between hour marks
on the 24-hour dial
for each 1/2 hour of
ON time desired. For
example, if timer is to
be ON between 12-2
PM, all four trippers
between those times
must be pulled up.
2. To set time
of day: turn dial
clockwise with the
arrow head pointed
to the correct time.
The dark area
denotes PM and
the white area
denotes AM.
Straight out of the manual. Pull up trippers for all of the time that you want the device to run.
Rotate the time of day dial in the direction of the arrows.
The off/on dial will override the timer until it comes around to the on time again then the timer will control.
Good luck.
Gary
Dec 10, 2010 | Intermatic Hardware & Accessories
How do I set the woods outdoor timer model #59730
Woods 59730 is24-hour 6-outlet yard stake with dial located on top
This timer is identical to GE15107 yard stake
Manual.
http://waterheatertimer.org/pdf/GE-15107-outdoor-timer-manual.pdf
If this is not your timer, look at following page to identify your timer
Add a comment any time
Timer instructions.
Set current time by rotating dial until time lines up with arrowhead located on inner dial
There are segments located around dial.
Look at inner dial > segments are located just outside the inner dial.
Timer comes with segments pushed inward.
To set timer to turn ON, pull segments outward for hours you want timer ON.
All 6 outlets are controlled by timer.
Last step:
There is override switch located on inner dial.
Move switch to TIMER for timer to operate.
Dec 09, 2010 | Woods Outdoor Lighting Timer
No instruction manual came with product. How do I set the timer? Which 2 outlets are always on and which are controlled by the timer?
What product do you have?
It sounds like an outdoor yard stake with receptacles, where the bottom one-or-two receptacles are always on, and the upper receptacles are controlled by timer.
If your timer is digital, we need to know the exact brand and model number in order to dig out the instructions for you.
If you have a dial-type timer, then you usually set current time by rotating dial. And you set on-off times by moving segments or pins back and forth or up and down. This action depends on the model of timer you have.
Answer back with more information and it is possible we can help you.
Oct 25, 2010 | Hardware & Accessories
Need instructions to set the First Alert TM220 Timer.
For the Model TM-220, 24 hour timer set as follows:
1. Begin with all timer segments on the dial 'pushed up'.
2. Push 'down' the segments required for the 'ON' time;
each segments represents 1 hour.
3. Rotate the dial clockwise until the 'TIME NOW' aligns with the pointer.
Mar 19, 2010 | First Alert 24 Hour Timers - 2 For The...
I have the GE Plug in Mechanical Timer Model 15119. I have the pins pulled up on the white side at 5 and on the black side at 5 and the side setting on the timer position. Yet when I plug it in the wall...
We had the same problem when we first tried to set our timer. Although we have a newer model, this might work for your timer as well. The pin for each 1/2 hour interval that you want the device to be "on" must be pushed toward the perimeter of the dial, not the center of the dial. For each 1/2 hour interval that you want the device off, the pins should be pushed toward the center of the timer. Don't forget to move the arrow on the dial to the current time just before plugging in the timer. Be sure the switch on the side of the timer is moved to "timer on", the override is "outlet on" for when you want your device to come on during the time that the timer is set to have your device turned off.
Dec 27, 2009 | General Electric GE 24-Hour Timer, 2-Pin...
I need an owner manuel for Caloric Range Model # EST 345 I can'g figure out how to run the self cleaning oven cycle.
you might try the following, although it is the instructions for an old model, it may be relevant;
"The actual self-cleaning process is initiated by a simple 5 step procedure: 1. Set the range clock to time of day. Note: on models not equipped with an automatic oven timer, the self-cleaning cycle is preprogrammed for a 21/2 hour cycle. Use Steps 3, 4 and 5 only. 2.Establish the length of cleaning time by:
A. Setting the start time. Press and turn the start dial of the automatic oven timer clockwise to the desired starting time. B. Set the stop time. Press and turn the stop dial of the automatic oven timer clockwise to the desired stop time. Max time is 3 hours miniumum 1/12 hours. 3. Set the oven selector dial on the control panel to "Clean" 4. Set the temperature control dial to "off". If you temperature control dial has a "Clean" position, then set the dial to "Clean" instead of "Off". 5. Remove oven racks, broiler pan and broiler grid from lower oven. Close and lock the oven door by moving the latch lever as far right as it will go - into the locked position. If the lever is accidently dislodged restore it to the locked position. Otherwise, the self-cleaning process will not take place. Shortly after the cleaning cycle has begun, the oven temperatur reaches a degree in excess of the normal broiling temperature. The red "Clean" light will come on and the clean cycle will start. In a few minutes the door lock lever, which you have placed in the locked position, will automatically be secured to prevent the oven door from beging opened during the cleaning cycle. This latch remains locked until the clean cycle is complete and the oven temperature reduces to normal baking and broiling temperaturs. NOTE: Prior to self cleaning cycle operation, the oven and surface lights must be turned offed. The upper oven can be used."
I found this here; http://www.appliance411.com/archive/21155_caloric_oven_lost_cleaning_manual.shtml
Nov 18, 2009 | Ovens
Hardware & Accessories Logo
149 people viewed this question
Top Hardware & Accessories Experts
Gene Haynes
Hippy_dd
Are you a Hardware and Accessory Expert? Answer questions, earn points and help others
